Page 29 of 33
Re: Python Plugin : Broadlink RM2 V4
Posted: Tuesday 04 June 2019 20:34
by Loky31
Good hint!!! Thanks!
I have used ihc app ( no the e-control... damned !) .
So I don't know how to find those files...
Is there any known method to do the same? If I install hte econtrol app do I have to start all over again to learn the codes and so on through this app?
Posted: Saturday 08 June 2019 23:33
by scriptkiddie
hello friends...is for the first time when i'm blocked.
I have a server from an old laptop with domoticz and another things...
Recently i buyed a BroadLink RM PRO i installed apk in android phone and it work on phine perfectly.
Now i want to connect with domoticz and i can do that...
i dont know what i need to do...
root@debian:/home/alex/domoticz/plugins/BroadlinkRM2# ls -a
. import plugin_http.py plugin.py __pycache__
.. ini plugin_http.sh plugin_send.py remote
root@debian:/home/alex/domoticz/plugins/BroadlinkRM2# pip3 list | grep pyaes
DEPRECATION: The default format will switch to columns in the future. You can ue --format=(legacy|columns) (or define a format=(legacy|columns) in your pip.cof under the [list] section) to disable this warning.
pyaes (1.6.1)
root@debian:/home/alex/domoticz/plugins/BroadlinkRM2# pip3 list | grep broadlink
DEPRECATION: The default format will switch to columns in the future. You can use --format=(legacy|columns) (or define a format=(legacy|columns) in your pip.conf under the [list] section) to disable this warning.
broadlink (0.11)
root@debian:/home/alex/domoticz/plugins/BroadlinkRM2# sudo pip3 show broadlink
Version: 0.11
Summary: Python API for controlling Broadlink IR controllers
Home-page: http://github.com/mjg59/python-broadlink
Author: Matthew Garrett
Author-email: [email protected]
License: UNKNOWN
Requires: cryptography, PyCRC
root@debian:/home/alex/domoticz/plugins/BroadlinkRM2# pip3 show pyaes
Version: 1.6.1
Summary: Pure-Python Implementation of the AES block-cipher and common modes ofoperation
Home-page: https://github.com/ricmoo/pyaes
Author: Richard Moore
License: License :: OSI Approved :: MIT License
Location: /usr/local/lib/python3.5/dist-packages/pyaes-1.6.1-py3.5.egg
Requires:
root@debian:/home/alex/domoticz/plugins/BroadlinkRM2# python --version
Python 3.5.3
on domoticz log i have...
2019-06-09 00:19:35.370 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:19:57.724 Status: Incoming connection from: 192.168.1.105
2019-06-09 00:20:00.314 Status: User: Admin initiated a switch command (18/central - Discovery/Off)
2019-06-09 00:20:00.469 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 00:20:00.495 (central) Processing 'onCommandCallback' message
2019-06-09 00:20:00.504 (central) Calling message handler 'onCommand'.
2019-06-09 00:20:00.505 (central) onCommand called for Unit 1: Parameter 'Off', Level: 0 , Connected : False
2019-06-09 00:20:00.524 (central - Discovery) Updating device from 1:'Found : 0 device(s)' to have values 0:'Off'.
2019-06-09 00:20:00.530 (central) Update 0:'Off' (central - Discovery)
2019-06-09 00:20:03.947 Status: User: Admin initiated a switch command (18/central - Discovery/On)
2019-06-09 00:20:03.948 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 00:20:03.989 (central) Processing 'onCommandCallback' message
2019-06-09 00:20:03.990 (central) Calling message handler 'onCommand'.
2019-06-09 00:20:03.990 (central) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2019-06-09 00:20:03.990 (central) All plugin system is on pause for 5s...
2019-06-09 00:20:09.082 (central) Found 0 broadlink devices
2019-06-09 00:20:09.082 (central - Discovery Info) Updating device from 1:'' to have values 1:''.
2019-06-09 00:20:09.089 (central) Update 1:'' (central - Discovery Info)
2019-06-09 00:20:09.089 (central - Discovery) Updating device from 0:'Off' to have values 1:'Found : 0 device(s)'.
2019-06-09 00:20:09.094 (central) Update 1:'Found : 0 device(s)' (central - Discovery)
2019-06-09 00:20:09.948 Status: User: Admin initiated a switch command (18/central - Discovery/On)
2019-06-09 00:20:09.949 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 00:20:09.997 (central) Processing 'onCommandCallback' message
2019-06-09 00:20:09.998 (central) Calling message handler 'onCommand'.
2019-06-09 00:20:09.998 (central) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2019-06-09 00:20:09.998 (central) All plugin system is on pause for 5s...
2019-06-09 00:20:10.095 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:20:15.004 (central) Found 0 broadlink devices
2019-06-09 00:20:15.005 (central - Discovery Info) Updating device from 1:'' to have values 1:''.
2019-06-09 00:20:15.010 (central) Update 1:'' (central - Discovery Info)
2019-06-09 00:20:15.010 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:20:15.010 (central) Calling message handler 'onHeartbeat'.
0 devices...
what i do wrong? the device is online it work ok with android phone...
i tried to make manually
2019-06-09 00:24:15.723 Status: (central) Stopping threads.
2019-06-09 00:24:15.723 Status: (central) Stopped.
2019-06-09 00:24:15.723 Status: (central) Started.
2019-06-09 00:24:16.373 Status: (central) Entering work loop.
2019-06-09 00:24:16.374 Status: (central) Initialized version 4.0.0, author 'zak45'
2019-06-09 00:24:16.376 (central) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2019-06-09 00:24:16.376 (central) Creating device 'Remote'.
2019-06-09 00:24:16.378 (central) 'Database':'/home/alex/domoticz/domoticz.db'
2019-06-09 00:24:16.378 (central) 'DomoticzBuildTime':'2019-05-09 14:04:08'
2019-06-09 00:24:16.378 (central) 'Version':'4.0.0'
2019-06-09 00:24:16.378 (central) 'Mode3':'RM2'
2019-06-09 00:24:16.378 (central) 'UserDataFolder':'/home/alex/domoticz/'
2019-06-09 00:24:16.378 (central) 'HomeFolder':'/home/alex/domoticz/plugins/BroadlinkRM2/'
2019-06-09 00:24:16.379 (central) 'Key':'BroadlinkRM2'
2019-06-09 00:24:16.379 (central) 'Mode4':'no'
2019-06-09 00:24:16.379 (central) 'Name':'central'
2019-06-09 00:24:16.379 (central) 'Language':'ro'
2019-06-09 00:24:16.379 (central) 'HardwareID':'8'
2019-06-09 00:24:16.379 (central) 'Mode5':'9000'
2019-06-09 00:24:16.379 (central) 'DomoticzVersion':'4.10717'
2019-06-09 00:24:16.379 (central) 'Mode1':'C8F74248623D'
2019-06-09 00:24:16.379 (central) 'DomoticzHash':'b38b49e5'
2019-06-09 00:24:16.379 (central) 'Author':'zak45'
2019-06-09 00:24:16.379 (central) 'Address':'192.168.1.120'
2019-06-09 00:24:16.379 (central) 'StartupFolder':'/home/alex/domoticz/'
2019-06-09 00:24:16.379 (central) 'Mode6':'Debug'
2019-06-09 00:24:16.379 (central) 'Mode2':'/tmp/ini'
2019-06-09 00:24:16.379 (central) 'Port':'0'
2019-06-09 00:24:16.380 (central) Device count: 3
2019-06-09 00:24:16.380 (central) Device: 1 - ID: 18, Name: 'central - Discovery', nValue: 0, sValue: 'Off'
2019-06-09 00:24:16.380 (central) Device ID: '18'
2019-06-09 00:24:16.380 (central) Device Name: 'central - Discovery'
2019-06-09 00:24:16.380 (central) Device nValue: 0
2019-06-09 00:24:16.380 (central) Device sValue: 'Off'
2019-06-09 00:24:16.380 (central) Device LastLevel: 0
2019-06-09 00:24:16.380 (central) Device: 2 - ID: 19, Name: 'central - Discovery Info', nValue: 1, sValue: ''
2019-06-09 00:24:16.380 (central) Device ID: '19'
2019-06-09 00:24:16.380 (central) Device Name: 'central - Discovery Info'
2019-06-09 00:24:16.380 (central) Device nValue: 1
2019-06-09 00:24:16.380 (central) Device sValue: ''
2019-06-09 00:24:16.380 (central) Device: 254 - ID: 20, Name: 'central - Remote', nValue: 0, sValue: ''
2019-06-09 00:24:16.380 (central) Device ID: '20'
2019-06-09 00:24:16.381 (central) Device Name: 'central - Remote'
2019-06-09 00:24:16.381 (central) Device nValue: 0
2019-06-09 00:24:16.381 (central) Device sValue: ''
2019-06-09 00:24:16.381 (central) Device LastLevel: 0
2019-06-09 00:24:16.381 (central) Pushing 'PollIntervalDirective' on to queue
2019-06-09 00:24:16.381 (central) Connecting to: 192.168.1.120:C8F74248623D
2019-06-09 00:24:16.381 Error: (central) Error Connecting to Broadlink device....192.168.1.120
2019-06-09 00:24:16.391 (central) No ini file :/tmp/ini/remote/plugin_remote_8.ini
2019-06-09 00:24:16.391 (central) Custom Commands for Remote not managed
2019-06-09 00:24:16.391 (central) Device Number begin to : 2
2019-06-09 00:24:16.391 (central) Processing 'PollIntervalDirective' message
2019-06-09 00:24:16.391 (central) Heartbeat interval set to: 30.
2019-06-09 00:24:25.035 Status: User: Admin initiated a switch command (20/central - Remote/On)
2019-06-09 00:24:25.036 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 00:24:25.072 (central) Processing 'onCommandCallback' message
2019-06-09 00:24:25.072 (central) Calling message handler 'onCommand'.
2019-06-09 00:24:25.072 (central) onCommand called for Unit 254: Parameter 'On', Level: 0 , Connected : False
2019-06-09 00:24:25.072 (central) Generate on Command for learned code stored on unit/ini :254
2019-06-09 00:24:25.072 Error: (central) ini file not found: /tmp/ini/BroadlinkRM2-8-254.ini
2019-06-09 00:24:26.376 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:24:26.426 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:24:26.426 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:24:56.384 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:24:56.418 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:24:56.418 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:25:26.392 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:25:26.404 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:25:26.404 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:25:26.405 Error: (central) Error getting temperature data from Broadlink device....Timeout
2019-06-09 00:25:26.405 Error: (central) Error Connecting to Broadlink device....192.168.1.120
2019-06-09 00:25:56.400 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:25:56.441 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:25:56.442 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:26:26.408 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:26:26.435 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:26:26.435 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:26:56.419 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:26:56.428 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:26:56.428 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:27:26.428 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:27:26.464 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:27:26.464 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:27:56.436 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:27:56.450 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:27:56.450 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:28:26.444 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:28:26.489 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:28:26.489 (central) Calling message handler 'onHeartbeat'.
2019-06-09 00:29:49.677 Status: User: Admin initiated a switch command (18/central - Discovery/On)
2019-06-09 00:29:49.678 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 00:29:49.682 (central) Processing 'onCommandCallback' message
2019-06-09 00:29:49.682 (central) Calling message handler 'onCommand'.
2019-06-09 00:29:49.682 (central) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2019-06-09 00:29:49.682 (central) Generate on Command for learned code stored on unit/ini :1
2019-06-09 00:29:49.682 Error: (central) ini file not found: /tmp/ini/BroadlinkRM2-8-1.ini
2019-06-09 00:29:56.469 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 00:29:56.501 (central) Processing 'onHeartbeatCallback' message
2019-06-09 00:29:56.502 (central) Calling message handler 'onHeartbeat'.
anny ideea?
Posted: Sunday 09 June 2019 17:05
by zak45
scriptkiddie wrote: Saturday 08 June 2019 23:33
'/tmp/ini'
anny ideea?
first, update your release, actual one is 4.2.0, plugin.py can be found on dropbox
second, verify that your ip/mac are the rights one, need to be the one of your Broadlink device
third, as advice, not really good idea to put ini files on temporary folder, but that's up to you;
Posted: Sunday 09 June 2019 21:21
by scriptkiddie
I updated...
2019-06-09 21:58:34.081 Status: (central) Initialized version 4.2.0, author 'zak45'
2019-06-09 22:01:39.828 Status: (central) Initialized version 4.2.0, author 'zak45'
2019-06-09 22:04:24.872 Status: (central) Initialized version 4.2.0, author 'zak45'
2019-06-09 22:11:34.252 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:12:04.250 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:12:04.298 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:12:04.298 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:12:34.259 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:12:34.291 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:12:34.292 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:13:04.267 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:13:04.282 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:13:04.282 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:13:34.276 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:13:34.318 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:13:34.318 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:13:55.145 Status: User: Admin initiated a switch command (20/central - Remote/On)
2019-06-09 22:13:55.145 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 22:13:55.180 (central) Processing 'onCommandCallback' message
2019-06-09 22:13:55.181 (central) Calling message handler 'onCommand'.
2019-06-09 22:13:55.181 (central) onCommand called for Unit 254: Parameter 'On', Level: 0 , Connected : False
2019-06-09 22:13:55.181 (central) Generate on Command for learned code stored on unit/ini :254
2019-06-09 22:13:55.181 Error: (central) ini file not found: /tmp/ini/BroadlinkRM2-8-254.ini
2019-06-09 22:14:04.284 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:14:04.308 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:14:04.308 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:14:08.620 Status: User: Admin initiated a switch command (18/central - Discovery/On)
2019-06-09 22:14:08.621 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 22:14:08.671 (central) Processing 'onCommandCallback' message
2019-06-09 22:14:08.672 (central) Calling message handler 'onCommand'.
2019-06-09 22:14:08.672 (central) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2019-06-09 22:14:08.672 (central) Generate on Command for learned code stored on unit/ini :1
2019-06-09 22:14:08.672 Error: (central) ini file not found: /tmp/ini/BroadlinkRM2-8-1.ini
root@debian:/tmp/ini# tail -50 /tmp/domoticz.txt
2019-06-09 22:18:04.373 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:18:34.362 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:18:34.363 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:18:34.364 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:19:04.371 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:19:04.406 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:19:04.407 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:19:34.380 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:19:34.406 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:19:34.406 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:20:04.391 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:20:04.397 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:20:04.397 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:20:04.466 (central) Connected to Broadlink device: 192.168.1.120
2019-06-09 22:20:34.400 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:20:34.415 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:20:34.416 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:21:04.409 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:21:04.412 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:21:04.412 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:21:34.418 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:21:34.449 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:21:34.450 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:21:52.901 Status: User: Admin initiated a switch command (20/central - Remote/On)
2019-06-09 22:21:52.902 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 22:21:52.905 (central) Processing 'onCommandCallback' message
2019-06-09 22:21:52.905 (central) Calling message handler 'onCommand'.
2019-06-09 22:21:52.905 (central) onCommand called for Unit 254: Parameter 'On', Level: 0 , Connected : True
2019-06-09 22:21:52.905 (central) Generate on Command for learned code stored on unit/ini :254
2019-06-09 22:21:52.906 Error: (central) ini file not found: /tmp/ini/BroadlinkRM2-8-254.ini
2019-06-09 22:21:58.052 Status: User: Admin initiated a switch command (18/central - Discovery/Off)
2019-06-09 22:21:58.053 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 22:21:58.072 (central) Processing 'onCommandCallback' message
2019-06-09 22:21:58.072 (central) Calling message handler 'onCommand'.
2019-06-09 22:21:58.072 (central) onCommand called for Unit 1: Parameter 'Off', Level: 0 , Connected : True
2019-06-09 22:21:58.073 (central - Discovery) Updating device from 1:'10' to have values 0:'Off'.
2019-06-09 22:21:58.079 (central) Update 0:'Off' (central - Discovery)
2019-06-09 22:22:00.742 Status: User: Admin initiated a switch command (18/central - Discovery/On)
2019-06-09 22:22:00.743 (central) Pushing 'onCommandCallback' on to queue
2019-06-09 22:22:00.744 (central) Processing 'onCommandCallback' message
2019-06-09 22:22:00.744 (central) Calling message handler 'onCommand'.
2019-06-09 22:22:00.744 (central) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : True
2019-06-09 22:22:00.745 (central) Generate on Command for learned code stored on unit/ini :1
2019-06-09 22:22:00.745 Error: (central) ini file not found: /tmp/ini/BroadlinkRM2-8-1.ini
2019-06-09 22:22:04.427 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:22:04.457 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:22:04.457 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:22:34.435 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:22:34.447 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:22:34.447 (central) Calling message handler 'onHeartbeat'.
ip and mac
i put in tmp because i think he don't have rights but i maked chmod 755 ...
update ...
i don't do anything and he modify in this...
2019-06-09 22:25:04.477 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:25:04.501 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:25:04.501 (central) Calling message handler 'onHeartbeat'.
2019-06-09 22:25:04.565 (central) Connected to Broadlink device: 192.168.1.120
2019-06-09 22:25:04.565 (central - Discovery) Updating device from 0:'Off' to have values 1:'10'.
2019-06-09 22:25:04.572 (central) Update 1:'10' (central - Discovery)
2019-06-09 22:25:34.485 (central) Pushing 'onHeartbeatCallback' on to queue
2019-06-09 22:25:34.510 (central) Processing 'onHeartbeatCallback' message
2019-06-09 22:25:34.510 (central) Calling message handler 'onHeartbeat'.
what i need to do?
Posted: Wednesday 12 June 2019 21:38
by scriptkiddie
nobody?
Posted: Thursday 13 June 2019 22:46
by zak45
try to remove devices and reload the plugin.
Posted: Saturday 15 June 2019 16:32
by Loky31
Hello again all,
So I gave a try with the e-control app, adding some RF commands for a switch and then share through the app, copy paste the JSON files into the domoticz RM2 pluggin directory and finally get the same error :
2019-06-15 16:31:45.140 Error: (RM salon) 'onCommand' failed 'FileNotFoundError'.
2019-06-15 16:31:45.141 Error: (RM salon) ----> Line 265 in '/home/pi/domoticz/plugins/BroadlinkRM2/plugin.py', function onCommand
2019-06-15 16:31:45.141 Error: (RM salon) ----> Line 825 in '/home/pi/domoticz/plugins/BroadlinkRM2/plugin.py', function createIniImport
Is this only working for IR commands or RF commands are also took into account?
That's my last guess as a reason for this not to work...
Edit :
I've tried to use the getBroadlinkSharedData.py but ended with that:
pi@raspberrypi:~/domoticz/plugins/BroadlinkRM2 $ python getBroadlinkSharedData.p y
File "getBroadlinkSharedData.py", line 20, in <module>
import simplejson as json
ImportError: No module named simplejson
So I did install the simplejson and get again orginial file true mozilla and now my web server is back to the 127 error with access right...
/suicide!
Posted: Thursday 20 June 2019 16:09
by Flappie
Tried to install the Broadlink RM2 V4 plugin on my Raspberry Pi:
copied the files "plugin_send.py" , "plugin_http.sh", "plugin_http.py" and "plugin.py" to /home/pi/domoticz/plugins/BroadlinkRM2/
Then installed the required modules:
sudo apt install python-pip
sudo pip3 install pyaes
sudo pip3 install broadlink
Last commmand fails with this errors:
Failed building wheel for cffi
and
Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-5omen2nv/cffi/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-cmn1bjq2-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-5omen2nv/cffi/
Posted: Thursday 20 June 2019 16:26
by Flappie
Flappie wrote: Thursday 20 June 2019 16:09
and
Already fixed it with:
sudo apt-get install libffi-dev libssl-dev
Posted: Thursday 20 June 2019 18:01
by Loky31
Flappie wrote: Thursday 20 June 2019 16:26
and
Is the pluggin working well for you then? I mean web import and so on?
Posted: Saturday 29 June 2019 14:18
by Flappie
Okey, received my RM3 Mini today. Installed the app and connected it to the network.
The plugin however, isn't working!
It keeps saying:
2019-06-29 14:16:33.595 Error: (Broadlink RM3 Mini) ini file not found: /home/pi/domoticz/plugins/BroadlinkRM2/BroadlinkRM2-17-254.ini
The file BroadlinkRM2-17-254.ini doesn't exists and is not auto created?
Do i need to create it manualy ?
When i press the "learn" button, the light on de the broadlink is on, so it looks like it does something
Posted: Monday 01 July 2019 8:20
by EddyG
The plugin works fine in my setup on a Raspberry Pi 3B+
BUT: several times per day I get this error:
2019-06-30 18:07:07.239 Error: Broadlink hardware (35) thread seems to have ended unexpectedly
I am using Domoticz v.4.10717 Python 3.5.3 on Linux domoticz 4.14.83v7-aufs #1 SMP Wed Nov 28 22:52:43 CET 2018 armv7l GNU/Linux
All other plugins works fine. Domoticz is running fine for 14 days now. System is up for over 38 days and running fine.
What might cause the error?
Posted: Monday 01 July 2019 23:06
by zak45
EddyG wrote: Monday 01 July 2019 8:20
this could happend when plugin could not reach the device due to network problem. Got this error also on my win installation every time when I had network issue (wire deconnected, tcp/ip hang, ...)
Posted: Friday 19 July 2019 10:43
by Flappie
Can anyone confirm this plugin works with the latest beta of Domoticz?
Posted: Monday 29 July 2019 22:17
by mantoz
Flappie wrote: Friday 19 July 2019 10:43
to be sincere, I tried in the past days but I'm not able to make it work with my RM mini3.
While the import feature seems to work, I am not able to get domoticz connected to the RM mini3 while it is sending commands.
Everything is ok with the app on my mobile phone, it just doesn't work from domoticz with the python script.
From my side, anyone with some tip or trick is welcome.
mantoz
Posted: Friday 16 August 2019 9:53
by alextk69
I found the problem.
What I did to resolve the issue was to remove the broadlink plugin and to install an older version of it that I know was working before.
So all you have to do is the following:
sudo pip3 uninstall broadlink
sudo -H pip3 install broadlink==0.10
After doing this I restarted domoticz and then I was able to find my rm3 mini devices.
I hope this will help you and good luck!
Posted: Wednesday 04 December 2019 14:10
by nezber
Sorry realise this is an old post however I seem to be having similar issues to a lot on here but can't seem to see the response.
I have reinstalled domoticz and got the Broadlink connected OK, however the learn button seems really temperamental, I am trying to learn RF commands and sometimes it works, others not it seems to learn one then need a full reboot of the Pi before it will learn anything else.
I am running it on a Pi
Any thoughts or help much appreciated
Rich
Posted: Thursday 05 December 2019 13:35
by zak45
nezber wrote: Wednesday 04 December 2019 14:10
RF should not work with this relaese. Next one will include it.
Posted: Friday 14 February 2020 18:44
by Jufo
I have a problem with the new installation, please help
Without plugin, Domoticz works correctly.
System: Debian Buster
Domoticz: 4.11690
2020-02-14 18:13:56.036 Status: PluginSystem: Entering work loop.
2020-02-14 18:13:56.138 Error: Domoticz(pid:535, tid:539('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-02-14 18:13:56.138 Error: siginfo address=0x217, address=0x7f33b3bca5cb
2020-02-14 18:13:56.141 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-02-14 18:13:56.151 Error: #0 /home/robert/domoticz/domoticz() [0x735e53]
2020-02-14 18:13:56.151 Error: #1 /home/robert/domoticz/domoticz : signal_handler(int, siginfo_t*, void*) + 0x295 [0x736975]
2020-02-14 18:13:56.151 Error: #2 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x12730 [0x7f33b3bca730]
2020-02-14 18:13:56.151 Error: #3 /lib/x86_64-linux-gnu/libpthread.so.0 : raise + 0x10b [0x7f33b3bca5cb]
2020-02-14 18:13:56.151 Error: #4 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0x12730 [0x7f33b3bca730]
2020-02-14 18:13:56.151 Error: #5 /lib/x86_64-linux-gnu/libc.so.6 : + 0x90a4a [0x7f33b38d9a4a]
2020-02-14 18:13:56.151 Error: #6 /home/robert/domoticz/domoticz() [0xc47429]
2020-02-14 18:13:56.151 Error: #7 /home/robert/domoticz/domoticz : lh_insert + 0x4c [0xc476dc]
2020-02-14 18:13:56.151 Error: #8 /home/robert/domoticz/domoticz : OBJ_NAME_add + 0x63 [0xc10543]
2020-02-14 18:13:56.151 Error: #9 /lib/x86_64-linux-gnu/libcrypto.so.1.1 : + 0x16f11e [0x7f3395b6711e]
2020-02-14 18:13:56.151 Error: #10 /lib/x86_64-linux-gnu/libcrypto.so.1.1 : + 0x189f99 [0x7f3395b81f99]
2020-02-14 18:13:56.151 Error: #11 /lib/x86_64-linux-gnu/libpthread.so.0 : + 0xf997 [0x7f33b3bc7997]
2020-02-14 18:13:56.151 Error: #12 /lib/x86_64-linux-gnu/libcrypto.so.1.1 : CRYPTO_THREAD_run_once + 0x9 [0x7f3395bebc09]
2020-02-14 18:13:56.151 Error: #13 /lib/x86_64-linux-gnu/libcrypto.so.1.1 : OPENSSL_init_crypto + 0x263 [0x7f3395b82503]
2020-02-14 18:13:56.151 Error: #14 /usr/lib/python3.7/lib-dynload/_hashlib.cpython-37m-x86_64-linux-gnu.so : PyInit__hashlib + 0x11 [0x7f33b093ba41]
2020-02-14 18:13:56.151 Error: #15 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyImport_LoadDynamicModuleWithSpec + 0x183 [0x7f33b2770a93]
2020-02-14 18:13:56.151 Error: #16 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x18600b [0x7f33b277100b]
2020-02-14 18:13:56.151 Error: #17 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyMethodDef_RawFastCallDict + 0x1d7 [0x7f33b285ff37]
2020-02-14 18:13:56.151 Error: #18 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyCFunction_FastCallDict + 0x25 [0x7f33b2860a45]
2020-02-14 18:13:56.151 Error: #19 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x78e0 [0x7f33b2661700]
2020-02-14 18:13:56.151 Error: #20 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.151 Error: #21 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallKeywords + 0x93 [0x7f33b2860123]
2020-02-14 18:13:56.151 Error: #22 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x7b95 [0x7f33b26619b5]
2020-02-14 18:13:56.151 Error: #23 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #24 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x9334 [0x7f33b2663154]
2020-02-14 18:13:56.151 Error: #25 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #26 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #27 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #28 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #29 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #30 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #31 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #32 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallDict + 0x2e2 [0x7f33b2860542]
2020-02-14 18:13:56.151 Error: #33 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x276d60 [0x7f33b2861d60]
2020-02-14 18:13:56.151 Error: #34 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyObject_CallMethodIdObjArgs + 0xa9 [0x7f33b2862389]
2020-02-14 18:13:56.151 Error: #35 /lib/x86_64-linux-gnu/libpython3.7m.so : PyImport_ImportModuleLevelObject + 0x60f [0x7f33b266c83f]
2020-02-14 18:13:56.151 Error: #36 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x747a [0x7f33b266129a]
2020-02-14 18:13:56.151 Error: #37 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.151 Error: #38 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCodeEx + 0x3e [0x7f33b278946e]
2020-02-14 18:13:56.151 Error: #39 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCode + 0x1b [0x7f33b278a23b]
2020-02-14 18:13:56.151 Error: #40 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x1a2bdd [0x7f33b278dbdd]
2020-02-14 18:13:56.151 Error: #41 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyMethodDef_RawFastCallDict + 0x1d7 [0x7f33b285ff37]
2020-02-14 18:13:56.151 Error: #42 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyCFunction_FastCallDict + 0x25 [0x7f33b2860a45]
2020-02-14 18:13:56.151 Error: #43 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x78e0 [0x7f33b2661700]
2020-02-14 18:13:56.151 Error: #44 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.151 Error: #45 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallKeywords + 0x93 [0x7f33b2860123]
2020-02-14 18:13:56.151 Error: #46 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x7b95 [0x7f33b26619b5]
2020-02-14 18:13:56.151 Error: #47 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #48 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x9334 [0x7f33b2663154]
2020-02-14 18:13:56.151 Error: #49 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #50 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #51 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #52 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #53 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #54 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallDict + 0x2e2 [0x7f33b2860542]
2020-02-14 18:13:56.151 Error: #55 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x276d60 [0x7f33b2861d60]
2020-02-14 18:13:56.151 Error: #56 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyObject_CallMethodIdObjArgs + 0xa9 [0x7f33b2862389]
2020-02-14 18:13:56.151 Error: #57 /lib/x86_64-linux-gnu/libpython3.7m.so : PyImport_ImportModuleLevelObject + 0x60f [0x7f33b266c83f]
2020-02-14 18:13:56.151 Error: #58 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x747a [0x7f33b266129a]
2020-02-14 18:13:56.151 Error: #59 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.151 Error: #60 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCodeEx + 0x3e [0x7f33b278946e]
2020-02-14 18:13:56.151 Error: #61 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCode + 0x1b [0x7f33b278a23b]
2020-02-14 18:13:56.151 Error: #62 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x1a2bdd [0x7f33b278dbdd]
2020-02-14 18:13:56.151 Error: #63 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyMethodDef_RawFastCallDict + 0x1d7 [0x7f33b285ff37]
2020-02-14 18:13:56.151 Error: #64 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyCFunction_FastCallDict + 0x25 [0x7f33b2860a45]
2020-02-14 18:13:56.151 Error: #65 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x78e0 [0x7f33b2661700]
2020-02-14 18:13:56.151 Error: #66 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.151 Error: #67 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallKeywords + 0x93 [0x7f33b2860123]
2020-02-14 18:13:56.151 Error: #68 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x7b95 [0x7f33b26619b5]
2020-02-14 18:13:56.151 Error: #69 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #70 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x9334 [0x7f33b2663154]
2020-02-14 18:13:56.151 Error: #71 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #72 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #73 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #74 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.151 Error: #75 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.151 Error: #76 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallDict + 0x2e2 [0x7f33b2860542]
2020-02-14 18:13:56.151 Error: #77 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x276d60 [0x7f33b2861d60]
2020-02-14 18:13:56.152 Error: #78 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyObject_CallMethodIdObjArgs + 0xa9 [0x7f33b2862389]
2020-02-14 18:13:56.152 Error: #79 /lib/x86_64-linux-gnu/libpython3.7m.so : PyImport_ImportModuleLevelObject + 0x60f [0x7f33b266c83f]
2020-02-14 18:13:56.152 Error: #80 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x747a [0x7f33b266129a]
2020-02-14 18:13:56.152 Error: #81 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.152 Error: #82 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCodeEx + 0x3e [0x7f33b278946e]
2020-02-14 18:13:56.152 Error: #83 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCode + 0x1b [0x7f33b278a23b]
2020-02-14 18:13:56.152 Error: #84 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x1a2bdd [0x7f33b278dbdd]
2020-02-14 18:13:56.152 Error: #85 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyMethodDef_RawFastCallDict + 0x1d7 [0x7f33b285ff37]
2020-02-14 18:13:56.152 Error: #86 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyCFunction_FastCallDict + 0x25 [0x7f33b2860a45]
2020-02-14 18:13:56.152 Error: #87 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x78e0 [0x7f33b2661700]
2020-02-14 18:13:56.152 Error: #88 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.152 Error: #89 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallKeywords + 0x93 [0x7f33b2860123]
2020-02-14 18:13:56.152 Error: #90 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x7b95 [0x7f33b26619b5]
2020-02-14 18:13:56.152 Error: #91 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #92 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x9334 [0x7f33b2663154]
2020-02-14 18:13:56.152 Error: #93 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #94 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.152 Error: #95 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #96 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.152 Error: #97 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #98 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallDict + 0x2e2 [0x7f33b2860542]
2020-02-14 18:13:56.152 Error: #99 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x276d60 [0x7f33b2861d60]
2020-02-14 18:13:56.152 Error: #100 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyObject_CallMethodIdObjArgs + 0xa9 [0x7f33b2862389]
2020-02-14 18:13:56.152 Error: #101 /lib/x86_64-linux-gnu/libpython3.7m.so : PyImport_ImportModuleLevelObject + 0x60f [0x7f33b266c83f]
2020-02-14 18:13:56.152 Error: #102 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x747a [0x7f33b266129a]
2020-02-14 18:13:56.152 Error: #103 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.152 Error: #104 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCodeEx + 0x3e [0x7f33b278946e]
2020-02-14 18:13:56.152 Error: #105 /lib/x86_64-linux-gnu/libpython3.7m.so : PyEval_EvalCode + 0x1b [0x7f33b278a23b]
2020-02-14 18:13:56.152 Error: #106 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x1a2bdd [0x7f33b278dbdd]
2020-02-14 18:13:56.152 Error: #107 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyMethodDef_RawFastCallDict + 0x1d7 [0x7f33b285ff37]
2020-02-14 18:13:56.152 Error: #108 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyCFunction_FastCallDict + 0x25 [0x7f33b2860a45]
2020-02-14 18:13:56.152 Error: #109 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x78e0 [0x7f33b2661700]
2020-02-14 18:13:56.152 Error: #110 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalCodeWithName + 0x996 [0x7f33b27891e6]
2020-02-14 18:13:56.152 Error: #111 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallKeywords + 0x93 [0x7f33b2860123]
2020-02-14 18:13:56.152 Error: #112 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x7b95 [0x7f33b26619b5]
2020-02-14 18:13:56.152 Error: #113 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #114 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x9334 [0x7f33b2663154]
2020-02-14 18:13:56.152 Error: #115 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #116 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.152 Error: #117 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #118 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyEval_EvalFrameDefault + 0x5d1c [0x7f33b265fb3c]
2020-02-14 18:13:56.152 Error: #119 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x794d3 [0x7f33b26644d3]
2020-02-14 18:13:56.152 Error: #120 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyFunction_FastCallDict + 0x2e2 [0x7f33b2860542]
2020-02-14 18:13:56.152 Error: #121 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x276d60 [0x7f33b2861d60]
2020-02-14 18:13:56.152 Error: #122 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyObject_CallMethodIdObjArgs + 0xa9 [0x7f33b2862389]
2020-02-14 18:13:56.152 Error: #123 /lib/x86_64-linux-gnu/libpython3.7m.so : PyImport_ImportModuleLevelObject + 0x60f [0x7f33b266c83f]
2020-02-14 18:13:56.152 Error: #124 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x1a11d8 [0x7f33b278c1d8]
2020-02-14 18:13:56.152 Error: #125 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyMethodDef_RawFastCallDict + 0x13b [0x7f33b285fe9b]
2020-02-14 18:13:56.152 Error: #126 /lib/x86_64-linux-gnu/libpython3.7m.so : _PyCFunction_FastCallDict + 0x25 [0x7f33b2860a45]
2020-02-14 18:13:56.152 Error: #127 /lib/x86_64-linux-gnu/libpython3.7m.so : + 0x276bfb [0x7f33b2861bfb]
Posted: Saturday 15 February 2020 15:21
by Jufo
Ok, this is the problem with the new beta version domoticz and plugin ?
Works correctly in version 4.11494 (I have restored from my old virtual machine backup)
Works with python 3.7
I found the same problems in other threads, it looks like from version 4.11595:
https://github.com/domoticz/domoticz/issues/3819
https://www.domoticz.com/forum/viewtopi ... .0#p232761
This tells me you have an issue with OpenSSL version compatability:
Very often caused by plugins including the 'requests' library rather than using the built in protocols.
