[MyDomoAtHome] Support thread
rafal
Domoticz version: latest
Re: [MyDomoAtHome] Support thread
Post by rafal »
Doler wrote:
rafal wrote:Thank You for answer :)
Stuck on a pre 0.1.x version
apt-get remove mydomoathome
apt-get update
apt-get install MyDomoAtHome
done !
but still the the same :/ waiting for update :)
PS Thank You epierre for You hard work !
You should put 'sudo' before the commands.
Yes i know, look on my print screen :)
epierre
Post by epierre »
@rafal try this (sorry I thought that was fixed, image not readable easily on mobile)
sudo chown -R $(whoami) ~/.npm
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
rafal
Post by rafal »
epierre wrote:@rafal try this (sorry I thought that was fixed, image not readable easily on mobile)
no problem
i did new instaltaion of domoticz (fresh system ubuntu serwer :)) and i used your command, still the same problem with instalation mydomoathome.
Don't rush my old MyDomoAtHome working fine but i' d like to change my old domoathome to new mydomoathome with nodejs :)
i added new images (print screen) via link on google drive, should be much better to open for You.
https://drive.google.com/file/d/0B5vmlS ... sp=sharing
epierre
Post by epierre »
@rafal version °.1.10 from this morning has been reported as working on this issue. do an update and an upgrade.
Someone else pointed me this that I didn't understood first as an issue.
rafal
Post by rafal »
ok
update is 1.09 :shock:
still the same ;/
SchattenMann
Post by SchattenMann »
and to me it shows as 0.1.7...that's bizarre
epierre
Post by epierre »
scratching my head...
at worse you can download here:
http://www.e-nef.com/domoticz/mdah/node ... latest.deb
have you made an apt-get update before ?
rafal
Post by rafal »
Yes
sudo apt-get update then sudo apt-get upgrade
SchattenMann
OK so I think I got it, I've managed to install 1.09 which according to apt-get is the latest version.
think there's something wrong with the version numbering no?
April 02 -> 0.1.7
April 06 -> 1.0.9
April 07 -> 0.1.10
MyDomoAtHome:
Installed: 1.0.9
Candidate: 1.0.9
Version table:
*** 1.0.9 0
500 http://www.e-nef.com/domoticz/mdah/ Packages
100 /var/lib/dpkg/status
1.0.8 0
0.1.10 0
0.1.7 0
0.1.6 0
0.1.4 0
0.1.3 0
0.1.2 0
0.1.1 0
0.1.0 0
rafal
Post by rafal »
ok manually instalation is complete :)
i don't know under red line is information that You need
rafal
Post by rafal »
SchattenMann wrote:OK so I think I got it, I've managed to install 1.09 which according to apt-get is the latest version.
April 02 -> 0.1.7
April 06 -> 1.0.9
April 07 -> 0.1.10
MyDomoAtHome:
Installed: 1.0.9
Candidate: 1.0.9
Version table:
*** 1.0.9 0
1.0.8 0
0.1.10 0
0.1.7 0
0.1.6 0
0.1.4 0
0.1.3 0
0.1.2 0
0.1.1 0
0.1.0 0
i think so, about version you're right, look on my print screen: my domo is downgrading from 1.0.9 to 0.1.10 ;/
rafal
Post by rafal »
1.10 working :D:D:D :mrgreen: :mrgreen:
AppName: MyDomoAtHome
MDAH: http://10.216.xxx.xxx:3002
Domoticz: http://127.0.0.1:8080
NodeJS: v4.4.2
Webmanager: EJS
Renderer: Express
epierre
Post by epierre »
looks like I did number wrong at some point, V1.0.0 will be when graphs will be back there ;-)
the red line is jus ta Warning... forget it!
doh
Post by doh »
I have this all up and running on my Pi2 no problem, and have ImperiHome on my Android phone connected to it ok. Is there a way for ImperiHome to group devices by the Rooms/Plans that Domoticz uses at all? Thanks
epierre
Post by epierre »
doh wrote:I have this all up and running on my Pi2 no problem, and have ImperiHome on my Android phone connected to it ok. Is there a way for ImperiHome to group devices by the Rooms/Plans that Domoticz uses at all? Thanks
yes I have it in my backlog...
epierre
Post by epierre »
@all graphes for devices are back in day/week/month/year, some are still to be put it:
https://github.com/empierre/MyDomoAtHome/issues/90
I have a proposal for PlanID here, can you comment if this is fine for you ?
https://github.com/empierre/MyDomoAtHome/issues/57
epierre
Post by epierre »
@all I'm searching for the devices you would have with z-wave on blinds+energy or switch+energy plugs please contact me !
naitsirhc
Post by naitsirhc »
I am an newbie to Domoticz and Imperihome now, and I'm very pleased to have it running in my local network.
Al my devices are lock and loaded and its works (most of the time) very good.
However, it would be nice to have it running outside my local network.
So I followed the wiki (http://www.domoticz.com/wiki/Secure_Nginx_Proxy_Setup) and installed it, till I get to the point where I have to remove the pass phrase from the server key.
Wenn I enter : sudo openssl rsa -in /etc/ssl/private/server.key -out /etc/ssl/private/server.key
The answer is:
unable to load Private Key
3069404368:error:0906D06C:PEM routines:PEM_read_bio:no start line:pem_lib.c:703:Expecting: ANY PRIVATE KEY
This is a little odd, because I do have a server.key in the mentioned directory.
Does anybody know what the probem can be?
Thnaks in advance
Und Tschjuß
epierre
Post by epierre »
looks like you had an issue during the "sudo nano /etc/ssl/private/server.key", try again this step ;-)
epierre
Post by epierre »
@all latest versions now support:
- PlanID
- domoticz camera
- instant energy with the switch
- use of protected devices
cheers & many thanks to all contributors !
