Panasonic TV Support
barrymossel
Re: Panasonic TV Support
Post by barrymossel »
It seems that when I turn off the TV by remote and later turn it on after a longer (?) time, Domoticz doesn't seem to register TV being turned on. A reboot of Domoticz makes it discover the TV again. Any idea why?
deejc
Domoticz version: 3.5641
Post by deejc »
my old panasonic TV worked well for a few years (3.5) but sadly died recently, panasonic replaced it with a new one (49FX750B) which unfortunately no longer responds to the plugin or curl.
i reinstalled the panasonic tv 2 app from play store and it needed to be paired to the TV with a pin so i suspect there is now some kind of authorisation happening before control is allowed, are there any workarounds or plans to implement something ?
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
RubenK
Post by RubenK »
I couldn't find anything concerning source code of the Panasonic TV plugin - so I'm posting this here. The plugin is great and works like a charm with my 50CX680 - there's only one little pickle I'm having with the plugin: it's hogging the log view. I've set the plugin to a poll interval of 60 seconds - and yet ... I get twelve logs every minute. I'd love to be wrong and overlooking something - but it seems like the polling action ignores the set interval.
2018-10-15 21:13:02.415 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:07.421 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:12.426 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:17.431 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:22.436 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:27.441 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:32.447 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:37.452 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:42.457 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:47.463 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:52.468 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
2018-10-15 21:13:57.473 Status: Panasonic Plugin: (PanasonicTV) Connected to '192.168.1.19:55000'.
deejc
Post by deejc »
This is why 2018 TV's don't work anymore
In regards to your query, I would like to inform you that our TV's only support Crestron and Control4 for IP commands, as JSON is not a supported feature.
Willmore
Post by Willmore »
I Didn't know that...so thanks
representative Speedypaper
moo2089
Domoticz version: 11804
Post by moo2089 »
hi,
when i put https://10.0.0.91:55000/json.htm?type=c ... =getvolume in browser address line, no answer is arrived, anyway pugin is ok, what could be wrong?
the aim is "setvolume", for predefined volume after automatic powering on tv set in morning
thx
moo2089
Post by moo2089 »
moo2089 wrote: Thursday 01 November 2018 23:59 hi,
thx
solved, need to use domoticz ip and port:"http://<domoticz_ip>:8080/json.htm?type=command&param=panasonicmediacommand&idx=44&action=VolumeUp" :lol: :lol: :lol:
arkoko
Post by arkoko »
RubenK wrote: Monday 15 October 2018 21:20it's hogging the log view. I've set the plugin to a poll interval of 60 seconds - and yet ... I get twelve logs every minute.
I have exactly the same problem. Log is flooding by this plugin every 5 seconds, no matter what is polling interval:
2019-01-15 13:12:55.123 Status: Panasonic Plugin: (TX-P42GT50E) Connected to '192.168.1.237:55000'.
2019-01-15 13:13:00.132 Status: Panasonic Plugin: (TX-P42GT50E) Connected to '192.168.1.237:55000'.
TheJuice
Post by TheJuice »
arkoko wrote: Tuesday 15 January 2019 12:15
Hi, same problem here...
Any solution ?
barry44
Domoticz version: 2023.1
Post by barry44 »
Hello
Same problem here.
My 2017 OLED tv was working great with panasonic plugin. But it had a problem, and have been replaced by support with a 2018 model, and now it's broken, with the same logs as messages before
mayyam
Domoticz version: 4.11333
Post by mayyam »
Me too.
2019-09-21 08:08:16.967 Status: Panasonic Plugin: (TX58DXE720) Connected to '192.168.12.19:55000'.
2019-09-21 08:08:21.982 Status: Panasonic Plugin: (TX58DXE720) Connected to '192.168.12.19:55000'.
2019-09-21 08:08:26.997 Status: Panasonic Plugin: (TX58DXE720) Connected to '192.168.12.19:55000'.
2019-09-21 08:08:32.012 Status: Panasonic Plugin: (TX58DXE720) Connected to '192.168.12.19:55000'.
2019-09-21 08:08:37.034 Status: Panasonic Plugin: (TX58DXE720) Connected to '192.168.12.19:55000'.
2019-09-21 08:08:42.049 Status: Panasonic Plugin: (TX58DXE720) Connected to '192.168.12.19:55000'.
Domoticz - Version: 4.11333
_______________
- Dell FX-160 / Ubuntu 16.04
- RFLink 433Mhz / NRF 2.4GHz
- 2x Xiaomi Gateway
- different species of ESP8266
grecof973
Post by grecof973 »
Does anyone know how to solve the problem of this Plug, even my Log is flooding by this plugin every 5 seconds.
Are there any solutions ??
grecof973
Post by grecof973 »
I still ask for help with this proplema, has anyone managed to solve the problem that the Registry is flooded with this Panasonic Plug-In ???
RedEarth
Post by RedEarth »
This is still a problem, I'd like to enable this plugin and use it, but the flooding of the logs with this 'Connected to...' entry is a real nuisance so I've had to disable the plugin.
I think a change was done several years ago to tidy up the logging on various plugins (maybe when the standard logging options on the hardware page changed?) to make it always log when it has successfully established a connection (e.g. when the TV is first switched on), however it looks like the way this plugin works is by polling the connection every x seconds to read the volume value etc. so if this is the case then I don't think it's necessary log this connection being established on every poll?
