Page 28 of 55
Re: [MyDomoAtHome] Support thread
Posted: Monday 04 April 2016 21:33
by rafal
Doler wrote:rafal wrote:Thank You for answer
Stuck on a pre 0.1.x version
apt-get remove mydomoathome
apt-get update
apt-get install MyDomoAtHome
done !
but still the the same :/ waiting for update
PS Thank You epierre for You hard work !
You should put 'sudo' before the commands.
Yes i know, look on my print screen
Posted: Wednesday 06 April 2016 22:05
by epierre
@rafal try this (sorry I thought that was fixed, image not readable easily on mobile)
sudo chown -R $(whoami) ~/.npm
Posted: Thursday 07 April 2016 10:06
by rafal
epierre wrote:@rafal try this (sorry I thought that was fixed, image not readable easily on mobile)
no problem
i did new instaltaion of domoticz (fresh system ubuntu serwer
) and i used your command, still the same problem with instalation mydomoathome.
Don't rush my old MyDomoAtHome working fine but i' d like to change my old domoathome to new mydomoathome with nodejs
i added new images (print screen) via link on google drive, should be much better to open for You.
https://drive.google.com/file/d/0B5vmlS ... sp=sharing
Posted: Thursday 07 April 2016 10:26
by epierre
@rafal version °.1.10 from this morning has been reported as working on this issue. do an update and an upgrade.
Someone else pointed me this that I didn't understood first as an issue.
Posted: Thursday 07 April 2016 11:28
by rafal
Posted: Thursday 07 April 2016 11:33
by SchattenMann
and to me it shows as 0.1.7...that's bizarre
Posted: Thursday 07 April 2016 11:47
by epierre
scratching my head...
at worse you can download here:
http://www.e-nef.com/domoticz/mdah/node ... latest.deb
have you made an apt-get update before ?
Posted: Thursday 07 April 2016 11:56
by rafal
Yes
sudo apt-get update then sudo apt-get upgrade
by SchattenMann
OK so I think I got it, I've managed to install 1.09 which according to apt-get is the latest version.
think there's something wrong with the version numbering no?
April 02 -> 0.1.7
April 06 -> 1.0.9
April 07 -> 0.1.10
MyDomoAtHome:
Installed: 1.0.9
Candidate: 1.0.9
Version table:
*** 1.0.9 0
500
http://www.e-nef.com/domoticz/mdah/ Packages
100 /var/lib/dpkg/status
1.0.8 0
500
0.1.10 0
500
500
0.1.7 0
500
0.1.6 0
500
0.1.4 0
500
0.1.3 0
500
0.1.2 0
500
0.1.1 0
500
0.1.0 0
500
Posted: Thursday 07 April 2016 12:27
by rafal
ok manually instalation is complete
i don't know under red line is information that You need
Posted: Thursday 07 April 2016 12:43
by rafal
i think so, about version you're right, look on my print screen: my domo is downgrading from 1.0.9 to 0.1.10 ;/
Posted: Thursday 07 April 2016 12:49
by rafal
1.10 working
:D:D
AppName: MyDomoAtHome
MDAH:
http://10.216.xxx.xxx:3002
Domoticz:
http://127.0.0.1:8080
NodeJS: v4.4.2
Webmanager: EJS
Renderer: Express
Posted: Thursday 07 April 2016 20:45
by epierre
looks like I did number wrong at some point, V1.0.0 will be when graphs will be back there
the red line is jus ta Warning... forget it!
Posted: Monday 11 April 2016 18:35
by doh
I have this all up and running on my Pi2 no problem, and have ImperiHome on my Android phone connected to it ok. Is there a way for ImperiHome to group devices by the Rooms/Plans that Domoticz uses at all? Thanks
Posted: Monday 11 April 2016 20:44
by epierre
doh wrote:I have this all up and running on my Pi2 no problem, and have ImperiHome on my Android phone connected to it ok. Is there a way for ImperiHome to group devices by the Rooms/Plans that Domoticz uses at all? Thanks
yes I have it in my backlog...
Posted: Wednesday 13 April 2016 9:31
by epierre
@all graphes for devices are back in day/week/month/year, some are still to be put it:
https://github.com/empierre/MyDomoAtHome/issues/90
I have a proposal for PlanID here, can you comment if this is fine for you ?
https://github.com/empierre/MyDomoAtHome/issues/57
Posted: Thursday 14 April 2016 12:07
by epierre
@all I'm searching for the devices you would have with z-wave on blinds+energy or switch+energy plugs please contact me !
Posted: Friday 15 April 2016 22:16
by naitsirhc
I am an newbie to Domoticz and Imperihome now, and I'm very pleased to have it running in my local network.
Al my devices are lock and loaded and its works (most of the time) very good.
However, it would be nice to have it running outside my local network.
So I followed the wiki (
http://www.domoticz.com/wiki/Secure_Nginx_Proxy_Setup) and installed it, till I get to the point where I have to remove the pass phrase from the server key.
Wenn I enter : sudo openssl rsa -in /etc/ssl/private/server.key -out /etc/ssl/private/server.key
The answer is:
unable to load Private Key
3069404368:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:703:Expecting: ANY PRIVATE KEY
This is a little odd, because I do have a server.key in the mentioned directory.
Does anybody know what the probem can be?
Thnaks in advance
Posted: Monday 18 April 2016 9:42
by epierre
looks like you had an issue during the "sudo nano /etc/ssl/private/server.key", try again this step
Posted: Monday 18 April 2016 9:43
by epierre
@all latest versions now support:
- PlanID
- domoticz camera
- instant energy with the switch
- use of protected devices
cheers & many thanks to all contributors !
