Or the OpenAQ plugin, works perfectly.
viewtopic.php?f=65&t=22092
Get online airquality data [SOLVED]
- Domoticz version: 2026.3
Re: Get online airquality data
mojso
Hi, I have a question again, the script works great,
Can it be done in the script
if the rgb light is turned off, the command to change the color will not be sent
data from http://waqi.info/
An API key is required and can be aquired here ==> http://aqicn.org/data-platform/token/
Based on the original idea and script from @elmortero
http://api.waqi.info/feed/geo:51.852062;4.507676/?token=Your_apikey = Zwartewaalstraat, Rotterdam Zuid
http://api.waqi.info/feed/geo:51.986119;4.934413/?token=Your_apikey = Lopik (co)
http://api.waqi.info/feed/geo:51.867238,4.354981/?token=Your_apikey = Leemkuil (so2)
timer = { "every 30 minutes" },
httpResponses = { "waqi*" } -- matches callback wildcard
data = {
safedMessage = { history = true, maxItems = 100 , maxHours = 168 }
logging = { level = domoticz.LOG_DEBUG,
marker = "Waqi" },
execute = function(dz, triggerItem)
local apiKey = "my api"
local defaultLocation = "my location"
local sensorType
local colorDevice = dz.devices('desk light')
if dz.data.safedMessage.get(1) == nil then
dz.data.safedMessage.add("Init")
local geo = { nearby = defaultLocation, -- to get station closest to your home
so2 = "", -- if value for this item cannot be obtained from "nearby"
co = "", -- else keep this as an empty string
pm25 = "",
pm10 = "",
o3 = "",
no2 = "",
aqi = "",
p = "", --barometer
w = "",
-- wg = "",
local sensors = { so2 = { sensor = 62, alert = 63 }, -- enter device index Numbers or 0 for sensor and alert "
co = { sensor = 64, alert = 65 },
pm25 = { sensor = 66, alert = 67 },
pm10 = { sensor = 68, alert = 69 },
o3 = { sensor = 70, alert = 71 },
no2 = { sensor = 72, alert = 73 },
aqi = { sensor = 76, alert = 75 , aqiSensor = 74}, -- additional Air Quality sensor
p = { sensor = 647, alert = 0 }, --barometer
w = { sensor = 656, alert = 0 },
-- wg = { sensor = 657, alert = 0 },
local sensorTypes = { alert = "Alert", aqi = "Air Quality", custom = "Custom Sensor" }
local function responseType(str) -- strip waqi_ from string
return str:gsub("waqi_","")
local function setColor(value, device)
local colors = {
green = {min = 0, max = 50, red = 0, green = 255, blue = 0},
yellow = {min = 51, max = 100, red = 255, green = 255, blue = 0},
orange = {min = 101, max = 150, red = 255, green = 165, blue = 0},
red = {min = 151, max = 200, red = 255, green = 0, blue = 0},
purple = {min = 201, max = 300, red = 128, green = 0, blue = 128},
maroon = {min = 301, max = 999999, red = 128, green = 0, blue = 0},
for color, control in pairs(colors) do
if value > control.min and value <= control.max then
device.setColor(control.red, control.green, control.blue, device.level)
device.dimTo(device.level).afterSec(1)
--device.dump()
local function errorMessage(message,notify) -- Add entry to log and notify to all subsystems
dz.log(message,dz.LOG_ERROR)
if notify then
dz.notify(message)
local function callPollutionURL(location,callback,delay)
local delay = delay or 1
local url = "http://api.waqi.info/feed/geo:".. location .. "/?token=" .. apiKey
dz.openURL({ url = url,
method = "GET",
callback = callback
}).afterSec(delay)
local function getAirQualityData()
local delay = 1
for callType, location in pairs(geo) do
if location ~= "" then
callPollutionURL(location,"waqi_" .. callType,delay)
delay = delay + 30
local function alertLevelAQI(value)
if value < 50 then return dz.ALERTLEVEL_GREEN,"Excellent" end
if value < 100 then return dz.ALERTLEVEL_YELLOW,"Poor" end
if value < 150 then return dz.ALERTLEVEL_ORANGE,"Polluted" end
return dz.ALERTLEVEL_RED,"Dangerous"
function deviceType(device)
if device ~= nil then
if dz.devices(device).deviceType:upper() == "GENERAL" then
return dz.devices(device).deviceSubType
return dz.devices(device).deviceType
return nil
local function setSensor(sensor,value)
if sensor ~= 0 and value ~= nil then
if deviceType(sensor) == sensorTypes.custom then
dz.devices(sensor).updateCustomSensor(value)
elseif deviceType(sensor) == sensorTypes.aqi then
dz.devices(sensor).updateAirQuality(value)
local alertLevel, alertText = alertLevelAQI(value)
local alertString = alertText .. "(" .. tostring(value) .. ")"
if dz.devices(sensor).text ~= alertString then
dz.devices(sensor).updateAlertSensor(alertLevel, alertString)
local function handleResponse(type)
local rt = triggerItem.json -- rt is just a reference to the data no actual copy is done
dz.log(triggerItem.data,dz.LOG_DEBUG)
if triggerItem.json ~= nil and rt.data ~= nil and tonumber(rt.data.aqi) then
if type == "nearby" then
rt.data.iaqi["aqi"] = {}; rt.data.iaqi["aqi"].v = rt.data.aqi -- handle exception in iaqi as aqi is stored elsewhere
for nearbyType, location in pairs(geo) do
if nearbyType ~= "nearby" and location == "" then -- No other location for this type
handleResponse(nearbyType)
for setDevice, idx in pairs(sensors[type]) do
dz.log("setDevice" .. setDevice, dz.log_DEBUG)
dz.log("idx" .. idx, dz.log_DEBUG)
dz.log("sensors[Type]" .. tostring(sensors[Type]), dz.log_DEBUG)
dz.log("rt" .. tostring(rt), dz.log_DEBUG)
dz.log("rt.data" .. tostring(rt.data), dz.log_DEBUG)
dz.log("rt.data.iaqi" .. tostring(rt.data.iaqi), dz.log_DEBUG)
dz.log("rt.data.iaqi[type]" .. tostring(rt.data.iaqi[type]), dz.log_DEBUG)
setSensor(idx,rt.data.iaqi[type:lower()].v)
dz.log("type" .. tostring(type), dz.log_DEBUG)
if type:lower() == 'pm10' then
dz.log("pm10 value" .. tostring(rt.data.iaqi.pm10.v), dz.log_DEBUG)
setColor(rt.data.iaqi.pm10.v, colorDevice)
errorMessage("This should not happen") -- aqi should always be there and set
if dz.data.safedMessage.get(1).time.secondsAgo > 30 then
errorMessage("I will call url again") -- aqi should always be there and set
callPollutionURL(geo[responseType(triggerItem.trigger)],triggerItem.trigger,1)
dz.data.safedMessage.add("Extra call to openURL for " .. triggerItem.trigger)
if triggerItem.isHTTPResponse then
if triggerItem.ok and triggerItem.isJSON then
handleResponse(responseType(triggerItem.trigger))
errorMessage("Problem with response from waqi",true)
getAirQualityData()
You can add a check for device.active in the if statement.
See also wiki https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
mojso
Thanks i added in line 80 "and device.active" and i think it works as it should
waltervl wrote: Saturday 23 July 2022 22:58 You can add a check for device.active in the if statement.
