dashticz: Important Request
Thuis
Re: IMPORTANT REQUEST!!!
Post by Thuis »
this is line 44 of the SG_iCal_Parser.php
$c = curl_init();
correct ?
I Love Domoticz ! And the community around it :-)
Thuis
Post by Thuis »
well i tried several things like adding php_curl.dll in my php.ini file, copying dll files from php folder to apache24\bin folder. But i never get a curl in the phpinfo.php. Only the name of the module maker, which is Sterling Hughes by the way....
For now, i just leave it at this, i have to do some work. Tomorrow i will be switching and swapping files on the windows machine again ,to see if i can get it to work somehow :-p
poudenes
Domoticz version: 3.8993
Post by poudenes »
Tried everything:
Updated the part in calendar.js
        if (settings['calendar_parse_localy']){
                curUrl = './vendor/dashticz/ical/?time=' + cache + '&url=' + curUrl;
        } else {
                curUrl = 'https://MY WEBSITE/dashticz/ical/?time=' + cache + '&url=' + curUrl;
and add this in my CONFIG.js
config['calendar_parse_localy']=false;
But no calendar is shown.
HansieNL
Post by HansieNL »
Updated to beta 2.4.2 and installed: sudo apt-get install php7.0-curl
Calendar and TV Channels working great. Now I have only to get Garbage working.
Blah blah blah
EdwinK
Post by EdwinK »
Still can't get it to work. Server is running on Synology with php7 and Curl enabled. Keep getting connection refused errors
Failed to load resource: net::ERR_CONNECTION_REFUSED
:8080/scripts/ical/?time=1540223287867&url=https://calendar.google.com/calendar/ic ... asic.ics:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
:8080/scripts/afval/?service=mijnafvalwijzer&sub=undefined&zipcode=3161LH&nr=27&t=:1 Failed to load resource: net::ERR_CONNECTION_REFUSED
poudenes
Post by poudenes »
HansieNL wrote: Monday 22 October 2018 17:42 Updated to beta 2.4.2 and installed: sudo apt-get install php7.0-curl
php7.0-curl was already running. Everything except Calendar is working
HansieNL
Post by HansieNL »
[FIXED] @poudenes : You got your garbage running?
If I try http://json.mijnafvalwijzer.nl/?method= ... oevoeging= in the browser I get a json response. Mmm...
Blah blah blah
peerkersezuuker
Post by peerkersezuuker »
To get the garbage running don't forget to edit function getGeneralData(service,address, date, random, subservice){ in the garbage.js.
Replace the dashticz.nl with you own domain
HansieNL
Post by HansieNL »
[FIXED] @peerkersezuuker : I did change the domainsaddress and port to my own webserver. But no luck till now.
If I try http://192.168.2.14:3000/dashticz/vendo ... L&nr=41&t= in the browser I get all the data I need, but not in the Garbage block :(
Blah blah blah
EdwinK
Post by EdwinK »
Got thrash working. I had added portnumber, but I forgot I don't use a specific port for web on my synology
On to the next
Calendar also working :)
peerkersezuuker
@HansieNL,
And when you enable the inspector from your browser and open your dashticz board, do yo see any errors in the console pane regarding your url ?
HansieNL
Post by HansieNL »
peerkersezuuker wrote: Monday 22 October 2018 18:59 @HansieNL,
Missed function getGeneralData(service,address, date, random, subservice){ in the garbage.js. :oops: :oops:
Thanks for the help. Everything is up and running as it was before :D :D :D
Blah blah blah
EdwinK
Post by EdwinK »
I just need tvguide and public transportation working. Then I'm real happy.
poudenes
Post by poudenes »
I get a ERROR 403 - Forbidden.
77.250.102.136 - - [22/Oct/2018:19:30:38 +0200] "GET /dashticz/ical/?time=1540229438248&url=https://p28-calendars.icloud.com/publis ... YjJQOufb3g HTTP/1.1" 403 2348 "http://192.168.100.18:8081/dashbeta/index2.html" "Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_6) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36"
find this URL in log file and tried open it in browser. Then get a error 403. (Yes paste the full URL :) )
can someone tell me what this problem can be?
jake
Post by jake »
all you lucky ones. I don't get the curl module enabled. I ended up with PHP 5.6, 7.0 and 7.2
When I run the phpinfo.php file, it always gives me the php info of 5.6, but I don't see the module loaded/enabled
How should I proceed, delete 2 of 3 PHP versions?
And why do some use a specific port number, I simply added the afval folder in the same folder as the ical folder in /vendor/dashticz/ and pointed towards that in the garbage.js file. Is that the right way to do it?
HansieNL
Post by HansieNL »
jake wrote: Monday 22 October 2018 20:03 all you lucky ones. I don't get the curl module enabled. I ended up with PHP 5.6, 7.0 and 7.2
Are you running your own webserver? I run my own webserver and is set to a different port.
I'm running nginx with php. You can find a good description how to do that on raspberrypi.org https://www.raspberrypi.org/documentati ... r/nginx.md Maybe that solves your problem with the php version.
Blah blah blah
pvm
Domoticz version: 4.10538
Post by pvm »
Is it possible to configure ip address (and /or path) from config file?
jake
Post by jake »
HansieNL wrote: Are you running your own webserver? I run my own webserver and is set to a different port.
I have Dashticz installed in /var/www/html and can access it from my tablet. Am I right to say that I therefore have an (apache) webserver running?
Phpinfo.php shows me the php information as well. When I look in the 'loaded modules', I don't see curl in the list.
core mod_so mod_watchdog http_core mod_log_config mod_logio mod_version mod_unixd mod_access_compat mod_alias mod_auth_basic mod_authn_core mod_authn_file mod_authz_core mod_authz_host mod_authz_user mod_autoindex mod_deflate mod_dir mod_env mod_filter mod_mime prefork mod_negotiation mod_php5 mod_reqtimeout mod_setenvif mod_status
moses123
Domoticz version: latest b
Post by moses123 »
jake wrote: Tuesday 23 October 2018 9:23
Install curl for php and change the parameter in the settings, thats all, no changed of anything in the code.
It is imported to use the latest beta.
Moses123
jake
Post by jake »
moses123 wrote: Install curl for php and change the parameter in the settings, thats all, no changed of anything in the code.
Moses123
I installed curl for php, but somehow it doesn't load. I don't think that having 3 versions on my system helps. Would I be better off to remove 2? If so, should I keep 5.6 or 7.2?
