Are you sure you have entered the correct IP on the plugin-configuration page in domoticz? It should be the IP of the machine running the adapter. If the adapter is running on the same machine as domoticz, it's normally 127.0.0.1, yours is set to 172.0.0.1...Varazir wrote: Friday 10 May 2019 22:48moroen wrote: Friday 10 May 2019 21:56The adapter is running and waiting for a connection from domoticz. What does the domoticz log show?Varazir wrote: Friday 10 May 2019 13:22
I get nothing when running that command, just a blank line
I have symlinked the folder into the plugin folder so domoticz can see it but it shouldn't matter when running this command.Code: Select all
pi@zwave2:~/domoticz/IKEA-Tradfri $ python3 tradfri.tac IKEA-tradfri COAP-adaptor version 0.8.8 started (command line)!
Regards,
M
I didn't get it I should enable the plugin well here is logs with debugThe shell still shows nothing.Code: Select all
2019-05-10 22:49:15.522 (IKEA) Transport set to: 'TCP/IP', 172.0.0.1:1234.
Regards,
M
