Thanks!tozzke wrote: I think it's because of this new feature:
viewtopic.php?f=6&t=9838
Nice find!
Helps us a lot!
Sounds stupid, probably, but what exactly has to be long-pressed? NB: in the premium version, not the beta!MarcelMAH wrote:Long pressubfssF wrote:Current Play store version (premium, 0.1.207) does have the ability to create locations for Geofencing, but I haven't found a way to set switches based on it. Is that confined to the beta app, or am I overlooking something?
Really love the app, especially the Android wear option![]()
On Android wear an option to select a group instead of only switches would be a nice upgrade, but a "nice to have" one of course.
The geofenced that you have added show up below the map (I'm also on the non beta). You can scroll trough them altough you can't see the scroll bar... when long pressing on the individual geofences you get a popup to select the switches.ubfssF wrote:Sounds stupid, probably, but what exactly has to be long-pressed? NB: in the premium version, not the beta!MarcelMAH wrote:Long pressubfssF wrote:Current Play store version (premium, 0.1.207) does have the ability to create locations for Geofencing, but I haven't found a way to set switches based on it. Is that confined to the beta app, or am I overlooking something?
No, the switch is not "protected". It works sometimes now (in average 1 time on 4) . Some places works better than other (on the 3G/4G too). Maybe connection is lagggging too much. The trigger works most of the time... I hope with the version it wil work. I use the play store version. Where can i fond the beta version?Skippiemanz wrote:Same problem here on my Samsung s6 edge. Receive notification but the switch isn't flipped. Maybe something to do with my virtual switch beeing protected? Switch hasn't been triggered since installation off the app. Using premium version and beta tester. Updated the geofencing settings after the beta update today.rammstan wrote:Hello,
I have pro version. I have bugs with geofence. Sync and geoloc are activate on m'y mobile.
No connection problem with Server.
I m notified When i leave the area or enter in it. But the state of the switch is not changing.
Do you experiment the same problem ?
Do you know why?
Thank for your feedback
*EDIT* Just turned off the switch protection and the geofencing off the app switched it right away! So please look in to that!
For the rest keep up good work!
That needs quite a intelligent code and connection.rammstan wrote:What would be nice is a feature to transform your (old) mobile phone in camera/ detection presence / lumionosity / others device directly detected (and configured) with your domoticz server.
It's in beta right now.svenker wrote:Hello
I am still dreaming of a great Security Panel page.
My Android tablet is on the wall, everything works well except the security panel on which I didn't find a good integration.
Is there a release soon ?
Sam
First we have to test and create a stable base.lrybak wrote:Really good stuff guys.
Do you have plans for implementing imperihome style like dashboard with possibility to select particular device as an icon and align it on grid?
That would be very good option for wall mounted tablets.
Is it possible to change language from my device default one (Polish) to English? I can't find it in Settings page
Keep going
