Page 4 of 23
Re: Dashticz - Module - Calendar
Posted: Wednesday 10 May 2017 20:06
by HansieNL
alveman wrote:Now the calendar just saying "Loding..." any suggestions? I'm using iCloud calendar.
Martin
Have you tried without https://crossorigin.me/
Posted: Wednesday 10 May 2017 20:12
by robgeerts
Martin
This is handled automatically nowadays with the calendars ;)
Try:
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
and then in your columns:
columns[1]['blocks'] = [calendars.private]
But, I'm still working on the calendar-module.
Posted: Wednesday 10 May 2017 21:27
by alveman
robgeerts wrote:
Martin
Try:
var calendars = {}
Now I have tested this but no luck
//var _ICALENDAR_URL			= 'https://p02-calendarws.icloud.com/ca/subscribe/1/XXX';
//var _ICALENDAR_DATEFORMAT	= 'YYYY.MM.DD HH:mm';
//var _ICALENDAR_LOCALE		= 'en'; //en,hu, etc.
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'webcal://p02-calendarws.icloud.com/ca/subscribe/1/XXX' }
And changed the output block from 'icalendar' to calendars.private
Also tested both webcal:// and https:// but no difference same result. It's says "Loding..." for like 3 sec then emty. I can wait for the calendar-module ;) , keep up the good work!!
Martin
Posted: Wednesday 10 May 2017 22:26
by robgeerts
Could you share your calendar link (only for me, via pm) so I can test it?
(I dont care about your appointments so dont bother about that ;)
Posted: Wednesday 10 May 2017 22:44
by alveman
robgeerts wrote:Could you share your calendar link (only for me, via pm) so I can test it?
It seems to be a Internet Explorer "bug", just walked by my wallmounted iPad and there was the calendar :D and it seems to work in Chrome as well. (worked in IE before the update)
But the output looks lite random calendar objects from 2014 until now.
Martin
Posted: Thursday 11 May 2017 6:05
by poudenes
After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
I can share mine as well if you want to test it?
Posted: Thursday 11 May 2017 8:53
by robgeerts
Recurring will be fixed, meanwhile I fixed something in latest beta when multiple events are at the same day/time
Posted: Thursday 11 May 2017 11:06
by robgeerts
New version of the calendar module is available in BETA.
Please test, its not completely finished... 1 step at a time ;)
BACKUP YOUR CUSTOM.JS
Posted: Thursday 11 May 2017 11:18
by EdwinK
Going to check it out :)
Posted: Thursday 11 May 2017 12:38
by robgeerts
poudenes wrote:After latest update (beta) is see the items sorted correct. Only the repeated items are gone again.
Could you test recurring events in latest beta??
If not working, please pm me your calendar-url and date where recurring events should be..
Posted: Thursday 11 May 2017 14:10
by mvveelen
I tried the
maxitems: 5, ......
but that doesn't work (yet ?).
Also, I see some strange behaviour (see attachment): recurring events are shown multiple times, the date is displayed wrong, the times are...wrong.
Work in progress, right :) ?
Schermafbeelding 2017-05-11 om 14.09.55.png (282.37 KiB) Viewed 2353 times
Posted: Thursday 11 May 2017 14:24
by poudenes
robgeerts wrote:New version of the calendar module is available in BETA.
After latest update, It shows all repeated items somewhere in 2018. And the time is 1 hour later then actual in ical calendar.
And it shows 1 time item for next day (this one is for 12th may 2017)
Posted: Thursday 11 May 2017 23:00
by gielie
I have the calendar working fine only the days and months are in English, is it possible to show this in Dutch?
Posted: Thursday 11 May 2017 23:12
by robgeerts
"Da kenne we wel regelen"
I'm not at a pc right now but i thought there was a variable called '_CALENDAR_LOCALE' you can set to nl_NL in config.js
Posted: Thursday 11 May 2017 23:35
by mvveelen
Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
Posted: Thursday 11 May 2017 23:37
by robgeerts
Wich line?
Posted: Thursday 11 May 2017 23:39
by mvveelen
I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
Posted: Friday 12 May 2017 9:59
by EdwinK
mvveelen wrote:Eh....why does my calendar show these strange line then ? Using the latest beta (about 1 hour ago). Locale is set to NL, is this a bug or something with my setup (2 iCalendar's combined) ?
Can we have combined calendar's again?
Posted: Friday 12 May 2017 10:34
by robgeerts
mvveelen wrote:I mean lines....see this screenshot: https://www.domoticz.com/forum/viewtopi ... 84#p134107
Your calendar shows right at my dashboard, I have this var set in config.js:
var _ICALENDAR_DATEFORMAT	= 'DD.MM HH:mm';
What do you have set in this variable?
Combined calendars should work again.
Posted: Friday 12 May 2017 11:01
by EdwinK
Okay. Going to try them :)
When I use calendars.combined I get this error message:
Error combined calendars
Screen Shot 2017-05-12 at 11.03.48.png (34.22 KiB) Viewed 2222 times
Looks like this happens with the private calendar. So, when I got back from work, I will see if I can find out WHY.
