Page 30 of 94
Posted: Thursday 28 January 2016 21:27
by npinguin
Hello
Is DSM 6 beta supported / can the package run on DSM 6 beta?
I have a rs815+
Nicky
Posted: Thursday 28 January 2016 23:54
by jumbotroll
npinguin wrote:Hello
I have a rs815+
Nicky
I don't think so, I have not updated to 6.0 beta yet.
Posted: Friday 29 January 2016 7:08
by mschut
I have a rs815+
Nicky
I am running the dsm 6 beta (beta 2 now). The synology package is jnstalled and working for me. Not using it however, due to something else.
Verstuurd vanaf mijn SM-G920F met Tapatalk
Posted: Friday 29 January 2016 13:02
by AxelvanH
Unfortunately it's not working on DSM 6 beta.
You can install it, but it won't run.
Logbook mentions:
/usr/local/domoticz/bin/domoticz: /lib/libstdc++.so.6: no version information available (required by /usr/local/domoticz/lib/libboost_system.so.1.59.0)
Posted: Friday 29 January 2016 13:56
by Gravityz
i installed the latyest 4346 version
everything seems to work but i ssse this error in the error tab
2016-01-29 13:36:22.287 Error: SQL Query("ALTER TABLE MobileDevices ADD COLUMN [Name] VARCHAR(100) DEFAULT ''") : duplicate column name: Name
i stopped domoticz and restarted again. no errors sofar but it is up to you if this is something to look at.
Posted: Friday 29 January 2016 16:23
by M4nu
Hi everyone,
First thank you for your work !
I have added the repositories urls (
http://packages.synocommunity.com/ and
http://www.jadahl.com/domoticz_stable/), but even after refreshing my DS414J can't find any update. It sticks to the 2.2112 version (after updating from the Domoticz ui).
Any clue ?
Thank in advance !
Posted: Friday 29 January 2016 23:18
by jumbotroll
Add:
http://www.jadahl.com/domoticz_beta/ in package center and allow any publisher, and you will have the latest build.
you can also manually download and install
http://www.jadahl.com/domoticz_beta/?arch=comcerto2k
Posted: Saturday 30 January 2016 10:14
by M4nu
Thank you it's working now !
There is a message which tell me that a version 3530 is available, I suppose I have to ignore it ?
Posted: Saturday 30 January 2016 10:34
by gizmocuz
Gravityz wrote:i installed the latyest 4346 version
You can ignore this error (will be fixed in next beta)
Posted: Saturday 30 January 2016 10:42
by M4nu
Ok ! Thank you !
Posted: Saturday 30 January 2016 18:11
by Stevanovich
I try to install it, but i get this message :
Need DSM 5.0-448 or more
Can i get it another way ?
Thank
Posted: Saturday 30 January 2016 20:40
by Egregius
You're still on DSM 4?
Posted: Saturday 30 January 2016 22:53
by AxelvanH
AxelvanH wrote:Unfortunately it's not working on DSM 6 beta.
Logbook mentions:
Does anybody know how to solve this?
Posted: Sunday 31 January 2016 15:31
by djksage
i use now domoticz on my synology ( HP n54l with xpenology ) , working perfectly with aeon labs z-stick gen5, thanks jumbotroll for your work
i would like test mysensor but usb gateway is recognised by domoticz installed on syno?
thanks for your information
Posted: Sunday 31 January 2016 15:47
by jumbotroll
djksage wrote:Hello,
I don't know if mysensor work. Not tested!
Maybe you need some drivers?
Posted: Sunday 31 January 2016 17:13
by djksage
Yes, i find this (in french)
Le module serialport n’a pas réussi à être installé sur Synology (npm exactement ne peut pas être installé)
the serialport can't be installed on synology (npm exactly can't installed)
i buy arduino for test
EDIT: the best way is buy a nodemcu for make a wifi gateway and this gateway is compatible with domoticz
Posted: Sunday 31 January 2016 20:23
by tobiasvdl
jumbotroll wrote:mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
No it's not supported in my build.
Hi Jumbotroll,
Do you have any plans to include support for the HGI80 in the synology package? Would be great to connect my evohome to domoticz (running on my synology).
Cheers,
Tobias
Posted: Sunday 31 January 2016 21:15
by jumbotroll
tobiasvdl wrote:jumbotroll wrote:mschut wrote:Just checking. Is the Evohome HGI-80 module supported within the Synology package? I am not able to see the module on my Synology. It isnt getting a usb port.
Hi Jumbotroll,
Cheers,
Tobias
Sorry I don't think so.
I have tried to implement this earlier , but Synology need drivers and do not download the firmware for HGI-80 automatically like Linux Ubuntu and Raspberry do. I do not have HGI-80 myself , so this makes it difficult to test.
Posted: Sunday 31 January 2016 21:53
by niki_lauda
Egregius wrote:You're still on DSM 4?
When you have a an "older" DS like me a DS209, you can't upgrade to dsm 5.
Synology supports the dsm 5 year after release off the diskstation.
Posted: Monday 01 February 2016 0:25
by jumbotroll
I have made a test build Domoticz stable v2.3530 for DS209+ DSM 4.3 (arch=ppc853x) and OpenZvave. (NOT TESTED!!)
Should also work on DSM 4.2.
http://www.jadahl.com/domoticz_stable/?arch=ppc853x
http://www.jadahl.com/domoticz_stable/p ... 3530-7.spk
