Page 29 of 55
Re: [MyDomoAtHome] Support thread
Posted: Monday 18 April 2016 14:41
by lowca
Thx.,
I have some problems., mdah crash if i dont have any camera and room plan...
Maybe its something with my db..
Posted: Monday 18 April 2016 16:03
by epierre
sorry I've seen that, will fix that tonight.
in the meantime:
sudo apt-get install MyDomoAtHome=0.1.22
Posted: Monday 18 April 2016 21:44
by epierre
ok new version with standalone auth and auto to domoticz (thanks to spawnrider):
It works in a "key":"value" mode. Basic value is:
"app_name": "MyDomoAtHome",
"auth": null,
"domoticz": {
"ssl": false,
"host": "127.0.0.1",
"port": "8080",
"path": "/",
"auth": null,
"port": "3002",
"passcode": ""
- multi-instances: just change the app_name tag between instances
- change the MDAH port: change the basic (top level) port (here 3002)
- protected device code: change the passcode above
- access domoticz in ssl mode: change domoticz:port and ssl to true
- change domoticz host or port: do it on domoticz:host and domoticz.port
- add a login/pass to access MDAH:change top-level "auth": null to "auth": { "username": "admin", "password": "admin" },
- manage login/pass on domoticz, do the same in domoticz:path
Posted: Monday 18 April 2016 22:27
by lowca
Thx great work !
But in my system still crash without rooms ... (no camera ok)..
Posted: Monday 18 April 2016 23:21
by naitsirhc
Hi epierre,
Thanks for your answer.
Did the steps again and am pleased to say, it works (although the HTTPS part)
When I type https://****.no-ip.biz I can see my domoticz homepage.
Unfortunatly I don't get the part:
In the domoticz configuration add a section to redirect to the gateway such as this (change your ip below),
Do I have to add:
location /iss/ {
proxy_pass http://10.0.0.170:3001/;
acces_log /......
error_log /.....
(because I want to test without a password, I deleted
auth_basic "Access Restricted";
auth_basic_user_file "/etc/nginx/.htpasswd";)
in /etc/nginx/sites-available/domoticz?????
Do I have to delete the other location? (127.0.0.1)
and create a .htpasswd for both (using htpasswd from package apache2-utils => htpasswd -c .htaccess YOURusername YOURpasswd)
And how to create the .htpasswd?
Are these the only steps to go to connect Imperihome?
please tell me I'm very close :-)
Posted: Tuesday 19 April 2016 7:13
by epierre
From yesterday's version you don't need to make this step, just add (see here in section config.json https://github.com/empierre/MyDomoAtHome) :
"auth": "auth": { "username": "admin", "password": "admin" },
"domoticz": {
"ssl": false,
"port": "8080",
"path": "/",
"auth": null
"port": "3002",
"passcode": ""
change login/pass here ;-)
Posted: Tuesday 19 April 2016 10:07
by ahmedadelhosni
Hello all,
On last Friday I followed the wiki and after a lot of tries the Imperihome was working very well with Domoticz. I tried after all to follow the secure remote access but failed, and on Sunday I suddenly found the Application not working at all. After many tries I decided to create a new raspain jessie image !
Now I am following again the steps in the wiki in here https://www.domoticz.com/wiki/ImperiHome
I installed all required packages and restarted mydomoathome but still when I connet through the App i get this error :
Unnable to connect. Please check your parameters.
my Local API Base Url is : http://192.168.0.4:3002/
my /etc/mydomoathome/config.json
"auth": null,
"domoticz": {
"ssl": false,
"host": "192.168.0.4",
"port": "8080",
"path": "/",
"auth": null,
"port": "3002",
"passcode": ""
My domoticz.sh :
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Domoticz Home Automation System"
NAME=domoticz
USERNAME=pi
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
DAEMON=/home/$USERNAME/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
If I go to : http://192.168.0.4:8080/json.htm?type=d ... order=Name
I can find outputs in the browser
If I go to : http://192.168.0.4:8080/devices
I get Domoticz offline from the browser.
The Domoticz App itself is working well.
I am out of ideas !!
THanks.
Posted: Tuesday 19 April 2016 10:17
by epierre
@ahmedadelhosni sorry, an error in the example above corrected, please remove the extra coma withing the domoticz block:
"auth": null, <-- this one
also if it does not start, check /var/log/mydomoathome
Posted: Tuesday 19 April 2016 10:31
by ahmedadelhosni
epierre wrote:@ahmedadelhosni sorry, an error in the example above corrected, please remove the extra coma withing the domoticz block:
Great. At last it can see my device and the system is added.
Still there is problem in the app now. A pop up window says "MyDodoAtHome (ImperiHome Standard System) : iss : Could not get devices infos."
Also another pop up error window : Multiple local error for 'MyDomoAtHome' . Falling back to remote mode.
Still trying to debug
Thanks for the quick help
Posted: Tuesday 19 April 2016 10:36
by epierre
check the logs, there could be two processes running or ... this message is just saying the Imperihome application cannot connect the MDAH gateway
Posted: Tuesday 19 April 2016 10:42
by epierre
@naitsirhc what are you trying to make ? both ssl + login/pass ?
a full SSL for domoticz and MDAH could be:
access_log off;
 add_header Cache-Control public;
 server_tokens off;
 server  {
   include    /etc/nginx/proxy_params;
   listen 443 ssl;                                          #<== 443 is the default SSL port, change by another port if desired
   keepalive_timeout 70;
   server_name localhost (my_DDNS);      #<== here put domain names (without https://) separated by spaces
   ssl on;
   ssl_certificate             /etc/ssl/ca/server.crt;
   ssl_certificate_key         /etc/ssl/ca/server.key;
   ssl_client_certificate /etc/ssl/ca/ca.crt;
   ssl_verify_client on;
   add_header X-Frame-Options SAMEORIGIN;
   location / {
     proxy_pass http://(DOMOTICZ_IP):8080/;
     access_log /var/log/nginx/domoticz.access.log;
     error_log /var/log/nginx/domoticz.error.log;
location /iss/ {
    proxy_pass http://(MDAH_IP):3002/;
by ahmedadelhosni
Well I checked the mentioned path in usage.log
This is the output each time I reload the APP.
{"url":"http://192.168.0.4:8080/json.htm?type=devices&filter=utility&order=Name","headers":{"User-Agent":"request"},"level":"info","message":"","timestamp":"2016-04-19T08:41:59.359Z"}
{"level":"info","message":"Domoticz server: http://192.168.0.4:8080/json.htm","timestamp":"2016-04-19T08:42:03.846Z"}
{"level":"info","message":"Node version: 4.2.2","timestamp":"2016-04-19T08:42:03.870Z"}
{"level":"info","message":"MDAH version: MyDomoAtHome 0.1.27","timestamp":"2016-04-19T08:42:03.873Z"}
{"level":"info","message":"OS version: Linux linux 4.1.13-v7+","timestamp":"2016-04-19T08:42:03.877Z"}
{"level":"info","message":"Hostname: raspberrypi 192.168.0.4 in /var/www","timestamp":"2016-04-19T08:42:03.884Z"}
{"level":"info","message":"MDAH port: 3002","timestamp":"2016-04-19T08:42:03.929Z"}
Posted: Tuesday 19 April 2016 10:47
by epierre
ahmedadelhosni wrote:Well I checked the mentioned path in usage.log
looks fine, still connectivity issue ?
don't reload the app if this is the only message you get
Posted: Tuesday 19 April 2016 11:08
by ahmedadelhosni
Actually no devices are shown yet. Domoticz App can see devices well.
This for example works fine: http://192.168.0.4:8080/json.htm?type=c ... tchcmd=Off
   "status" : "OK",
   "title" : "SwitchLight"
These are the running processes:
pi@raspberrypi:~/domoticz $ ps aux | grep mydomo
www-data  1641  0.0  0.2   4596  2372 ?        Ss   11:05   0:00 /bin/bash /usr/share/mydomoathome/bin/mydomoathome
www-data  1644  2.7  3.1 123116 29452 ?        Sl   11:05   0:03 node /usr/local/bin/forever --minUptime 1000 --spinSleepTime 1000 --max-old-space-size=128 /usr/share/mydomoathome/app/mdah.js
www-data  1667  4.5  3.9 130452 37816 ?        Sl   11:05   0:04 /usr/bin/node /usr/share/mydomoathome/app/mdah.js
pi        1684  0.0  0.2   4260  1912 pts/0    S+   11:07   0:00 grep --color=auto mydomo
Posted: Tuesday 19 April 2016 11:11
by epierre
ahmedadelhosni wrote:Actually no devices are shown yet. Domoticz App can see devices well.
Can you access : http://192.168.0.4:3002/ if yes try the links in it to see devices
Posted: Tuesday 19 April 2016 11:14
by ahmedadelhosni
I can acess the link.
I can see results in http://192.168.0.4:8080/json.htm?type=devices
I can not reach this: http://192.168.0.4:3002/devices
Posted: Tuesday 19 April 2016 11:18
by epierre
@ahmedadelhosni what gives:
curl 'http://192.168.0.4:3002/devices'
anything in the logs ?
Posted: Tuesday 19 April 2016 14:49
by lowca
@epierre
mdah 0.1.27 no room in room plan = crash ...
/usr/share/mydomoathome/app/mdah.js:1608
With empty room work ok ., but maybe it's a problem also for other users.. :?:
Posted: Tuesday 19 April 2016 15:01
by epierre
@lowca thanks for reporting, I'll correct that ;-)
Posted: Tuesday 19 April 2016 22:56
by lowca
@epierre
0.1.28 rooms ok :) Thx ..
When installed on new system ., still problem with
"auth": null, <-- this one extra coma
