Get online airquality data  [SOLVED]
Domoticz version: 2025.1
Re: Get online airquality data
Or the OpenAQ plugin, works perfectly.
viewtopic.php?f=65&t=22092
mojso
Post by mojso »
Hi, I have a question again, the script works great,
Can it be done in the script
if the rgb light is turned off, the command to change the color will not be sent
data from http://waqi.info/
An API key is required and can be aquired here ==> http://aqicn.org/data-platform/token/
Based on the original idea and script from @elmortero
http://api.waqi.info/feed/geo:51.852062;4.507676/?token=Your_apikey = Zwartewaalstraat, Rotterdam Zuid
http://api.waqi.info/feed/geo:51.986119;4.934413/?token=Your_apikey = Lopik (co)
http://api.waqi.info/feed/geo:51.867238,4.354981/?token=Your_apikey = Leemkuil (so2)
    on =    {
                timer           = { "every 30 minutes" },
                httpResponses   = { "waqi*" }                            -- matches callback wildcard
        data    =   {
                        safedMessage = { history = true, maxItems = 100 , maxHours = 168 }
        logging =   {   level   =   domoticz.LOG_DEBUG,
                        marker  =   "Waqi" },
    execute = function(dz, triggerItem)
        local apiKey            = "my api"
        local defaultLocation   = "my location"
        local sensorType
        local colorDevice = dz.devices('desk light')
        if dz.data.safedMessage.get(1) == nil then
            dz.data.safedMessage.add("Init")
        local geo   = { nearby  = defaultLocation,        -- to get station closest to your home
                        so2     = "",   -- if value for this item cannot be obtained from "nearby"
                        co      = "",   -- else keep this as an empty string
                        pm25    = "",
                        pm10    = "",
                        o3      = "",
                        no2     = "",
                        aqi     = "",
                        p       = "", --barometer
                        w       = "",
                       -- wg       = "",
        local sensors = {   so2     = { sensor = 62,  alert = 63 },   -- enter device index Numbers or 0 for sensor and alert "
                            co      = { sensor = 64,  alert = 65 },
                            pm25    = { sensor = 66,  alert = 67 },
                            pm10    = { sensor = 68,  alert = 69 },
                            o3      = { sensor = 70,  alert = 71 },
                            no2     = { sensor = 72,     alert = 73 },
                            aqi     = { sensor = 76,  alert = 75  , aqiSensor = 74},      -- additional Air Quality sensor
                            p       = { sensor = 647, alert = 0 }, --barometer
                            w       = { sensor = 656, alert = 0 },
                           -- wg       = { sensor = 657, alert = 0 },
        local sensorTypes = { alert = "Alert", aqi = "Air Quality", custom = "Custom Sensor" }
        local function responseType(str)   -- strip waqi_ from string
            return str:gsub("waqi_","")
        local function setColor(value, device)
            local colors =  {
                                green =  {min = 0, max = 50, red = 0, green = 255, blue = 0},
                                yellow = {min = 51, max = 100, red = 255, green = 255, blue = 0},
                                orange = {min = 101, max = 150, red = 255, green = 165, blue = 0},
                                red    = {min = 151, max = 200, red = 255, green = 0, blue = 0},
                                purple = {min = 201, max = 300, red = 128, green = 0, blue = 128},
                                maroon = {min = 301, max = 999999, red = 128, green = 0, blue = 0},
            for color, control in pairs(colors) do
                if value > control.min and value <= control.max then
                    device.setColor(control.red, control.green, control.blue, device.level)
                    device.dimTo(device.level).afterSec(1)
                    --device.dump()
        local function errorMessage(message,notify)   -- Add entry to log and notify to all subsystems
            dz.log(message,dz.LOG_ERROR)
            if notify then
                dz.notify(message)
        local function callPollutionURL(location,callback,delay)
            local delay = delay or 1
            local url   = "http://api.waqi.info/feed/geo:".. location .. "/?token=" .. apiKey
            dz.openURL({    url         = url,
                            method      = "GET",
                            callback    = callback
                       }).afterSec(delay)
        local function getAirQualityData()
            local delay = 1
            for callType, location in pairs(geo) do
                if location ~= "" then
                    callPollutionURL(location,"waqi_" .. callType,delay)
                    delay = delay + 30
        local function alertLevelAQI(value)
            if value < 50 then return dz.ALERTLEVEL_GREEN,"Excellent" end
            if value < 100 then return dz.ALERTLEVEL_YELLOW,"Poor" end
            if value < 150 then return dz.ALERTLEVEL_ORANGE,"Polluted" end
            return dz.ALERTLEVEL_RED,"Dangerous"
        function deviceType(device)
            if device ~= nil then
                if dz.devices(device).deviceType:upper() == "GENERAL" then
                    return dz.devices(device).deviceSubType
                    return dz.devices(device).deviceType
                return nil
        local function setSensor(sensor,value)
            if sensor ~= 0 and value ~= nil then
                if deviceType(sensor) == sensorTypes.custom then
                    dz.devices(sensor).updateCustomSensor(value)
                elseif deviceType(sensor) == sensorTypes.aqi then
                    dz.devices(sensor).updateAirQuality(value)
                    local alertLevel, alertText = alertLevelAQI(value)
                    local alertString = alertText .. "(" .. tostring(value) .. ")"
                    if dz.devices(sensor).text ~= alertString then
                        dz.devices(sensor).updateAlertSensor(alertLevel, alertString)
        local function handleResponse(type)
            local rt = triggerItem.json                        -- rt is just a reference to the data no actual copy is done
            dz.log(triggerItem.data,dz.LOG_DEBUG)
            if triggerItem.json ~= nil and rt.data ~= nil and tonumber(rt.data.aqi) then
                if type == "nearby" then
                    rt.data.iaqi["aqi"] = {}; rt.data.iaqi["aqi"].v = rt.data.aqi    -- handle exception in iaqi as aqi is stored elsewhere
                    for nearbyType, location in pairs(geo) do
                        if nearbyType ~= "nearby" and location == "" then               -- No other location for this type
                            handleResponse(nearbyType)
                    for setDevice, idx in pairs(sensors[type]) do
                        dz.log("setDevice" .. setDevice, dz.log_DEBUG)
                        dz.log("idx" .. idx, dz.log_DEBUG)
                        dz.log("sensors[Type]" .. tostring(sensors[Type]), dz.log_DEBUG)
                        dz.log("rt" .. tostring(rt), dz.log_DEBUG)
                        dz.log("rt.data" .. tostring(rt.data), dz.log_DEBUG)
                        dz.log("rt.data.iaqi" .. tostring(rt.data.iaqi), dz.log_DEBUG)
                        dz.log("rt.data.iaqi[type]" .. tostring(rt.data.iaqi[type]), dz.log_DEBUG)
                        setSensor(idx,rt.data.iaqi[type:lower()].v)
                    dz.log("type" .. tostring(type), dz.log_DEBUG)
                    if type:lower() == 'pm10' then
                        dz.log("pm10 value" .. tostring(rt.data.iaqi.pm10.v), dz.log_DEBUG)
                        setColor(rt.data.iaqi.pm10.v, colorDevice)
                errorMessage("This should not happen")   -- aqi should always be there and set
                if dz.data.safedMessage.get(1).time.secondsAgo > 30 then
                    errorMessage("I will call url again")   -- aqi should always be there and set
                    callPollutionURL(geo[responseType(triggerItem.trigger)],triggerItem.trigger,1)
                    dz.data.safedMessage.add("Extra call to openURL for " .. triggerItem.trigger)
        if triggerItem.isHTTPResponse then
           if triggerItem.ok and triggerItem.isJSON then
               handleResponse(responseType(triggerItem.trigger))
               errorMessage("Problem with response from waqi",true)
            getAirQualityData()
You can add a check for device.active in the if statement.
See also wiki https://www.domoticz.com/wiki/DzVents:_ ... ll_devices
mojso
Post by mojso »
Thanks i added in line 80 "and device.active" and i think it works as it should
waltervl wrote: Saturday 23 July 2022 22:58 You can add a check for device.active in the if statement.
