Page 30 of 48
Re: [REQUEST] Ikea Trådfri Gateway (smart lights hub controller) plugin?
Posted: Saturday 11 May 2019 1:10
by moroen
Varazir wrote: Friday 10 May 2019 22:48
moroen wrote: Friday 10 May 2019 21:56
Varazir wrote: Friday 10 May 2019 13:22
I get nothing when running that command, just a blank line
pi@zwave2:~/domoticz/IKEA-Tradfri $ python3 tradfri.tac
IKEA-tradfri COAP-adaptor version 0.8.8 started (command line)!
I have symlinked the folder into the plugin folder so domoticz can see it but it shouldn't matter when running this command.
The adapter is running and waiting for a connection from domoticz. What does the domoticz log show?
Regards,
M
I didn't get it I should enable the plugin well here is logs with debug
2019-05-10 22:49:15.522 (IKEA) Transport set to: 'TCP/IP', 172.0.0.1:1234.
The shell still shows nothing.
Are you sure you have entered the correct IP on the plugin-configuration page in domoticz? It should be the IP of the machine running the adapter. If the adapter is running on the same machine as domoticz, it's normally 127.0.0.1, yours is set to 172.0.0.1...
Regards,
M
Posted: Saturday 11 May 2019 7:41
by Varazir
moroen wrote:Varazir wrote: Friday 10 May 2019 22:48
Regards,
M
Regards,
M
Ya, I used default settings and in the haste didn't catch IP. Changed to 127 and it worked. Should have seen that when I was comparing the settings between my 2 installations.
Skickat från min Nokia 7 plus via Tapatalk
Posted: Sunday 12 May 2019 16:14
by Alessio78
moroen wrote: Tuesday 19 March 2019 23:42
Alessio78 wrote: Tuesday 19 March 2019 20:29
Hello, someone can helpme plz?
I run
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py 192.168.0.201 PSW
usage: configure.py [-h] {config,service} ...
configure.py: error: argument command: invalid choice: '192.168.0.201' (choose from 'config', 'service')
else if I run
pi@raspberrypi:~/domoticz/plugins/IKEA-Tradfri $ ./configure.py config 192.168.0.201 PSW
Error: Unable to import pytradfri. Please check your installation!
How I can proceed?
You're missing the pytradfri library. If you've installed it with pip3, make sure that you have only one python3 interpreter installed...
Regards,
M
Hello, I reinstalled pytradfti and python 3.5.3.
For pytradfri if I run
~/pytradfri $ python3 -i -m pytradfri IP_IKEA
I can control the lights and work correctly.
For python 3.5.3, if I run:
python
Python 3.4.2 (default, Feb 10 2019, 17:23:02)
[GCC 4.9.2] on linux
and if I run:
python3
Python 3.5.3 (default, May 12 2019, 02:51:00)
I've installed python 3.5.3:
update-alternatives --list python3
/usr/local/bin/python3
but I've also:
/usr/bin/python2.7
/usr/bin/python3.4
Do you think that the problem can be this? How I can resolve?
Thanks in advance!
Posted: Saturday 25 May 2019 21:23
by wolfguru
I bought Ikea Trådfri Gateway and lights and I'm trying to get it to run with Domoticz on Synology. I tried to follow the steps in the link (
https://github.com/moroen/IKEA-Tradfri-plugin) but it seems that it is for RaspPi only.
I can see some posts where people have succeeded to get it to run on Synology.
Anyone can help with a description on how to get it to work on Synology? I have DS218+ and it is not bootstrapped. Do I need to bootstrap it? I tried to get the docker image to work instead but then it could not run due to missing config.json file.
Please help.
Thanks.
Posted: Tuesday 28 May 2019 22:40
by wolfguru
Hi, is this a dead thread?
Posted: Wednesday 29 May 2019 0:04
by Alessio78
Alessio78 wrote:moroen wrote: Tuesday 19 March 2019 23:42
I run
else if I run
How I can proceed?
Regards,
M
python
and if I run:
python3
but I've also:
/usr/bin/python2.7
/usr/bin/python3.4
Thanks in advance!
Hello, after a full reinstall of SO with DietPi work correctly
Inviato dal mio ZUK Z2121 utilizzando Tapatalk
Posted: Wednesday 29 May 2019 15:07
by moroen
wolfguru wrote: Saturday 25 May 2019 21:23
Please help.
Thanks.
I just made a change to the Dokcerfiles in the repo, hopefully this resolves the missing ikeatradfri library and missing config.json. I know nothing about Synology, and can't help you there.
Regards,
M
Posted: Friday 07 June 2019 6:37
by schulpr
I have a lot of (dis)connections, more then once per minute. Is this normal behavior or is something wrong?
(Tradfri) Device has disconnected
(Tradfri) Connected successfully to: 127.0.0.1
I'm on the latest beta of Domoticz and de plugin.
Thanks in advance for the help!
Kind regards, Rob
Posted: Friday 07 June 2019 9:37
by Varazir
What's the best praxis on to update the plugin ?
Posted: Saturday 08 June 2019 0:45
by moroen
schulpr wrote: Friday 07 June 2019 6:37
Kind regards, Rob
It's not normal behavior, try running the adapter from the command line, and check for/post any errors...
Regards,
M
Posted: Saturday 08 June 2019 0:50
by moroen
Varazir wrote: Friday 07 June 2019 9:37
If your running the adapter as a service, I would recommend:
$ sudo systemctl stop domoticz.service
$ sudo systemctl stop ikea-tradfri.service
$ cd plugins/IKEA-Tradfri
$ git pull
$ sudo systemctl start ikea-tradfri.service
$ sudo systemctl start domoticz.service
After domoticz has restarted, you should take a look at the IKEA entry on the hardware page, and make sure that all fields still contains valid entries, just in case something has changed (though this should happen very rarely).
Regards,
M
Posted: Saturday 08 June 2019 11:06
by schulpr
Hi M,
Thanks for the reaction. It's alright now. I had a wrong user in the configure.py file.
Kind regards, Rob
Posted: Thursday 27 June 2019 23:37
by redfirebrooks
Again the plugin stopped to work.
I have this error :
2019-06-27 23:36:19.828 (IKEA TRADFRI) Failed to connect to IKEA tradfri COAP-adapter! Status: 111 Description: Connection refused
2019-06-27 23:36:19.828 (IKEA TRADFRI) Device has disconnected
but
pi@domoticz:~/domoticz/plugins/IKEA-Tradfri $ sudo systemctl status ikea-tradfri.service
● ikea-tradfri.service - IKEA Tradfri COAP-adapter
Loaded: loaded (/etc/systemd/system/ikea-tradfri.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2019-06-27 23:37:00 CEST; 2s ago
Main PID: 9504 (twistd)
CGroup: /system.slice/ikea-tradfri.service
└─9504 /usr/bin/python3 /usr/local/bin/twistd --nodaemon --rundir=/home/pi/domoticz/plugins/IKEA-Tradfri --pidfil
juin 27 23:37:00 domoticz systemd[1]: Started IKEA Tradfri COAP-adapter.
So what's wrong !?!
Posted: Saturday 29 June 2019 21:19
by moroen
redfirebrooks wrote: Thursday 27 June 2019 23:37
I have this error :
but
So what's wrong !?!
Try to generate a new ident/PSK-pair...
Regards,
M
Posted: Sunday 11 August 2019 10:43
by heggink
Recently, I am seeing twistd errors as follows:
[stderr#error] ERROR:root:Error in initGateway: Request timeout
Trying to generate a new keypair, I also get a timeout. The Ikea app connects fine, has no issued controlling devices and the bridge is pingable. power cycling the bridge and restarting the ikea-tradfri-pi service then makes it connect again.
Both pytradfri and twisted are upgraded to the latest version. Same with the tradfri plugin. I did notice that the hub firmware was recently upgraded to 1.10.1.
Thoughts?
H
Posted: Monday 12 August 2019 20:26
by moroen
heggink wrote: Sunday 11 August 2019 10:43
Thoughts?
H
So the adapter works after a restart, and then fails again? Intermittent network drops aren't handled all that well by the adapter. You might want to try switching to the (soon to be master) aiocoap-branch of the plugin, it handles intermittent network timeouts better than the the coap-client version.
Regards,
M
Posted: Thursday 15 August 2019 22:30
by moroen
It's been a long way coming, but the aiocoap (
https://github.com/chrysn/aiocoap) version of the adapter and plugin has finally been pushed to the master branch. The upgrade should be fairly trivial, but some intervention is required. Anyone who updates the plugin to this version is urged to take a look at the readme.
This version removes the dependency on the coap-client command line tool and should be more resilient against network timeouts. It has the same features as the old version. The old coap-client based plugin is still available in the coap-client branch. Any glaring bugs in the coap-client based version might be fixed, but no further features will be implemented, unless someone is willing to fork the plugin and maintain the old version.
Regards,
M
Posted: Sunday 18 August 2019 15:05
by peerkersezuuker
Hi moroen,
Thanks for the hard work.
Is there a nice way to update the plugin from the previous version (coap-client) to this one (aiocoap) ?
Peter
Posted: Sunday 18 August 2019 20:06
by moroen
peerkersezuuker wrote: Sunday 18 August 2019 15:05
Hi moroen,
Peter
Just follow the steps outlined in the readme. I'm not very good at writing instructions, so if anything is unclear, let me know and I'll try to explain it better...
Regards,
M
Posted: Wednesday 28 August 2019 10:31
by olleman
moroen wrote: Saturday 20 October 2018 18:23
Mambobuzzz wrote: Saturday 20 October 2018 18:11
Hi there,
is it worth installing on Windnows Domoticz? Is it stable?
I haven't used Windows for years, so I really don't know. I would guess it should work, at least if you create a docker image with the adapter.
Regards,
M
Somebody tried with windows? I've had my Domoticz installation on windows for years and it would be a major hassle to move to an RPi3 now...
