Dashticz - Module - Garbage collector Topic is solved
robgeerts
Domoticz version: 3.7067
Re: Dashticz - Module - Garbage collector
Post by robgeerts »
I tried, I thought it should work because it uses the same backend as some others but unfortunately, one of the addresses I have to use (http://afvalkalender.sudwestfryslan.nl/ ... n/8633KC-6) is disabled and redirects me to a 404-page...
Martijn85
Domoticz version: Stable
Post by Martijn85 »
robgeerts wrote:I tried, I thought it should work because it uses the same backend as some others but unfortunately, one of the addresses I have to use (http://afvalkalender.sudwestfryslan.nl/ ... n/8633KC-6) is disabled and redirects me to a 404-page...
To bad! Thanks for trying. I will take a look into it to, maybe i cant find how this site is working.
robgeerts
Post by robgeerts »
gielie wrote:I have different colours for the text corresponding to the afval, is it possible to change the color of the trashcan, corresponding to the trash of that week.
Try latest beta, the icon gets the color of the first upcoming type of trash that gets picked up
htilburgs
Post by htilburgs »
Do I need to configure something for this?
Hardware:
EdwinK
Post by EdwinK »
I see a grey-ish 'kliko' now. :)
htilburgs
Post by htilburgs »
Problem solved. I thought I had the latest beta, but there was a newer (1/2 hour later ;))
Now it's blue, because today is paper-day....
Hardware:
EdwinK
Post by EdwinK »
Rob keeps bringing new updates every hour it looks :)
HansieNL
Post by HansieNL »
EdKo66 wrote:Rob keeps bringing new updates every hour it looks :)
I hope he's going on holiday soon, so we have the time to update the wiki :lol:
Blah blah blah
EdwinK
Post by EdwinK »
Maybe then he will have more time to make cool stuff. Some 'pollen' warning.
robgeerts
Post by robgeerts »
Holiday is starting at september 10th... :(
There will be a lot of updates untill my holiday starts...
(Now back on topic ;))
htilburgs
Post by htilburgs »
LOL, I've made some modifications, but most of all I take notice of the changes so I can check later (when I 've time myself) if the wiki is up-to-date.
Hardware:
HansieNL
Post by HansieNL »
Is it possible to have a static trashcan with just one color? If not... maybe a variable possible on/off colored icons?
Blah blah blah
robgeerts
Post by robgeerts »
Try latest beta that I've just pushed to githubb and add in config.js:
var _DO_NOT_USE_COLORED_TRASHCAN = true;
jake
Re: RE: Re: Dashticz - Module - Garbage collector
Post by jake »
robgeerts wrote:Try latest beta that I've just pushed to githubb and add in config.js:
And the opposite, a colored trashcan and standard text color? The green color is s bit hard to read.
The text size is not updating with the other blocks when the custom.js is used. Can that please be connected
robgeerts
Post by robgeerts »
Then set it to false (or remove it) if you want only the colored bin.
If your text is colored, it is defined in your config ;)
Take a look at the piece of code where your trash is defined ;)
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
In my municipality, trash collection day is always Wednesday, for all kinds of trash.
Today, they collected GFT and PBD. Next week, it will be GFT only. In 2 weeks, GFT and Rest, in 3 weeks: GFT only, and in 4 weeks, the cycle repeats: GFT and PBD.
Now, my afvalapp block only shows GFT pick-up dates.
Are the Rest and PBD dates suppressed, because they coincide with the GFT dates? Can I change something, to correct this, or to filter out GFT, because I already know that they pick that up every week?
I did not set any custom names, trash icons and colours, so that is not causing this weird issue.
robgeerts
Post by robgeerts »
Could you send me your trash-config including zipcode?
So I can test with it..
jake
Post by jake »
robgeerts wrote:Then set it to false (or remove it) if you want only the colored bin.
Confusion was for me about the point that for colouring the text, I have to specify the colors (green / orange). The garbage bin option gets the colours by itself, because I now have commented out the green / orange lines and the bin icon has the green colour for GFT.
Regarding the difference in text size, the define text size in the custom.css is not obliged in the trashcan block
title{
    font-size:15px;
gielie
Domoticz version: latest β
Post by gielie »
@Rob, you're amazing, i didnt check the forum for half a day and there are a ton of new updates. Please stop, i cant keep up your pace. ;)
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
EdwinK
Post by EdwinK »
You know you have to check this forum at least once every 30 minutes. At least or you will miss important updates. :)
