Remeha eTwist
bwbboot
- Domoticz version: Latest
Re: Remeha eTwist
Yes you are correct, only a heat pump. Now working without error messages. Thanks!
bwbboot
Re: Remeha eTwist
I did some work on the plugin and added EnergyConsumption and EnergyDelivery counters.
Do need some help, since counters don't seem to show up. Can I have permission to upload as a branche? So you can have a look at the code?
Cheers!
Cheers!
Tuk90
Re: Remeha eTwist
I got it working but the total of today always shows the previous day as day total. See my previous post. You can do a pull request or something like that, that is the easiest I guess
- gizmocuz
Re: Remeha eTwist
My suggestion is to:
Fork the project to your own github repository
Check out this form
Do your changes
Commit the changes
Now when you go to your forked project, you should see a green button 'Create Pull Request' and you can create a pull request that Tuk90 can merge
If you need to make any changes before the merging, you can do so, and commit them, and the pull request with automatically be adjusted
Check out this form
Do your changes
Commit the changes
bwbboot
Re: Remeha eTwist
I have used code below to only pull today's data. Idea is to update the counter and display consumption/delivery so far.Tuk90 wrote: Saturday 27 January 2024 6:56 I got it working but the total of today always shows the previous day as day total. See my previous post. You can do a pull request or something like that, that is the easiest I guess
import datetime
try:
now = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S.%fZ")
startDay = datetime.datetime.now().strftime("%Y-%m-%d 00:00:00.0")
response = requests.get(
f'https://api.bdrthermea.net/Mobile/api/appliances/{applianceId}/energyconsumption/daily?startDate={startDay}&endDate={now}',
headers=headers
response.raise_for_status()
if response.status_code != 200:
Domoticz.Error(f"Error getting device states: {response.status_code}")
return None
response_json = response.json()
heatingEnergyConsumed = response_json["data"][0]["heatingEnergyConsumed"] / 1000
heatingEnergyDelivered = response_json["data"][0]["heatingEnergyDelivered"] / 1000
Tuk90
Re: Remeha eTwist
I have almost the say for the daily calculation, but now the question is how to properly put it in a device? Since if you use these daily values as the current power then it just adds everything up so if at the end of the day you have 20kw used then Domoticz will think the total is around 50ish.bwbboot wrote: Saturday 27 January 2024 12:45I have used code below to only pull today's data. Idea is to update the counter and display consumption/delivery so far.Tuk90 wrote: Saturday 27 January 2024 6:56 I got it working but the total of today always shows the previous day as day total. See my previous post. You can do a pull request or something like that, that is the easiest I guess
import datetime try: now = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S.%fZ") startDay = datetime.datetime.now().strftime("%Y-%m-%d 00:00:00.0") response = requests.get( f'https://api.bdrthermea.net/Mobile/api/appliances/{applianceId}/energyconsumption/daily?startDate={startDay}&endDate={now}', headers=headers ) response.raise_for_status() if response.status_code != 200: Domoticz.Error(f"Error getting device states: {response.status_code}") return None response_json = response.json() heatingEnergyConsumed = response_json["data"][0]["heatingEnergyConsumed"] / 1000 heatingEnergyDelivered = response_json["data"][0]["heatingEnergyDelivered"] / 1000
My current setup is that I am using a KWH device and I update this device with the following values: "kwh yearly summed up; kwh of today" but it seems that the yearly kwh consumption is only updated on the next day. So my usage of today is the usage of yesterday, any ideas on a better way to update the device?
Tuk90
Re: Remeha eTwist
I added a new branch: called energyconsumption, can you test that one? It is a bit behind on some parts from master so you should delete the dwhtemeperature device. If this is what you want I will update the code to make it a bit more cleaner and wil also add the generated part for you and push it to master but first I would like you to test itbwbboot wrote: Saturday 27 January 2024 12:45I have used code below to only pull today's data. Idea is to update the counter and display consumption/delivery so far.Tuk90 wrote: Saturday 27 January 2024 6:56 I got it working but the total of today always shows the previous day as day total. See my previous post. You can do a pull request or something like that, that is the easiest I guess
bwbboot
Re: Remeha eTwist
I am testing it. I did change the device type to Type=113 as it simply acts as a counter.
Domoticz.Device(Name=device_name_6, Unit=device_id_6, Type=113, TypeName="Kwh", Subtype=0, Used=1).Create()
- Screenshot 2024-01-28 at 19.18.31.png (115.87 KiB) Viewed 2729 times
- gizmocuz
Re: Remeha eTwist
Could this not be a generic kWh sensor instead of a counter?
Tuk90
Re: Remeha eTwist
It is a generic KWH, BWBoot adjusted it for himself
- gizmocuz
Re: Remeha eTwist
Question, since you do not have Gas, is it possible to post here your json output?
Here is mine: (i masked the id's)
Could you maybe add the 'gasCalorificValue' as custom sensor?
It is the amount of energy you can get from 1 m3 gas... would be interested to see if this is fluctuating....
'waterPressureOK' could also be interesting as a switch (on=ok, off = not ok), we could set a alarm/action on this
Maybe you can use some of the 'capability' fields to determine if certain values are available
'appliances': [
'applianceId': '1234',
'applianceOnline': True,
'applianceConnectionStatus': 'Connected',
'applianceType': 'Boiler',
'pairingStatus': 'Paired',
'houseName': 'Home',
'errorStatus': 'Running',
'activeThermalMode': 'HeatingCH',
'operatingMode': 'AutomaticHeating',
'outdoorTemperature': None,
'outdoorTemperatureSource': 'Unknown',
'outdoorTemperatureInformation': {
'internetOutdoorTemperature': None,
'applianceOutdoorTemperature': None,
'utilizeOutdoorTemperature': None,
'internetOutdoorTemperatureExpected': False,
'isDayTime': True,
'weatherCode': 'normal cloudy',
'cloudOutdoorTemperature': 5,
'cloudOutdoorTemperatureStatus': 'Ok'
'currentTimestamp': None,
'holidaySchedule': {
'startTime': '0001-01-01T00:00:00Z',
'endTime': '0001-01-01T00:00:00Z',
'active': False
'autoFillingMode': 'Disabled',
'autoFilling': {
'mode': 'Disabled',
'status': 'Standby'
'waterPressure': 1.7,
'waterPressureOK': True,
'capabilityEnergyConsumption': True,
'capabilityCooling': False,
'capabilityPreHeat': True,
'capabilityMultiSchedule': True,
'capabilityPowerSettings': False,
'capabilityOutdoorTemperature': False,
'capabilityUtilizeOutdoorTemperature': False,
'capabilityInternetOutdoorTemperatureExpected': False,
'hasOverwrittenActivityNames': True,
'gasCalorificValue': 8.7917,
'isActive': True,
'hotWaterZones': [
'hotWaterZoneId': '1234',
'name': 'DHW',
'zoneType': 'DHW',
'dhwZoneMode': 'Scheduling',
'dhwStatus': 'Idle',
'dhwType': 'Combi',
'nextSwitchActivity': 'Reduced',
'capabilityBoostMode': False,
'dhwTemperature': 52.1,
'targetSetpoint': 60.0,
'reducedSetpoint': 15.0,
'comfortSetPoint': 60.0,
'setPointMin': 40.0,
'setPointMax': 65.0,
'setPointRanges': {
'comfortSetpointMin': 40.0,
'comfortSetpointMax': 65.0,
'reducedSetpointMin': 10.0,
'reducedSetpointMax': 60.0
'boostDuration': None,
'boostModeEndTime': None,
'nextSwitchTime': '2024-01-29T21:00:00Z',
'activeDwhTimeProgramNumber': 1
'climateZones': [
'climateZoneId': '1234',
'name': 'CIRCA ',
'zoneIcon': 0,
'zoneType': 'CH',
'activeComfortDemand': 'ProducingHeat',
'zoneMode': 'Scheduling',
'controlStrategy': 'RoomTemperatureOnly',
'firePlaceModeActive': False,
'capabilityFirePlaceMode': True,
'roomTemperature': 21.0,
'setPoint': 21.0,
'nextSetpoint': 16.0,
'nextSwitchTime': '2024-01-29T17:00:00Z',
'setPointMin': 5.0,
'setPointMax': 30.0,
'currentScheduleSetPoint': 21.0,
'activeHeatingClimateTimeProgramNumber': 1,
'capabilityTemporaryOverrideEndTime': True,
'preHeat': {
'enabled': True,
'active': False
'temporaryOverride': {
bwbboot
Re: Remeha eTwist
Reason I made the experimental change is, that the heat pump only provides the kWh usage, not the W from which the kWh can be calculated.
In the screenshot from Tuk90 it shows a usage of 3000 Watt which isn't the actual usage as you would see with a power meter.
I would expect it to simply display the kWh value.
bwbboot
Re: Remeha eTwist
gizmocuz wrote: Monday 29 January 2024 8:53 Question, since you do not have Gas, is it possible to post here your json output?
"appliances":[
"applianceId":"1234",
"applianceOnline":true,
"applianceConnectionStatus":"Connected",
"applianceType":"HeatPump",
"pairingStatus":"Paired",
"houseName":"Home",
"errorStatus":"Running",
"activeThermalMode":"HeatingCH",
"operatingMode":"AutomaticHeating",
"outdoorTemperature":2.5,
"outdoorTemperatureSource":"Wired",
"outdoorTemperatureInformation":{
"internetOutdoorTemperature":"None",
"applianceOutdoorTemperature":2.5,
"utilizeOutdoorTemperature":"None",
"internetOutdoorTemperatureExpected":false,
"isDayTime":true,
"weatherCode":"Sunny",
"cloudOutdoorTemperature":3,
"cloudOutdoorTemperatureStatus":"Ok"
"currentTimestamp":"None",
"holidaySchedule":{
"startTime":"0001-01-01T00:00:00Z",
"endTime":"0001-01-01T00:00:00Z",
"active":false
"autoFillingMode":"NotAvailable",
"autoFilling":{
"mode":"NotAvailable",
"status":"NotAvailable"
"waterPressure":1.7,
"waterPressureOK":true,
"capabilityEnergyConsumption":true,
"capabilityCooling":false,
"capabilityPreHeat":true,
"capabilityMultiSchedule":true,
"capabilityPowerSettings":false,
"capabilityOutdoorTemperature":true,
"capabilityUtilizeOutdoorTemperature":false,
"capabilityInternetOutdoorTemperatureExpected":false,
"hasOverwrittenActivityNames":true,
"gasCalorificValue":0.0,
"isActive":true,
"hotWaterZones":[
"climateZones":[
"climateZoneId":"1234",
"name":"Zone1",
"zoneIcon":0,
"zoneType":"CH",
"activeComfortDemand":"ProducingHeat",
"zoneMode":"Scheduling",
"controlStrategy":"RoomTemperatureOnly",
"firePlaceModeActive":false,
"capabilityFirePlaceMode":true,
"roomTemperature":21.0,
"setPoint":21.0,
"nextSetpoint":21.0,
"nextSwitchTime":"2024-01-29T19:00:00Z",
"setPointMin":5.0,
"setPointMax":30.0,
"currentScheduleSetPoint":21.0,
"activeHeatingClimateTimeProgramNumber":1,
"capabilityTemporaryOverrideEndTime":true,
"preHeat":{
"enabled":false,
"active":false
"temporaryOverride":{
Tuk90
Re: Remeha eTwist
The type is easily discovered via applianceType. I have 'Heatpump' and you have boiler so that value can be used. But first I want to have this calculation done. I do not have a lot of time so I want to get things done before I do something new.gizmocuz wrote: Monday 29 January 2024 8:53 Question, since you do not have Gas, is it possible to post here your json output?
Could you maybe add the 'gasCalorificValue' as custom sensor?Code: Select all
{ 'appliances': [ { 'applianceId': '1234', 'applianceOnline': True, 'applianceConnectionStatus': 'Connected', 'applianceType': 'Boiler', 'pairingStatus': 'Paired', 'houseName': 'Home', 'errorStatus': 'Running', 'activeThermalMode': 'HeatingCH', 'operatingMode': 'AutomaticHeating', 'outdoorTemperature': None, 'outdoorTemperatureSource': 'Unknown', 'outdoorTemperatureInformation': { 'outdoorTemperatureSource': 'Unknown', 'internetOutdoorTemperature': None, 'applianceOutdoorTemperature': None, 'utilizeOutdoorTemperature': None, 'internetOutdoorTemperatureExpected': False, 'isDayTime': True, 'weatherCode': 'normal cloudy', 'cloudOutdoorTemperature': 5, 'cloudOutdoorTemperatureStatus': 'Ok' }, 'currentTimestamp': None, 'holidaySchedule': { 'startTime': '0001-01-01T00:00:00Z', 'endTime': '0001-01-01T00:00:00Z', 'active': False }, 'autoFillingMode': 'Disabled', 'autoFilling': { 'mode': 'Disabled', 'status': 'Standby' }, 'waterPressure': 1.7, 'waterPressureOK': True, 'capabilityEnergyConsumption': True, 'capabilityCooling': False, 'capabilityPreHeat': True, 'capabilityMultiSchedule': True, 'capabilityPowerSettings': False, 'capabilityOutdoorTemperature': False, 'capabilityUtilizeOutdoorTemperature': False, 'capabilityInternetOutdoorTemperatureExpected': False, 'hasOverwrittenActivityNames': True, 'gasCalorificValue': 8.7917, 'isActive': True, 'hotWaterZones': [ { 'hotWaterZoneId': '1234', 'applianceId': '1234', 'name': 'DHW', 'zoneType': 'DHW', 'dhwZoneMode': 'Scheduling', 'dhwStatus': 'Idle', 'dhwType': 'Combi', 'nextSwitchActivity': 'Reduced', 'capabilityBoostMode': False, 'dhwTemperature': 52.1, 'targetSetpoint': 60.0, 'reducedSetpoint': 15.0, 'comfortSetPoint': 60.0, 'setPointMin': 40.0, 'setPointMax': 65.0, 'setPointRanges': { 'comfortSetpointMin': 40.0, 'comfortSetpointMax': 65.0, 'reducedSetpointMin': 10.0, 'reducedSetpointMax': 60.0 }, 'boostDuration': None, 'boostModeEndTime': None, 'nextSwitchTime': '2024-01-29T21:00:00Z', 'activeDwhTimeProgramNumber': 1 } ], 'climateZones': [ { 'climateZoneId': '1234', 'applianceId': '1234', 'name': 'CIRCA ', 'zoneIcon': 0, 'zoneType': 'CH', 'activeComfortDemand': 'ProducingHeat', 'zoneMode': 'Scheduling', 'controlStrategy': 'RoomTemperatureOnly', 'firePlaceModeActive': False, 'capabilityFirePlaceMode': True, 'roomTemperature': 21.0, 'setPoint': 21.0, 'nextSetpoint': 16.0, 'nextSwitchTime': '2024-01-29T17:00:00Z', 'setPointMin': 5.0, 'setPointMax': 30.0, 'currentScheduleSetPoint': 21.0, 'activeHeatingClimateTimeProgramNumber': 1, 'capabilityCooling': False, 'capabilityTemporaryOverrideEndTime': True, 'preHeat': { 'enabled': True, 'active': False }, 'temporaryOverride': { 'endTime': '0001-01-01T00:00:00Z' } } ] } ] }
Maybe you can add an issue on github for eacht feature that you want so I have a to do list?
Tuk90
Re: Remeha eTwist
I merged it to main, sometimes there are difference between the total calculation and the usage of today, but that is because of the update interval of the API.bwbboot wrote: Monday 29 January 2024 9:23Reason I made the experimental change is, that the heat pump only provides the kWh usage, not the W from which the kWh can be calculated.
Tuk90
Re: Remeha eTwist
I added the gascalorificvalue, it is in the main branch. The waterPressureOK value will followgizmocuz wrote: Monday 29 January 2024 8:53 Question, since you do not have Gas, is it possible to post here your json output?
Tuk90
Re: Remeha eTwist
I also added the water pressure 'alarm' deviceTuk90 wrote: Saturday 03 February 2024 15:56I added the gascalorificvalue, it is in the main branch. The waterPressureOK value will followgizmocuz wrote: Monday 29 January 2024 8:53 Question, since you do not have Gas, is it possible to post here your json output?
hendrikenrenny
- Domoticz version: 2020.2
Re: Remeha eTwist
Great this plugin! I have been waiting for it since a long time.
Would it be possible in the next update to include the entry and back flow temperature (aanvoer en retour) of the heating? Those temperatures could help to optimize the heating.
Hendrik
Hendrik
