@pj-r,
pj-r wrote:Douh.. my TX-NR515 doesnt support that method or at least ISCP-V1.26_2013.xlsx file claims so.
Is there any alternative way?
In this plugin I use this information, as the input numbers and names differ a lot between models, it is the easiest way to create the devices with correct information. The plugin as it is currently programmed does not work without a proper NRI response from the receiver.
The plugin could be adapted to create the devices with all possible values, where the user could then delete unused inputs etc. I would then create a configuration option to indicate a receiver without NRI support is used.
I would give it a try with the current version, you never know, maybe it works. I see that there is a recent (2015) firmware on the onkyo website. As far as I can tell, the onkyo remote app, also uses the XML. So if that works, chances are that there is no issue and the XLS file is incorrect.
Regards,
Jorg
