Dashticz - Module - Garbage collector Topic is solved
robgeerts
- Domoticz version: 3.7067
Re: Dashticz - Module - Garbage collector
I tried, I thought it should work because it uses the same backend as some others but unfortunately, one of the addresses I have to use (http://afvalkalender.sudwestfryslan.nl/ ... n/8633KC-6) is disabled and redirects me to a 404-page...
Martijn85
- Domoticz version: Stable
To bad! Thanks for trying. I will take a look into it to, maybe i cant find how this site is working.robgeerts wrote:I tried, I thought it should work because it uses the same backend as some others but unfortunately, one of the addresses I have to use (http://afvalkalender.sudwestfryslan.nl/ ... n/8633KC-6) is disabled and redirects me to a 404-page...
robgeerts
Try latest beta, the icon gets the color of the first upcoming type of trash that gets picked upgielie wrote:I have different colours for the text corresponding to the afval, is it possible to change the color of the trashcan, corresponding to the trash of that week.
- htilburgs
Do I need to configure something for this?robgeerts wrote:Try latest beta, the icon gets the color of the first upcoming type of trash that gets picked upgielie wrote:I have different colours for the text corresponding to the afval, is it possible to change the color of the trashcan, corresponding to the trash of that week.
Hardware:
- EdwinK
- Domoticz version: BETA
I see a grey-ish 'kliko' now.
- htilburgs
Problem solved. I thought I had the latest beta, but there was a newer (1/2 hour laterhtilburgs wrote:Do I need to configure something for this?robgeerts wrote:Try latest beta, the icon gets the color of the first upcoming type of trash that gets picked upgielie wrote:I have different colours for the text corresponding to the afval, is it possible to change the color of the trashcan, corresponding to the trash of that week.
Now it's blue, because today is paper-day....
Hardware:
- EdwinK
Rob keeps bringing new updates every hour it looks
- HansieNL
I hope he's going on holiday soon, so we have the time to update the wikiEdKo66 wrote:Rob keeps bringing new updates every hour it looks
Blah blah blah
- EdwinK
Maybe then he will have more time to make cool stuff. Some 'pollen' warning.HansieNL wrote:I hope he's going on holiday soon, so we have the time to update the wikiEdKo66 wrote:Rob keeps bringing new updates every hour it looks
robgeerts
Holiday is starting at september 10th...
There will be a lot of updates untill my holiday starts...
(Now back on topic
(Now back on topic
- htilburgs
LOL, I've made some modifications, but most of all I take notice of the changes so I can check later (when I 've time myself) if the wiki is up-to-date.HansieNL wrote:I hope he's going on holiday soon, so we have the time to update the wikiEdKo66 wrote:Rob keeps bringing new updates every hour it looks
Hardware:
- HansieNL
Is it possible to have a static trashcan with just one color? If not... maybe a variable possible on/off colored icons?
Blah blah blah
robgeerts
Try latest beta that I've just pushed to githubb and add in config.js:
var _DO_NOT_USE_COLORED_TRASHCAN = true;
jake
Re: RE: Re: Dashticz - Module - Garbage collector
And the opposite, a colored trashcan and standard text color? The green color is s bit hard to read.robgeerts wrote:Try latest beta that I've just pushed to githubb and add in config.js:
The text size is not updating with the other blocks when the custom.js is used. Can that please be connected
robgeerts
Then set it to false (or remove it) if you want only the colored bin.
If your text is colored, it is defined in your config
Take a look at the piece of code where your trash is defined
niceandeasy
- Domoticz version: 3.8153
In my municipality, trash collection day is always Wednesday, for all kinds of trash.
Today, they collected GFT and PBD. Next week, it will be GFT only. In 2 weeks, GFT and Rest, in 3 weeks: GFT only, and in 4 weeks, the cycle repeats: GFT and PBD.
Now, my afvalapp block only shows GFT pick-up dates.
Are the Rest and PBD dates suppressed, because they coincide with the GFT dates? Can I change something, to correct this, or to filter out GFT, because I already know that they pick that up every week?
I did not set any custom names, trash icons and colours, so that is not causing this weird issue.
robgeerts
Could you send me your trash-config including zipcode?
So I can test with it..
jake
Confusion was for me about the point that for colouring the text, I have to specify the colors (green / orange). The garbage bin option gets the colours by itself, because I now have commented out the green / orange lines and the bin icon has the green colour for GFT.robgeerts wrote:Then set it to false (or remove it) if you want only the colored bin.
Regarding the difference in text size, the define text size in the custom.css is not obliged in the trashcan block
title{
font-size:15px;
}- gielie
- Domoticz version: latest β
@Rob, you're amazing, i didnt check the forum for half a day and there are a ton of new updates. Please stop, i cant keep up your pace.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- EdwinK
You know you have to check this forum at least once every 30 minutes. At least or you will miss important updates.
