Page 30 of 114
Posted: Thursday 04 January 2018 18:32
by Tyturion
Madgeni wrote: Thursday 04 January 2018 18:08
Tyturion wrote: Thursday 04 January 2018 17:51
No, doesn't work, but thanks for trying.
Cheers,
Thomas
so if you curl https://yourhost:port/json.htm?type=command¶m=setkelvinlevel&idx=63&kelvin=50
does that not do anything?
I only get a positive response in the browser ({
"status" : "OK",
"title" : "Set Kelvin Level"
other that, nothing.
Posted: Thursday 04 January 2018 18:33
by Madgeni
and that device can alter its white temperature?
Posted: Thursday 04 January 2018 18:37
by gijsje
Madgeni wrote: Thursday 04 January 2018 18:13
gijsje wrote: Thursday 04 January 2018 17:58
I have tested again.
In the past if you say white it did change to warm white almost yellow to the max warm white of the mi light bulbs.
If i ask now for white they change to cold white.
If i ask for warm white the change to something in between warm and cold white
Is that good or bad? It sounds bad.
Good question.
I think it would be better to have the lights change to full warm white if you ask for white as that is the more natural color for the lights.
And if you ask for cold light that they change to cold light.
Or ask for warm white to get warm, if you askfor cold white you get cold white and if you ask white that it is in between warm and cold
Posted: Thursday 04 January 2018 18:40
by Madgeni
gijsje wrote: Thursday 04 January 2018 18:37
Good question.
so google interprets 'White' as 5000 Kelvin - which tells me they think of white as 'cold'.
I'll take another look, once i get more feedback
Posted: Thursday 04 January 2018 18:42
by Tyturion
Madgeni wrote: Thursday 04 January 2018 18:33
As far as I know there are various models on the market. Mine is an RGBW which is only capable of one white (warm white).
Posted: Thursday 04 January 2018 18:52
by alanlsmith
Tyturion wrote: Thursday 04 January 2018 18:42
I think the older models such as RGBW and RGBWW are only RGB and one temperature of white, warm or cool. They ignore the Set Kelvin command, hence my 'bodge' earlier. Newer lamps RGBDW have the ability to alter the colour temperature.
Of course there's also 'nightlight mode'.
Posted: Thursday 04 January 2018 19:16
by gijsje
Most of the light i have are 2700K to 6500K
Posted: Thursday 04 January 2018 21:16
by Madgeni
so why are you asking it to change the warmth of the white? i'm confused!
Posted: Thursday 04 January 2018 21:24
by alanlsmith
Madgeni wrote: Thursday 04 January 2018 21:16
I think what Tyturion means is not the ability to change the colour temperature but to set the lamps to their predetermined white. And like with my lamps, Google sends the Set Kelvin command, Domoticz accepts it but the MiLight control box just ignores it, so you can't change the lamp to white using Google at the moment. Unless you use a work around
Posted: Thursday 04 January 2018 23:07
by richardlane79
Hi Madgeni,
Please could I also be included in the beta? Controlicz is setup and registered with the email address with my forum username @gmail.com.
Thanks in advance
Richard
Posted: Thursday 04 January 2018 23:16
by HallezJB
Bonjour...
Lorsque l'on s'inscrit sur Controlicz... faut il mettre le même Email que celui inscrit dans google home ?? Car ca ne marche pas...
- 2018-01-04_231709.jpg (76.6 KiB) Viewed 2052 times
Posted: Friday 05 January 2018 8:53
by patatman
Hi Madgeni,
I've applied for the Beta some days ago but can't access it. In case u missed it, here's my e-mailadres i signed up with:
[email protected].
Also, is the source code from controlicz available somewhere? Couldn't find it on Github/Gitlab or on a forum post here.
Posted: Friday 05 January 2018 10:51
by Fasthook
Hi Madgeni,
Can I also apply for the Beta accesss? I registered Monday with e-mail address
[email protected] (this is my google acount)
Many thanks in advance!
David.
Posted: Friday 05 January 2018 11:09
by Tyturion
alanlsmith wrote: Thursday 04 January 2018 21:24
Alan is absolutely right here. My lamps only have got one white level just like Alans lamps. I'm going to implement the workaround for now.
@madgeni: have you done some changes to the code by any chance? Because Domoticz does not seem to display the "Set Kelvin Level" as switch state any longer...which would be needed for the workaround as described earlier by Alan.
Cheers,
Thomas
Posted: Friday 05 January 2018 11:22
by yanael
Hi i made my inscription.
[email protected]
But if dont know What i must do to connect Google Home
@Madgeni
Envoyé de mon MI NOTE LTE en utilisant Tapatalk
Posted: Friday 05 January 2018 13:14
by HallezJB
bonjour...
on va y arriver...
je viens de recréer un compte Controlicz avec mon Email de GoogleHome =
[email protected]
Ca me dit: Controlicz can connect to your Domoticz!
Merci de me renvoyer la version Béta pour Domoticz...
Posted: Friday 05 January 2018 13:43
by yanael
Ah ok alors je veux bien aussi cette version
Posted: Friday 05 January 2018 15:00
by alanlsmith
Tyturion wrote: Friday 05 January 2018 11:09
@Tyturion
Mine still show 'Set Kelvin Level' so I don't think there is any change but if there was it illustrates why I don't like workarounds and bodges as if there had been a change they would no longer work, just adding more complexity and possible confusion. Even though I suggested a workaround myself.
Posted: Friday 05 January 2018 17:25
by ketakwet
Hi, i have just created an account to controlicz
ketakwet[at]gmail[dot]com
thanks
Posted: Friday 05 January 2018 17:38
by gijsje
I am not able anymore to sync my devices.
Any issue with that at the moment??
