Page 29 of 29
Re: How to install Domoticz on a Synology NAS
Posted: Sunday 11 October 2020 0:02
by waaren
eddieb wrote: Saturday 10 October 2020 14:31
python3 is installed thru DSM package
Seems that I have hit the same / similar problem om my test system on my Synology. I recently upgraded Python on that system and my plugin stopped working.
@Jadahl is this a known issue ?
Posted: Sunday 11 October 2020 7:42
by eddieb
waaren wrote: Sunday 11 October 2020 0:02
Thanks for confirming @waaren
Glad I am not the only one
Posted: Friday 23 October 2020 9:36
by Atis
Hello I downloading and installing new synology 1019+ with pyton package. Installing ok but the package center can't runing the installed package.
Posted: Friday 23 October 2020 9:40
by jumbotroll
Atis wrote: Friday 23 October 2020 9:36
And you did install the Python3 package from synology first?
Posted: Friday 23 October 2020 16:36
by Atis
jumbotroll wrote: Friday 23 October 2020 9:40
No python package installed because this python packge working whitout synology python package:
domoticz_apollolake-6.2_2020.2.12340-8
I try update this package.
Posted: Friday 23 October 2020 16:56
by jumbotroll
Atis wrote: Friday 23 October 2020 16:36
It’s rolled back in latest beta because it was reported a lot of bugs, så if you try to update to latest beta with python plugin you need the synology python 3 package again.
Posted: Friday 23 October 2020 17:32
by Atis
jumbotroll wrote: Friday 23 October 2020 16:56
Working. Thank you. Are you planning to support DSM 7?
Posted: Friday 23 October 2020 18:06
by jumbotroll
Atis wrote: Friday 23 October 2020 17:32
No.
Read info on my website:
http://www.jadahl.com
Posted: Friday 23 October 2020 18:13
by monfiston
jumbotroll wrote: Friday 23 October 2020 18:06
No.
Hello
it's too bad
how can we find a parade?
Posted: Friday 23 October 2020 18:26
by Atis
No.
This is not good news
Posted: Saturday 28 November 2020 9:37
by artstam
I have a synology 211+. What is the latest package i can install? I would like to run a python script to if possible.
tx for the help!
Thomas
Posted: Sunday 20 December 2020 18:02
by teo1966
No.
what is the reason ?
Posted: Saturday 06 February 2021 9:46
by teo1966
i see this now on his site
Domoticz for synology will no longer be updated by Jadahl.
There is a time for everything and I have been compiling domoticz for synology since 2015.
Now I see that it is becoming more difficult and more complicated to build these packages for synology.
Another solution might be to use the Docker, or switch to Raspberry Pi or similar device.
Thanks for now!
I do not reply to emails regarding domoticz.
Posted: Thursday 01 July 2021 19:43
by monfiston
bonjour
avec un nas ds115j comment faire pour continuer à utiliser domotics?
Posted: Friday 01 October 2021 17:20
by monfiston
Hello
has anyone tried to make domoticz work with version 7?
Posted: Friday 01 October 2021 21:46
by EddyG
Yes, use docker.
Posted: Friday 01 October 2021 22:10
by monfiston
Je ne peux pas nas ds 115j
Posted: Thursday 26 May 2022 9:44
by jvdsanden
Can somebody tell were I must save the script (.lua) on the Domoticz that has been installed on the Synology running 7.0. If I make the script in Domoticz then the LOG showes the following:
2022-05-26 09:33:38.789 Error: CLuaHandler: cannot open /volume1/@appdata/domoticz/scripts/lua_parsers/watermeter.lua: No such file or directory
2022-05-26 09:33:46.365 Error: EventSystem: in watermeter.lua: [string "-- Smart Gateways Watermeter Script ..."]:4: attempt to index a nil value (global 'request')
2022-05-26 09:33:48.918 Error: CLuaHandler: cannot open /volume1/@appdata/domoticz/scripts/lua_parsers/watermeter.lua: No such file or directory
2022-05-26 09:33:56.409 Error: EventSystem: in watermeter.lua: [string "-- Smart Gateways Watermeter Script ..."]:4: attempt to index a nil value (global 'request')
2022-05-26 09:33:59.057 Error: CLuaHandler: cannot open /volume1/@appdata/domoticz/scripts/lua_parsers/watermeter.lua: No such file or directory
2022-05-26 09:34:00.387 Error: EventSystem: in watermeter.lua: [string "-- Smart Gateways Watermeter Script ..."]:4: attempt to index a nil value (global 'request')
This script "watermeter.lua" is needed to read the watermeter via the Domoticz type: HTTP/HTTPS poller. (see dutch version of installing) on:
https://www.connectix.nl/watermeter-uit ... -domoticz/
Thanks...
