Your Python plugin UPS monitor, works perfectly with my Pi3B, Python 3.4, Domoticz béta 9424, Synology and eaton 650 Pro.
everything is great
Thx
Thanks for your appreciation !toutazimuth wrote: Friday 11 May 2018 20:47 Hi Logread
everything is great
Thx![]()
Your version of Domoticz probably is too old... as said in the installation instructions it must be 3.7418 at a minimum. You should also disable the plugin (to delete its devices) before upgrading domoticz and re-enabling the plugin. Hopefully this should fix the issue you are having.legus49 wrote: Monday 05 November 2018 1:34 Hi,
I just installed UPS Monitor and it's working fine on Domoticz 3.7207, but I do not have the units for the sensors (Volt, %, W...) Any idea ?
Thanks a lot for this very usefull plugin.
The list of status variables handled by the plugin is embedded in the code:Skydesign wrote: Monday 31 December 2018 7:44 Hi.
Thank you for the plugin.
I installed a plugin that monitors UPS Power Walker with blazer_usb driver, in the terminal it displays a lot of information, eg input voltage, power, battery voltage, etc. Unfortunately, domoticz shows only a few data:
UPS status mode, UPS AC ferquency, UPS Charge %, UPS Load %, UPSAC Input.
How can I add more sensors eg battery voltage?
self.variables = {
# key: [device label, unit, value, device number, used by default]
"ups.status": ["UPS Status", "", 0, 1, 1],
"battery.charge": ["UPS Charge", "%", None, 2, 1],
"battery.runtime": ["UPS Backup Time", "s", None, 3, 1],
"input.voltage": ["UPS AC Input", "V", None, 4, 0],
"ups.load": ["UPS Load", "%", None, 5, 0],
"ups.realpower": ["UPS Power", "W", None, 6, 0],
"input.frequency": ["UPS AC Frequency", "Hz", None, 7, 0]
}Thank you, it works greatLogread wrote: Tuesday 01 January 2019 10:32 If your UPS server reports other variables that you want to capture, the above table needs to be expanded accordingly.
Thank you
Probably because the UPS devices created in domoticz are of « custom » type and I suspect these devices are not fully handled by the mobile app... but this is just a guesshaden wrote: Monday 14 January 2019 21:29 Thanks for nice plugin. works great
But for some reason i'm unable to see logs from any of the UPS devices on my Android phone using the lite app. It works fine for other sensors, and the UPS logs is working fine in a normal browser.
Seems the plugin was not able to create the devices.droop7 wrote: Tuesday 09 April 2019 16:07 Hello everybody
I try to word with this script but i'm a little bit blocked.
2019-04-09 15:51:14.549 Error: (APC) 'onStart' failed 'KeyError'.
2019-04-09 15:51:14.549 Error: (APC) ----> Line 199 in /home/pi/domoticz/plugins/NUT_UPS/plugin.py, function onStart
2019-04-09 15:51:14.549 Error: (APC) ----> Line 89 in /home/pi/domoticz/plugins/NUT_UPS/plugin.py, function onStart
Can anybody explain me where is the problem?
It is probable that your UPS NUT implementation does not report power usage. The plugin will not create devices for variables that do not have values (as shown by your debug log).Skwi wrote: Saturday 20 April 2019 10:29 Hi, I have an eaton protection station 800 but I don't have all the devices created in domoticz, I'd like to see the power but it stays at None.
Is it normal the state is 'OL CHRG' while the charge is 100? (because offline ups?)
OOPS... I forgot to update the plugin repository with a version I worked on more than one year ago and that implemented access control: Version 0.2.2 is now available from Github and the wiki page has been updated accordingly !febalci wrote: Tuesday 07 May 2019 18:44 @logread,
I was using UPS Monitor plugin for some time, i have 1 APC UPS on domoticz ubuntu server, and 1 APC UPS on Synology 916+. It was working nicely for some months. All of a sudden the connection for the Synology UPS started "ACCESS_DENIED" error. Could be since i upgraded Synology firmware, it deleted some settings, who knows. Now i try to telnet port 3493 on Synology, it connects well, but "LIST VAR ups" gives Error: Access Denied. If i enter upsd.users details as as USERNAME monuser and PASSWORD xxxxx on telnet, then i can get LIST VAR ups response. Since you mentioned that we should not use username and password on NUT installation, i still couldn't found out how to use NUT without username and password. Any help?
Thanks...
