[RELEASED] Python plugin to control Onkyo receivers
Re: [RELEASED] Python plugin to control Onkyo receivers
just tried some commands to be sure:
onkyo-script.py --host 192.168.1.5 system-power=on
returns...
<eISCP(TX-NR646) 192.168.1.5:60128> PWR01
<'system-power', 'on'>
(The device does turn on)
onkyo-script.py --discover
returns...
(nothing)
Hope this makes any sense. I'll try to find out why the discover function does not work, it's not a firewall thing.
to be continued, tnx
returns...
returns...
(nothing)
Could it have to do with 'enable new hardware' as well?
- jorgh
- Domoticz version: 3.8224
Not in this case, as the devices are created after receiving the Receiver configuration. As the discovery process fails, the Receiver is not even connected yet.jake wrote:Could it have to do with 'enable new hardware' as well?
Regards,
Jorg
It seems i'm not the only one: https://github.com/miracle2k/onkyo-eiscp/issues/59
I just installed python on a fresh windows pc and executed "onkyo-script.py --discover"
it returns:
File "C:\Python27\Scripts\onkyo-script.py", line 9, in <module>
load_entry_point('onkyo-eiscp==1.0', 'console_scripts', 'onkyo')()
File "C:\Python27\lib\site-packages\eiscp\script.py", line 134, in run
sys.exit(main() or 0)
File "C:\Python27\lib\site-packages\eiscp\script.py", line 50, in main
for receiver in eISCP.discover(timeout=1):
File "C:\Python27\lib\site-packages\eiscp\core.py", line 323, in discover
data, addr = sock.recvfrom(1024)
socket.error: [Errno 10054] An existing connection was forcibly closed by the remote host
Executing "onkyo-script.py --host 192.168.1.5 system-power:query"
Returns:
<eISCP(TX-NR646) 192.168.1.5:60128>: PWRQSTN
('system-power', 'standby')
it returns:
Returns:
- jorgh
@JimmyH1969,
I've installed Python on a windows machine and found out that windows does not supper the MSG_DONTWAIT flag.
So in my code the auto discover will definitely not work on Windows at this moment.
I'll change the code so this will work on Windows. But I don't yet know if this is the only issue. After I figure out a method that works on both Windows and Linux, I'll update the code in the bugfix branch.
Regards,
Jorg
Regards,
Jorg
- jorgh
@JimmyH1969,
I've made some changes that should make the autodiscover work on Windows. Have not tested it myself, as I don't have Domoticz running on a windows host. Verified the principle using a standalone script, so I'm confident the changes resolve the issue I found.
Don't know if that is the only issue that is keeping you from auto discovery, as apparently none of the existing scripts work on your install. Nevertheless, the changes are required on Windows.
The new code is currently in the bugfix branch: https://github.com/jorgh6/domoticz-onky ... ree/bugfix
Regards,
Jorg
Regards,
Jorg
Very, very nice.....
I updated the plugin remotely from work so i cant see the receivers responses, but it does detect the receiver and the devices are created.
Thank you for all the hard work and the great result ofcourse.
Can you explain what you changed to make discovery work?
Thanks again!
Regards, Jimmy
- jorgh
@Jimmy
I already did
https://github.com/jorgh6/domoticz-onky ... n/issues/6
https://github.com/jorgh6/domoticz-onky ... 14daeb8fa9
Regards,
Jorg
I already did
Regards,
Jorg
- Domoticz version: V3.8650
Douh.. my TX-NR515 doesnt support that method or at least ISCP-V1.26_2013.xlsx file claims so.jorgh wrote:The receiver configuration is requested using an NRIQSTN command. The response contains the receiver configuration in XML, that I use to create the devices.
Is there any alternative way?
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
- jorgh
@pj-r,
The plugin could be adapted to create the devices with all possible values, where the user could then delete unused inputs etc. I would then create a configuration option to indicate a receiver without NRI support is used.
I would give it a try with the current version, you never know, maybe it works. I see that there is a recent (2015) firmware on the onkyo website. As far as I can tell, the onkyo remote app, also uses the XML. So if that works, chances are that there is no issue and the XLS file is incorrect.
Regards,
Jorg
In this plugin I use this information, as the input numbers and names differ a lot between models, it is the easiest way to create the devices with correct information. The plugin as it is currently programmed does not work without a proper NRI response from the receiver.pj-r wrote:Douh.. my TX-NR515 doesnt support that method or at least ISCP-V1.26_2013.xlsx file claims so.
Regards,
Jorg
Sounds like its time for wireshark since the onkyo android app works fine.
I did try the NRIQSTN with this piece of python code and i always get timeout:
response is:
this "ValueError: Timeout waiting for response." is coming from the python lib.. https://github.com/miracle2k/onkyo-eisc ... re.py#L265
Other methods that are marked as supported in excel file are working just fine. And I have the latest firmware update installed.
For me it looks like this 515 doesnt really support NRI -> QSTN method. Let see what the wireshark has to say
import eiscp
receiver = eiscp.eISCP('192.168.1.10')
response = receiver.raw('NRIQSTN');
print response
receiver.disconnect()
pjr@pjr:~$ python testOnkyo.py
File "testOnkyo.py", line 10, in <module>
File "build/bdist.linux-armv7l/egg/eiscp/core.py", line 436, in raw
File "build/bdist.linux-armv7l/egg/eiscp/core.py", line 259, in filter_for_message
- Plaagje
- Domoticz version: Latest
Hi!jorgh wrote:Installation instructions:
Unzip the plugin.zip file and put plugin.py within a folder named 'Onkyo' in the Domoticz plugin folder.
On Linux make the file executable (chmod a+x plugin.py)
After you installed the plugin, restart Domoticz and add the Onkyo Receiver through the Setup->Hardware.
I did the above but i cant seem to find the onkyo receiver under Hardware...
Im running Domoticz V3.7041 on a Pi 2.
-Plaagje.
- jorgh
@Plaagje,
Did you create the Onkyo directory with a capital 'O'?
If not, try renaming the directory.
Do other plugins work (or at least show up in add-hardware)?
If not, it's probably a generic issue with plugins not working, and not something specific to this plugin.
Regards,
Jorg
Regards,
Jorg
- Plaagje
I added an other plugin and that one didnt load as well,,,, i suppose it is the plugin system.
The directory name does not matter. Any name will do as long as the files are readable by the user under which Domoticz runs. The files do not need to be executable, chmod +r is enough.
Verstuurd vanaf mijn XT1562 met Tapatalk
Has anyone this also working on a synolgy.
I have Python 2.7 running.
But when I do
I get an error
But when I do
python Onkyo-plugin.py --host 192.168.10.74 --discover
SyntaxError: Non-ASCII character '\xc3' in file Onkyo-plugin.py on line 569, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
Raspberry Pi (3x)
Master Domoticz installed on a Synology
RFXCOM RFXtrx433E USB
RFLink
USB Z-Wave Mini Adapter
Mi-light
QuinLED
Landis+Gyr ZME120ACd
Kamstrup_M401
USB-IR-Schreib-Lesekopf Alecto WS1700
Watermeter with TCRT5000
Kodi
DS18B20
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
You need python 3
- jorgh
@jossie67,
Regards,
Jorg
That is neither the plugin or command script posted in this thread.jossie67 wrote:Has anyone this also working on a synolgy.
But when I doI get an errorCode: Select all
Regards,
Jorg
Thanks that make sense!oohlaf wrote:You need python 3
I rename you python script "plugin.py" to 'Onkyo-plugin.py ,jorgh wrote:@jossie67,
Regards,
Jorg
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
Now I can run the python script, I'm only missing module named 'Domoticz'jossie67 wrote:Thanks that make sense!oohlaf wrote:You need python 3
Regards,
Jorg
Raspberry Pi (3x)
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
RFLink
Mi-light
QuinLED
Kamstrup_M401
Kodi
DS18B20
