dashticz: Important Request
- Thuis
Re: IMPORTANT REQUEST!!!
this is line 44 of the SG_iCal_Parser.php
$c = curl_init();
correct ?
$c = curl_init();
correct ?
I Love Domoticz ! And the community around it :-)
- Thuis
well i tried several things like adding php_curl.dll in my php.ini file, copying dll files from php folder to apache24\bin folder. But i never get a curl in the phpinfo.php. Only the name of the module maker, which is Sterling Hughes by the way....
For now, i just leave it at this, i have to do some work. Tomorrow i will be switching and swapping files on the windows machine again ,to see if i can get it to work somehow :-p
- Domoticz version: 3.8993
Tried everything:
Updated the part in calendar.js
and add this in my CONFIG.js
But no calendar is shown.
if (settings['calendar_parse_localy']){
curUrl = './vendor/dashticz/ical/?time=' + cache + '&url=' + curUrl;
} else {
curUrl = 'https://MY WEBSITE/dashticz/ical/?time=' + cache + '&url=' + curUrl;
config['calendar_parse_localy']=false;
- HansieNL
Updated to beta 2.4.2 and installed: sudo apt-get install php7.0-curl
Calendar and TV Channels working great. Now I have only to get Garbage working.
Blah blah blah
- EdwinK
- Domoticz version: BETA
Still can't get it to work. Server is running on Synology with php7 and Curl enabled. Keep getting connection refused errors
Failed to load resource: net::ERR_CONNECTION_REFUSED
:8080/scripts/ical/?time=1540223287867&url=https://calendar.google.com/calendar/ic ... asic.ics:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
:8080/scripts/afval/?service=mijnafvalwijzer&sub=undefined&zipcode=3161LH&nr=27&t=:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
php7.0-curl was already running. Everything except Calendar is working
- HansieNL
[FIXED] @poudenes : You got your garbage running?
If I try http://json.mijnafvalwijzer.nl/?method= ... oevoeging= in the browser I get a json response. Mmm...
Blah blah blah
To get the garbage running don't forget to edit function getGeneralData(service,address, date, random, subservice){ in the garbage.js.
Replace the dashticz.nl with you own domain
- HansieNL
[FIXED] @peerkersezuuker : I did change the domainsaddress and port to my own webserver. But no luck till now.
If I try http://192.168.2.14:3000/dashticz/vendo ... L&nr=41&t= in the browser I get all the data I need, but not in the Garbage block
Blah blah blah
- EdwinK
Got thrash working. I had added portnumber, but I forgot I don't use a specific port for web on my synology
On to the next
Calendar also working
On to the next
@HansieNL,
And when you enable the inspector from your browser and open your dashticz board, do yo see any errors in the console pane regarding your url ?
- HansieNL
Missed function getGeneralData(service,address, date, random, subservice){ in the garbage.js.peerkersezuuker wrote: ↑Monday 22 October 2018 18:59 @HansieNL,
Thanks for the help. Everything is up and running as it was before
Blah blah blah
- EdwinK
I just need tvguide and public transportation working. Then I'm real happy.
I get a ERROR 403 - Forbidden.
77.250.102.136 - - [22/Oct/2018:19:30:38 +0200] "GET /dashticz/ical/?time=1540229438248&url=https://p28-calendars.icloud.com/publis ... YjJQOufb3g HTTP/1.1" 403 2348 "http://192.168.100.18:8081/dashbeta/index2.html" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36"
find this URL in log file and tried open it in browser. Then get a error 403. (Yes paste the full URL
can someone tell me what this problem can be?
all you lucky ones. I don't get the curl module enabled. I ended up with PHP 5.6, 7.0 and 7.2
When I run the phpinfo.php file, it always gives me the php info of 5.6, but I don't see the module loaded/enabled
How should I proceed, delete 2 of 3 PHP versions?
And why do some use a specific port number, I simply added the afval folder in the same folder as the ical folder in /vendor/dashticz/ and pointed towards that in the garbage.js file. Is that the right way to do it?
- HansieNL
Are you running your own webserver? I run my own webserver and is set to a different port.jake wrote: ↑Monday 22 October 2018 20:03 all you lucky ones. I don't get the curl module enabled. I ended up with PHP 5.6, 7.0 and 7.2
I'm running nginx with php. You can find a good description how to do that on raspberrypi.org https://www.raspberrypi.org/documentati ... r/nginx.md Maybe that solves your problem with the php version.
Blah blah blah
- Domoticz version: 4.10538
Is it possible to configure ip address (and /or path) from config file?
I have Dashticz installed in /var/www/html and can access it from my tablet. Am I right to say that I therefore have an (apache) webserver running?HansieNL wrote: Are you running your own webserver? I run my own webserver and is set to a different port.
Phpinfo.php shows me the php information as well. When I look in the 'loaded modules', I don't see curl in the list.
- Spoiler: show
- Domoticz version: latest b
Install curl for php and change the parameter in the settings, thats all, no changed of anything in the code.jake wrote: ↑Tuesday 23 October 2018 9:23I have Dashticz installed in /var/www/html and can access it from my tablet. Am I right to say that I therefore have an (apache) webserver running?HansieNL wrote: Are you running your own webserver? I run my own webserver and is set to a different port.
- Spoiler: show
It is imported to use the latest beta.
Moses123
I installed curl for php, but somehow it doesn't load. I don't think that having 3 versions on my system helps. Would I be better off to remove 2? If so, should I keep 5.6 or 7.2?moses123 wrote: Install curl for php and change the parameter in the settings, thats all, no changed of anything in the code.
Moses123
