Page 4 of 4
Re: Confused about which device belong to which zwave-node
Posted: Friday 21 May 2021 7:40
by waaren
lost wrote: Friday 21 May 2021 7:25
Can't see how to put an image (needs an external URL) directly in the forum to show this, but that's what's happening.
You should see a tab with something like attachments. If you click that label you can add one or more (small sized) files. After adding you can place it / them inline
Posted: Friday 21 May 2021 18:55
by lost
- search.jpg (67.95 KiB) Viewed 546 times
- filter.jpg (43.9 KiB) Viewed 546 times
Here is the difference. Maybe something in the full pattern may explain this?
That's a bit bad on full image size, but copy/paste to gimp does this...
Posted: Friday 21 May 2021 19:08
by waaren
Sorry but from this last image I cannot see which hardware filters are available and which ones you picked (you can pick multiple)
I use the default windows snip tool (Windows + shift + S) and after saving use the good old ms-paint to add pointers and or select a part of he image before adding it to a forum post.
Posted: Saturday 22 May 2021 11:33
by lost
waaren wrote: Friday 21 May 2021 19:08
Selection was only on the zwave node 0x1C, same as the one used in search mode:
- search.jpg (75.36 KiB) Viewed 527 times
- filter.jpg (86.88 KiB) Viewed 527 times
These ones may be better (I'm Linux only, but found something better than GIMP for simple image editing as we have to use a intermediate file here, not just copy/pasting selection).
But, quite funny that 1st time this worked (all devices displayed in new filtered mode), second this was only showing 1 device as usual. So you may no see consistent re-creation of the issue???
Posted: Saturday 22 May 2021 12:29
by waaren
lost wrote: Saturday 22 May 2021 11:33
I understand now and see the same behavior on my system. The devices directly connected to the controller are not displayed when this filter is used.
I sent a comment about it to the developer who created this. Hopefully he can adjust the filter mechanism.
Posted: Saturday 22 May 2021 18:07
by lost
waaren wrote: Saturday 22 May 2021 12:29
What's strange is, sometimes, this works after unselect/select same node again:
- filter2.jpg (111.59 KiB) Viewed 507 times
Anyway, thanks for linking these observations to the developer of this long missing feature!
