How to install Domoticz on a Synology NAS
Re: How to install Domoticz on a Synology NAS
eddieb wrote: Saturday 10 October 2020 14:31 python3 is installed thru DSM package
Seems that I have hit the same / similar problem om my test system on my Synology. I recently upgraded Python on that system and my plugin stopped working.
@Jadahl is this a known issue ?
eddieb
Post by eddieb »
waaren wrote: Sunday 11 October 2020 0:02
Thanks for confirming @waaren
Glad I am not the only one
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
Atis
Post by Atis »
Hello I downloading and installing new synology 1019+ with pyton package. Installing ok but the package center can't runing the installed package.
jumbotroll
Post by jumbotroll »
Atis wrote: Friday 23 October 2020 9:36 Hello I downloading and installing new synology 1019+ with pyton package. Installing ok but the package center can't runing the installed package.
And you did install the Python3 package from synology first?
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Atis
Post by Atis »
jumbotroll wrote: Friday 23 October 2020 9:40
No python package installed because this python packge working whitout synology python package:
domoticz_apollolake-6.2_2020.2.12340-8
I try update this package.
jumbotroll
Atis wrote: Friday 23 October 2020 16:36
It’s rolled back in latest beta because it was reported a lot of bugs, så if you try to update to latest beta with python plugin you need the synology python 3 package again.
Jumbotroll
Atis
Post by Atis »
jumbotroll wrote: Friday 23 October 2020 16:56
Working. Thank you. Are you planning to support DSM 7?
jumbotroll
Atis wrote: Friday 23 October 2020 17:32
No.
Read info on my website: http://www.jadahl.com
Jumbotroll
monfiston
Post by monfiston »
jumbotroll wrote: Friday 23 October 2020 18:06
No.
Hello
it's too bad
how can we find a parade?
Atis
Post by Atis »
No.
This is not good news :(
artstam
Post by artstam »
I have a synology 211+. What is the latest package i can install? I would like to run a python script to if possible.
tx for the help!
Thomas
teo1966
Domoticz version: 2025.1
Post by teo1966 »
No.
what is the reason ?
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye
teo1966
Post by teo1966 »
i see this now on his site
Domoticz for synology will no longer be updated by Jadahl.
There is a time for everything and I have been compiling domoticz for synology since 2015.
Now I see that it is becoming more difficult and more complicated to build these packages for synology.
Another solution might be to use the Docker, or switch to Raspberry Pi or similar device.
Thanks for now!
I do not reply to emails regarding domoticz.
Release: 11
Codename: bullseye
monfiston
Post by monfiston »
bonjour
avec un nas ds115j comment faire pour continuer à utiliser domotics?
monfiston
Post by monfiston »
Hello
has anyone tried to make domoticz work with version 7?
EddyG
Post by EddyG »
Yes, use docker.
monfiston
Post by monfiston »
Je ne peux pas nas ds 115j
jvdsanden
Domoticz version: 7.1-4255
Post by jvdsanden »
Can somebody tell were I must save the script (.lua) on the Domoticz that has been installed on the Synology running 7.0. If I make the script in Domoticz then the LOG showes the following:
2022-05-26 09:33:38.789 Error: CLuaHandler: cannot open /volume1/@appdata/domoticz/scripts/lua_parsers/watermeter.lua: No such file or directory
2022-05-26 09:33:46.365 Error: EventSystem: in watermeter.lua: [string "-- Smart Gateways Watermeter Script ..."]:4: attempt to index a nil value (global 'request')
2022-05-26 09:33:48.918 Error: CLuaHandler: cannot open /volume1/@appdata/domoticz/scripts/lua_parsers/watermeter.lua: No such file or directory
2022-05-26 09:33:56.409 Error: EventSystem: in watermeter.lua: [string "-- Smart Gateways Watermeter Script ..."]:4: attempt to index a nil value (global 'request')
2022-05-26 09:33:59.057 Error: CLuaHandler: cannot open /volume1/@appdata/domoticz/scripts/lua_parsers/watermeter.lua: No such file or directory
2022-05-26 09:34:00.387 Error: EventSystem: in watermeter.lua: [string "-- Smart Gateways Watermeter Script ..."]:4: attempt to index a nil value (global 'request')
This script "watermeter.lua" is needed to read the watermeter via the Domoticz type: HTTP/HTTPS poller. (see dutch version of installing) on:
https://www.connectix.nl/watermeter-uit ... -domoticz/
Thanks...
Users browsing this forum: cmisip and 1 guest
