Page 4 of 123
Posted: Sunday 18 December 2016 7:48
by corbin
I haven't added temp sensors yet, but will get them in.
Power plugs/sockets is also working, allowing you to control the plug from Domoticz.
Posted: Sunday 18 December 2016 7:51
by corbin
deennoo wrote:What do you mean by radio ? FM band ? Wifi band ?
The hub/gateway has a radio function, which plays Internet radio streams, not FM or WiFi. But it looks to be only Chinese stations available.
MP3 can be uploaded to use as the doorbell sound.
Posted: Sunday 18 December 2016 8:45
by deennoo
Ok ! Fm ! Lol!
Start thinking about switch and cube : a selector switch ! This allow 10 differentes value.
3 positions for switch :
Clik
Double click
Long click
For cube as many as the cube got (ordered one).
Posted: Sunday 18 December 2016 11:42
by Coldman
corbin wrote:I haven't added temp sensors yet, but will get them in.
There are two versions of power plugs, WiFi and ZigBee. How to add them?
Thanks for your great work.
Отправлено с моего MI PAD 2 через Tapatalk
Posted: Sunday 18 December 2016 12:21
by pavelbor
corbin wrote:Power plugs/sockets is also working, allowing you to control the plug from Domoticz.
I can see status of my ZigBee sockets, but can not control (switch on/off) them.
How can i do it?
Posted: Sunday 18 December 2016 12:24
by pavelbor
I added only ZigBee version of smart socket. WiFi is not visible (developer mode must be enabled somehow).
"Setup --> Devices --> Not used"
You have to manually switch on/off socket, then it will be visible in devices.
But at first step, you must add Xiaomi Gateway in "Setup --> Hardware"
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Posted: Sunday 18 December 2016 12:33
by Coldman
My power plugs are WiFi version, the Domoticz can't find them, I've ordered one ZigBee to test. Xiaomi Gateway added, others devices are working very well.
Thanks for your advice.
Posted: Sunday 18 December 2016 14:04
by arkoko
Good news, but how to use it?
I have added group scene, but on and off buttons didn't do nothing.
Posted: Sunday 18 December 2016 22:12
by corbin
I haven't published the code that allows control of the smart plugs yet - have a couple of other bits to finish.
You do need the Zigbee version of the plug, the WiFi plug will not work with Domoticz.
Posted: Monday 19 December 2016 8:10
by pavelbor
Because most of Xiaomi sensors (body, door/window, switch, temp/hum) are wireless, it very important to know, does battery is good yet.
Is it possible to get battery status info from sensors connected to Xiaomi Gateway as well ?
Posted: Tuesday 20 December 2016 7:10
by ERRORR2
corbin wrote:You do need the Zigbee version of the plug, the WiFi plug will not work with Domoticz.
I added my Gateway to Domoticz hardware, but can not see my ZigBee Socket in devices. Can you help me with it?
I tried to power off/on socket and gateway, but it doesn't help.
Developer mode and LAN access are enabled on Gateway.
Posted: Tuesday 20 December 2016 12:21
by corbin
pavelbor wrote:Because most of Xiaomi sensors (body, door/window, switch, temp/hum) are wireless, it very important to know, does battery is good yet.
There is supposed to be battery level reported from the sensors, but I have not seen it as yet from my sensors during testing.
Posted: Tuesday 20 December 2016 12:24
by corbin
Do you have other Xiaomi devices that it is finding? My next update sends a discovery message so that may help.
Posted: Tuesday 20 December 2016 12:43
by pavelbor
corbin wrote:My next update sends a discovery message so that may help.
Does it will be included in latest beta? So, i just need to update Domoticz beta?
Posted: Tuesday 20 December 2016 12:52
by corbin
It isn't in the beta just yet, code is working but I need to test it a bit more.
Posted: Tuesday 20 December 2016 12:58
by pavelbor
corbin wrote:It isn't in the beta just yet, code is working but I need to test it a bit more.
Good luck then
And please let us know, when something will be ready.
Posted: Tuesday 20 December 2016 13:04
by ERRORR2
No, I have only gateway, zigbee socket and temperature sensor and nothing is finding in devices. Waiting for update) Thanks for your great work!
Posted: Tuesday 20 December 2016 13:28
by pavelbor
I have ZigBee sockets too, but they are in list of devices. Probably you have to press on/off button to "activate" them.
Then they will be listed in "Not used" devices tab.
Posted: Wednesday 21 December 2016 5:34
by ERRORR2
Yes, I've tried that several times, but still no success
Posted: Wednesday 21 December 2016 11:20
by corbin
Can you compile the code at
https://github.com/corbinmunce/domoticz and see if it finds your devices?
