Dashticz - Module - Public Transport
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Public Transport
Post by robgeerts »
Added NMBS (Belgium) in latest beta! (Thanks to ericvb)
Try:
publictransport.mol={station:'Mol',title:'Station Mol',show_lastupdate:true,provider:'irailbe',icon:'train',interval:15,width:7,results:5};
Dlanor
Post by Dlanor »
Anyone a idea how get rid of the Lijn null?
var publictransport = {}
publictransport.ovinfotrain = { show_via: true, station: 'station-den-haag-ypenburg', title:'NS-Ypenburg', provider: '9292-train', show_lastupdate:true, icon: 'train', width: 5, results: 6 };
Domoticz| Zigbee | SONOFF
amauryverschooren
Post by amauryverschooren »
robgeerts wrote: Monday 15 May 2017 23:00 First of all, thanks to @ultrara1n who started to build this module just the way the calendar- and trashmodule is coded too :)
In latest beta it is possible to show the timetable of the public transport company VVS (Germany) AND NS (Netherlands) with live data.
VVS:
To call the function properly, you will need the correct station id from: https://efa-api.asw.io/api/v1/station/
So for Stuttgart Central Station the station id is 5006118
Then add this to config.js:
publictransport.hbf= { show_via: true, station: '5006118', title:'Trains', show_lastupdate:true, provider: 'VVS', icon: 'train', interval: 15, results: 5 };
9292.nl:
First get the station id from http://api.9292.nl/0.1/locations?lang=nl-NL&q=eindhoven
(Change eindhoven to your own search parameter).
Then copy the id!
//example station id: station-eindhoven
publictransport.ovinfo= { show_via: true, station: 'station-eindhoven', title:'OV Info', show_lastupdate:true, provider: '9292', icon: 'train', results: 5 };
publictransport.ovinfotrain= { show_via: true, station: 'station-eindhoven', title:'Bus', show_lastupdate:true, provider: '9292-bus', icon: 'bus', results: 5 };
publictransport.ovinfobus= { show_via: true, station: 'station-eindhoven', title:'Trein', show_lastupdate:true, provider: '9292-train', icon: 'train', results: 5 };
Mobiliteit.lu:
To call the function properly, you will need the correct station name, for example:
Luxembourg/Centre, Royal
publictransport.ovinfobus = { key:'ovinfobus', show_via: false, station: 'Luxembourg/Centre, Royal', provider: 'mobiliteit',title:'Royal Stop',show_lastupdate:true, icon: 'bus', width:6,  results: 4}
icon is simply font-awesome without fa, interval = time in seconds for refreshing the data, and results = number of shown results. Also possible is to customize the width, but i would not change the value of 12 because of the size of the output.
If anyone can provide JSON-output from other transport companies, please send me a message and I will add these!
hello Rob, is there also a version for in Belgium?
Recky
Domoticz version: Latest
Post by Recky »
I have a request. Could you add the option to show the balance of the (anonymous) OV card? I'll crosspost this to the official request threat also. Thanks!
https://www.ov-chipkaart.nl/saldo-terug ... hecker.htm#/
rolandbreedveld
Domoticz version: 2021.1
Post by rolandbreedveld »
Is it possible for publictransport.ovinfobus to filter on destination, half of the info is not relevant for me, while the bus is driving the wrong direction.
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
Jimster
Post by Jimster »
rolandbreedveld wrote: Friday 21 February 2020 17:56 Is it possible for publictransport.ovinfobus to filter on destination, half of the info is not relevant for me, while the bus is driving the wrong direction.
Yes, you can use destination: 'Name of destination' to filter the destinations.
See https://dashticz.readthedocs.io/en/mast ... sport.html
rolandbreedveld
@Jimster, thanxzzz,
I works partly, I can't get "Rotterdam Zuidplein" as destination, what do I wrong:
publictransport.ovinfobus = { show_via: false, station: 'hendrik-ido-ambacht/bushalte-de-heerlijkheid', destination: 'Ridderkerk,Rotterdam Zuidplein', provider: '9292-bus', width: 6, results: 5 };
"Ridderkerk" works! but "Rotterdam Zuidplein" not, if I do without destination, I get :
"12:41 +3 - Lijn 392 - Rotterdam Zuidplein"
Should expect it working, I tried "Rotterdam", "Zuidplein", "Rotterdam Bushalte Zuidplein", "rotterdam/bushalte-zuidplein", and more combinations, but no result
This comes from the api:
"id": "rotterdam/bushalte-zuidplein",
"type": "stop",
"stopType": "Bushalte",
"name": "Zuidplein",
"place": {
"name": "Rotterdam",
"regionCode": "ZH",
"regionName": "Zuid-Holland",
"showRegion": false,
"countryCode": "NL",
"countryName": "Nederland",
"showCountry": false
"latLong": {
"lat": 51.886946,
"long": 4.488258
"urls": {
"nl-NL": "/rotterdam/bushalte-zuidplein",
"en-GB": "/en/rotterdam/bushalte-zuidplein"
Jimster
Post by Jimster »
Problably is 'Rotterdam Zuidplein' not the full name of that destination. Set show_via to true to see the full name. Then you can use the full name.
rolandbreedveld
Jimster wrote: Saturday 22 February 2020 16:42 Problably is 'Rotterdam Zuidplein' not the full name of that destination. Set show_via to true to see the full name. Then you can use the full name.
Yes, thanxz that did the trick it was "Rotterdam Zuidplein via Lombardijen"
Omemanti
Post by Omemanti »
For a couple of weeks, my public transport as well as the garbage module stopped getting data.
it worked for months without a hassle. (I didn't update anything on domotics, only Linux updates)
anyone else got this issue?
Lokonli
Post by Lokonli »
Both modules make use of PHP functionality. Maybe one of the required PHP libraries is not installed correctly.
HansieNL
Post by HansieNL »
Publictransport block will not load at the moment. Only the message “Loading” is shown.
Are there more people with this error at this moment?
Blah blah blah
JeroenG
Domoticz version: 20231
Post by JeroenG »
Hansie,
same here for bus and train since few days.
Jimster
Post by Jimster »
HansieNL wrote: Thursday 06 January 2022 18:58 Publictransport block will not load at the moment. Only the message “Loading” is shown.
Yes, me too, seems like since the beginning of the year.
I think 9292 took their API down. The URL gives an 404 :(
I hope there is an alternative :roll:
Seems like everyone needs to request for access to their API:
https://9292.nl/zakelijk/9292-reisadvies-api
Maybe OvAPI is an alternative: https://github.com/skywave/KV78Turbo-OVAPI/wiki
Or NDOV https://ndovloket.nl/
Doudy
Post by Doudy »
To Robgeerts,
robgeerts wrote: Wednesday 02 May 2018 9:16 Added NMBS (Belgium) in latest beta! (Thanks to ericvb)
Try:
Is it possible to also provide information in French?
E.g.: spoor = voie
Bergen = Mons
Charleroi-Zuid = Charleroi-Sud
etc...
Thank you
Lokonli
Post by Lokonli »
Doudy wrote: Monday 21 February 2022 10:42 Hello,
To Robgeerts,
Try:
E.g.: spoor = voie
Bergen = Mons
etc...
Thank you
The irail.be API supports other languages as well (ne, en, de, fr)
It's not too difficult to add a language block parameter (which could get a default value derived from the Dashticz language setting).
Lokonli
Post by Lokonli »
To Robgeerts,
Try:
E.g.: spoor = voie
Bergen = Mons
etc...
Thank you
Implemented in latest beta (3.9.2)
Doudy
Post by Doudy »
Thank you. 'Spoor' is not translated!
Lokonli
Post by Lokonli »
Doudy wrote: Monday 28 February 2022 7:59 👍
Should work now...
(it will follow the Dashticz language setting, not the block parameter)
Beschuitje
Post by Beschuitje »
If not posted in the right topic, a request to the moderator to show me in the right direction?
Rediscovering Dashticz and setting up a new dashboard for the last couple of days. Using 3.10.1 beta.
Having problems however with the public tranport block. I am wrestling with it for a few days now but cannot get it solved.
Is there a problem perhaps with 'ovapi'?
I am getting "loading' result;
Lijn 53.png (34.8 KiB) Viewed 3121 times
blocks['ovapi'] = {
tpc: '09542',
title: 'Lijn 53 Diemen Zuid - Centraal Station',
show_lastupdate: true,
provider: 'ovapi',
show_via: true,
icon: 'fas fa-subway',
interval: '120',
newindow: '1',
results: 5,
width: 6
tpc code is for GVB lines 50 and 53 at station 'Diemen Zuid'
When i load 'treinen' for station Diemen Zuid it works perfectly.
Is this because ovapi is not working correct or am i doing something wrong?
