RoadXY
Domoticz version: 2.2331
Re: Domoticz app 2.0
Post by RoadXY »
tozzke wrote: I think it's because of this new feature:
viewtopic.php?f=6&t=9838
Nice find!
Helps us a lot!
Chakkie
Post by Chakkie »
This app is amazing.
I was wondering if you can give us the option to choose between slide and seperated button for Group type Scenes.
One of my group type is several lights on and off. When some of the lights are already on and I wanted to activate the group to turn off the lights in the group. I have to slide the button to ON and then OFF. I would prefer to have the group type scene to have seperated ON and OFF button.
Thanks and keep up the good work
locogek
Post by locogek »
Maybe it is something for geofencing to choose if you want to set a switch on or of or both. Example I have made a virtual switch that will set on/off different things. But they need to go off if I am not at home anymore. If I come back I don't want always that they go on. <br /><br />Verstuurd vanaf mijn ONE A2003 met Tapatalk
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
MarcelMAH wrote:
ubfssF wrote:Current Play store version (premium, 0.1.207) does have the ability to create locations for Geofencing, but I haven't found a way to set switches based on it. Is that confined to the beta app, or am I overlooking something?
Really love the app, especially the Android wear option 8-)
On Android wear an option to select a group instead of only switches would be a nice upgrade, but a "nice to have" one of course.
Long press :)
Sounds stupid, probably, but what exactly has to be long-pressed? NB: in the premium version, not the beta!
MarcelMAH
Domoticz version: v3.8025
Post by MarcelMAH »
Long press :)
The geofenced that you have added show up below the map (I'm also on the non beta). You can scroll trough them altough you can't see the scroll bar... when long pressing on the individual geofences you get a popup to select the switches.
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
ubfssF
Post by ubfssF »
[/quote]The geofenced that you have added show up below the map (I'm also on the non beta). You can scroll trough them altough you can't see the scroll bar... when long pressing on the individual geofences you get a popup to select the switches.[/quote]
Thanx, found it now! I am probably stupid, but then I didn't get far also with the AIVD Christmas puzzle :P
pepeEL
Post by pepeEL »
I found next bug. WHen i open set point thermostat, and click SET, then i click on "-" and on first click it not change down , it change up, second click start change temp down. Button "+" works ok from first click.
rammstan
Post by rammstan »
Skippiemanz wrote:
rammstan wrote:Hello,
I have pro version. I have bugs with geofence. Sync and geoloc are activate on m'y mobile.
No connection problem with Server.
I m notified When i leave the area or enter in it. But the state of the switch is not changing.
Do you experiment the same problem ?
Do you know why?
Thank for your feedback
Same problem here on my Samsung s6 edge. Receive notification but the switch isn't flipped. Maybe something to do with my virtual switch beeing protected? Switch hasn't been triggered since installation off the app. Using premium version and beta tester. Updated the geofencing settings after the beta update today.
*EDIT* Just turned off the switch protection and the geofencing off the app switched it right away! So please look in to that!
For the rest keep up good work!
No, the switch is not "protected". It works sometimes now (in average 1 time on 4) . Some places works better than other (on the 3G/4G too). Maybe connection is lagggging too much. The trigger works most of the time... I hope with the version it wil work. I use the play store version. Where can i fond the beta version?
The bug example:
The two geofences are each 45 km away. But it say that i'm in the places at the same time (like schrodinger's cats :twisted: )
Image https://goo.gl/photos/A27z8TmfLhKy8g6J8
So it means the code check only i f you leave or enter. Not if your en or out??
Need light on this.
EDIT: i just to note that i activated an option to send data at fixe interval to save battery. Maybe it s that. I m testing When i m back to home
RPi 2 + UPS Pico + enOcean + RFXCOM ext 250
rammstan
Post by rammstan »
What would be nice is a feature to transform your (old) mobile phone in camera/ detection presence / lumionosity / others device directly detected (and configured) with your domoticz server. 8-)
RoadXY
Post by RoadXY »
rammstan wrote:What would be nice is a feature to transform your (old) mobile phone in camera/ detection presence / lumionosity / others device directly detected (and configured) with your domoticz server. 8-)
That needs quite a intelligent code and connection.
There are apps who do that already.
svenker
Domoticz version: Latest
Post by svenker »
Hello
I am still dreaming of a great Security Panel page.
My Android tablet is on the wall, everything works well except the security panel on which I didn't find a good integration.
Is there a release soon ?
Sam
RoadXY
Post by RoadXY »
svenker wrote:Hello
Sam
It's in beta right now.
Shouldn't be long
svenker
Post by svenker »
If you send me the apk, I can test it and give you feedback if needed :-)
lrybak
Post by lrybak »
Really good stuff guys.
Do you have plans for implementing imperihome style like dashboard with possibility to select particular device as an icon and align it on grid?
That would be very good option for wall mounted tablets.
Is it possible to change language from my device default one (Polish) to English? I can't find it in Settings page
Keep going
HW: HP dc7900 USD running ESXi, RaspberryPi (few of it), AEON S2 USB stick, Fibaro modules (Dimmers, switches), 1-wire (DS18B20, DS2423), DSC Alarm with Envisalink ethernet module, MySensors, RFLink
RoadXY
Post by RoadXY »
lrybak wrote:Really good stuff guys.
Keep going
First we have to test and create a stable base.
Language change is not possible.
MarcelMAH
Post by MarcelMAH »
I just updated (premium non beta) and the first big bug I found is the setpoint for temperature does not work correctly. When I click set the number shown is 0.5 lower than it really is and when pressing - it goes up by 0.5 until I press +, when I press + it goes down by 0.5 for the first time. When iI press OK the final number is 0.5 higher then what I set it to.
pepeEL
Post by pepeEL »
True ibwrite about it and it is set as a bug. Develeoper works on it.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
bvduijv
Post by bvduijv »
In de lite version it works better (not completely right), weird. I have both installed.
ceedebee
Post by ceedebee »
Updated the app by goole play and now it chrashes at start up.
maluko
Post by maluko »
dont know if it is on list of implement but i think that the scenes will be better with on/off buttons because:
- i have 6 blind with a scene "open morning" that open only 3 blind at morning, but if i want to close all blind with android app i have to close one by one or open the group with all and close.
- supose that you want open the blind to the midle with group, with my x10 module or DIO we have to click on and wait x seconds until blind arrive to midle and next click ON again to stop, so have to click 2x ON that with app we cant.
good work
