Page 28 of 33
Re: Python Plugin : Broadlink RM2 V4
Posted: Tuesday 07 May 2019 11:12
by arcpaqua
zak45 wrote: Saturday 20 April 2019 12:39
@arcpaqua
Do you have verified right settings on your ini / folder ?
User running Domoticz need to have at minima read authorization.
Thank you zak and sorry for the delay.
Here the permission in ini folder:
pi@raspberrypi:~/domoticz/plugins/BroadlinkRM2/ini $ ls -altr
total 116
-rw-r----- 1 root root 547 Apr 10 10:08 BroadlinkRM2-5-5.ini
-rw-r----- 1 root root 677 Apr 10 10:12 BroadlinkRM2-5-10.ini
-rw-r----- 1 root root 549 Apr 10 10:13 BroadlinkRM2-5-11.ini
-rw-r----- 1 root root 549 Apr 10 10:14 BroadlinkRM2-5-13.ini
-rw-r----- 1 root root 677 Apr 10 10:16 BroadlinkRM2-5-14.ini
-rw-r----- 1 root root 677 Apr 10 10:21 BroadlinkRM2-5-16.ini
-rw-r----- 1 root root 549 Apr 10 10:22 BroadlinkRM2-5-17.ini
-rw-r----- 1 root root 677 Apr 10 10:22 BroadlinkRM2-5-18.ini
-rw-r----- 1 root root 549 Apr 10 10:23 BroadlinkRM2-5-19.ini
-rw-r----- 1 root root 549 Apr 10 10:23 BroadlinkRM2-5-20.ini
-rw-r----- 1 root root 549 Apr 10 10:24 BroadlinkRM2-5-21.ini
-rw-r----- 1 root root 677 Apr 10 10:24 BroadlinkRM2-5-22.ini
-rw-r----- 1 root root 549 Apr 10 10:25 BroadlinkRM2-5-23.ini
-rw-r----- 1 root root 549 Apr 10 10:25 BroadlinkRM2-5-24.ini
-rw-r----- 1 root root 549 Apr 10 10:26 BroadlinkRM2-5-25.ini
-rw-r----- 1 root root 677 Apr 10 10:26 BroadlinkRM2-5-26.ini
-rw-r----- 1 root root 558 Apr 10 10:59 BroadlinkRM2-5-3.ini
-rw-r----- 1 root root 556 Apr 10 21:01 BroadlinkRM2-5-2.ini
-rw-r----- 1 root root 683 Apr 10 21:02 BroadlinkRM2-5-27.ini
-rw-r----- 1 root root 683 Apr 10 21:02 BroadlinkRM2-5-9.ini
-rw-r----- 1 root root 551 Apr 10 21:02 BroadlinkRM2-5-4.ini
-rw-r----- 1 root root 685 Apr 10 21:02 BroadlinkRM2-5-8.ini
-rw-r----- 1 root root 552 Apr 10 21:02 BroadlinkRM2-5-6.ini
-rw-r----- 1 root root 561 Apr 13 14:56 BroadlinkRM2-5-12.ini
drwxr-xr-x 2 root root 4096 Apr 15 23:51 remote
drwxr-xr-x 2 root root 4096 Apr 15 23:53 import
drwxr-xr-x 4 pi pi 4096 Apr 16 19:27 ..
drwxr-xr-x 4 root root 4096 Apr 16 19:27 .
-rw-r----- 1 root root 683 Apr 16 19:31 BroadlinkRM2-5-15.ini
Below the permission in remote folder
pi@raspberrypi:~/domoticz/plugins/BroadlinkRM2/ini/remote $ ls -altr
total 12
-rw-r----- 1 root root 69 Apr 11 17:34 plugin_remote_5.ini
drwxr-xr-x 2 root root 4096 Apr 15 23:51 .
drwxr-xr-x 4 root root 4096 Apr 16 19:27 ..
Do you see some wrong setting?
Thank you again,
P.
Posted: Tuesday 07 May 2019 11:23
by zak45
arcpaqua wrote: Tuesday 07 May 2019 11:12
total 12
Thank you again,
P.
Hummm.. not linux specialist.. but try this:
sudo chmod -R 777 ~/domoticz/plugins/BroadlinkRM2/ini/remote
Posted: Tuesday 07 May 2019 11:57
by arcpaqua
zak45 wrote: Tuesday 07 May 2019 11:23
Thanks a lot,
but still not working. I really don't understand.
I restarted Domoticz and also Broadlink hardware, but nothing, the plugin doesn't search in the right place (the remote folder).
log:
2019-05-07 10:51:04.675 Status: User: Admin initiated a switch command (28/Broadlink RM2 - Remote/On)
2019-05-07 10:51:04.689 Error: (Broadlink RM2) ini file not found: /home/pi/domoticz/plugins/BroadlinkRM2/ini/BroadlinkRM2-5-254.ini
I give up, it doesn't matter.
Thank you very very much zak, you made and make a great job.
Paolo
Posted: Friday 10 May 2019 12:51
by arcpaqua
arcpaqua wrote: Tuesday 07 May 2019 11:57
Thanks a lot,
log:
Paolo
Sorry zak,
it is possible that the problem is the python version?
I have python 3.5 installed. Maybe all of that works with python 3.4
Posted: Sunday 12 May 2019 11:34
by EmmanuelFR
First thank you for this nice plugin.
I just suceeded in making it work with the last domoticz stable version (4.10731) under Ubuntu 18.04.2 LTS.
Before, I had an error in the log saying that it couldn't find a .ini file (note sure which one).
I'm not sure what did the trick, but I :
- created ini and remote folders
- populated them with dummy ini files :
- made a sudo chmod 755 on these folders and their content
- placed BroadlinkRM2-XXX-254.ini and plugin_remote_XXX.ini files in the plugin folder
- tried to update the hardware
- deleted it
- reinstalled it with the discovery information kept.
And now it works, I can learn a code and test it !
Update : There is still a ini file problem, I can't save a code and replay it yet.
Final update : There was a folder ownership problem and a missing ini file, I have absolutely no idea of the nature of the problem, just was lucky...
Cheers
Posted: Sunday 12 May 2019 13:50
by Loky31
Hello Zak and all,
So i'm back to business
Eventually been able to check the rights and here is the result:
pi@raspberrypi:~/domoticz/plugins/BroadlinkRM2 $ ls -altr
total 104
-rw-r--r-- 1 pi pi 1523 mars 31 12:20 plugin_send.py
-rw-r--r-- 1 pi pi 43486 mars 31 12:20 plugin.py
drwxr-x--- 2 root root 4096 avril 28 20:42 remote
drwxr-x--- 2 root root 4096 avril 28 20:42 import
-rw------- 1 root root 14059 mai 1 12:26 plugin_http.py.save
-rw-r--r-- 1 root root 11197 mai 1 12:57 plugin_http.py
drwxr-x--- 2 root root 4096 mai 1 13:09 __pycache__
-rw------- 1 pi pi 102 mai 1 14:29 nohup.out
drwxr-xr-x 11 pi pi 4096 mai 10 13:18 ..
-rwxr-xr-x 1 pi pi 86 mai 12 13:43 plugin_http.sh
drwxr-xr-x 5 pi pi 4096 mai 12 13:44 .
Compared to your exemple I'm indeed not in line....
Not linux expert at all, is the chmod 755 the solution on the BroadlinkRM2 directory?
And when coming to test the nohup here is the result :
pi@raspberrypi:~/domoticz/plugins/BroadlinkRM2 $ nohup plugin_http.sh 0.0.0.0 9000 /home/pi/domoticz/
nohup: les entrées sont ignorées et la sortie est ajoutée à 'nohup.out'
nohup: impossible d'exécuter la commande 'plugin_http.sh': Aucun fichier ou dossier de ce type
in the nohup out :
python: can't open file '/Domoticz/plugins/BroadlinkRM2/plugin_http.py': [Errno 13] Permission denied
Posted: Wednesday 15 May 2019 16:35
by Loky31
Any help on that please?
Posted: Friday 17 May 2019 9:42
by arcpaqua
EmmanuelFR wrote: Sunday 12 May 2019 11:34
- deleted it
Cheers
Thank you Emmanuel,
I'll try that.
Just one question for you, which python version you have?
Posted: Friday 17 May 2019 12:14
by Loky31
Hello all,
I've tried the chmod 755 but it seems not to change anything to the file rights...
I've made it on the directory.
Don't understand what to do then
Posted: Friday 17 May 2019 13:11
by Loky31
I'm ending up to use the "chmod -R a+rx" command on the Broadlink directory but not getting better results...
Am I crazy or is there plenty of Broadlink directories? Are they symbolic links or real directories? On which other one should I apply those right changes???
Defenetely going crazy with that....
Posted: Friday 17 May 2019 14:06
by arcpaqua
Loky31 wrote: Friday 17 May 2019 12:14
Hello all,
Hi Loky,
have you tried with:
sudo chmod -R 755 /domoticz/plugins/BroadlinkRM2
Posted: Friday 17 May 2019 14:24
by Loky31
Just done that, doesn't work neither
I logged in through putty as PI user and directly put the command.
Then tried to start the webserver through domoticz but still have the 127 error.
Really wondering where do I fail on that...
I thought that pluggin would be more likely to install and play
I don't want to go for a removal and install again as I have some commands already imported and working fine. As I'm not sure to be able to import again all commands from the web app...
Posted: Friday 17 May 2019 15:10
by arcpaqua
Loky31 wrote: Friday 17 May 2019 14:24
Could you please provide shell result after you execute sudo chmod -R 755 /domoticz/plugins/BroadlinkRM2
and then the log in Domoticz?
Posted: Friday 17 May 2019 15:11
by Loky31
Sure will do it when back from work
Posted: Friday 17 May 2019 19:26
by garycooper
Hello, since the last updating about Domoticz, multiplug MP1 is now ok !
Posted: Friday 17 May 2019 19:57
by Loky31
So here is the result:
pi@raspberrypi:~ $ sudo chmod -R 755 /domoticz/plugins/BroadlinkRM2
pi@raspberrypi:~ $ cd domoticz/plugins/BroadlinkRM2/
total 104
-rwxrwxrwx 1 pi pi 1523 mars 31 12:20 plugin_send.py
-rwxrwxrwx 1 pi pi 43486 mars 31 12:20 plugin.py
drwxrwxrwx 2 root root 4096 avril 28 20:42 remote
drwxrwxrwx 2 root root 4096 avril 28 20:42 import
-rwxrwxrwx 1 root root 14059 mai 1 12:26 plugin_http.py.save
-rwxrwxrwx 1 root root 11197 mai 1 12:57 plugin_http.py
drwxrwxrwx 2 root root 4096 mai 1 13:09 __pycache__
-rwxrwxrwx 1 pi pi 102 mai 1 14:29 nohup.out
-rwxrwxrwx 1 pi pi 86 mai 12 13:43 plugin_http.sh
drwxrwxrwx 5 pi pi 4096 mai 16 22:26 .
And domoticz logs :
2019-05-17 20:04:15.917 (RM salon) Pushing 'onCommandCallback' on to queue
2019-05-17 20:04:15.967 (RM salon) Processing 'onCommandCallback' message
2019-05-17 20:04:15.967 (RM salon) Calling message handler 'onCommand'.
2019-05-17 20:04:15.968 (RM salon) onCommand called for Unit 255: Parameter 'Set Level', Level: 10 , Connected : True
2019-05-17 20:04:15.917 Status: User: Admin initiated a switch command (46/RM salon - Import/Set Level)
2019-05-17 20:04:16.018 (RM salon - Import) Updating device from 0:'Off' to have values 0:'Off'.
2019-05-17 20:04:16.048 (RM salon) Update 0:'Off' (RM salon - Import)
2019-05-17 20:04:16.017 Error: (RM salon) 127
2019-05-17 20:04:16.018 Error: (RM salon) /home/pi/domoticz/plugins/BroadlinkRM2/plugin_http.sh 0.0.0.0 9000 /home/domoticz/plugins/BroadlinkRM2
2019-05-17 20:04:16.018 Error: (RM salon) None
2019-05-17 20:04:16.048 Error: (RM salon) Not able to start Web server
Posted: Saturday 18 May 2019 21:55
by zak45
some info on linux setup/settings (not linux specialist ..):
we suppose all is running with sudo...
this is the content of my linux test box:
- Spoiler: show
-rw-r--r-- 1 usr root 43486 Feb 19 21:41 plugin.py
-rw-r--r-- 1 usr root 1518 Feb 22 16:57 plugin_send.py
-rw-r--r-- 1 usr root 58 Feb 22 16:57 plugin_send.cmd
-rw-r--r-- 1 usr root 11469 Feb 22 16:57 plugin_http.py
-rw-r--r-- 1 usr root 76 Feb 22 16:57 plugin_http.cmd
drwxr-xr-x 2 usr root 4096 Apr 20 10:16 __pycache__
-rwxr-xr-x 1 usr root 87 May 4 10:10 plugin_http.sh
-rw------- 1 usr usr 784 May 4 10:24 nohup.out
drwxrwxr-x 2 usr usr 4096 May 7 09:22 remote
drwxr-xr-x 5 usr root 4096 May 7 09:22 .
drwxrwxr-x 3 usr usr 4096 May 7 09:22 ini
usr@amlogic:~/domoticz/plugins/BroadlinkRM2$
inside the plugin_http.sh
nohup python3 /home/usr/domoticz/plugins/BroadlinkRM2/plugin_http.py $1 $2 $3 $4 $5 &
to summarize:
the .sh need to have +x right
the .sh need to be accessible by the user executing the action, in case of any problem, for testing you can set 777
always use absolute path ( vs relative ) in the .sh to avoid command not found error.
Posted: Sunday 19 May 2019 0:26
by Loky31
Hum... somehow I had it working!
I removed and create again the file in ( once in su mode) and now the webserver starts!!!!
Quick moment of glory as I ended up with the folowing error :
2019-05-19 00:24:05.738 Error: (RM salon) 'onCommand' failed 'FileNotFoundError'.
2019-05-19 00:24:05.738 Error: (RM salon) ----> Line 265 in '/home/pi/domoticz/plugins/BroadlinkRM2/plugin.py', function onCommand
2019-05-19 00:24:05.738 Error: (RM salon) ----> Line 825 in '/home/pi/domoticz/plugins/BroadlinkRM2/plugin.py', function createIniImport
but gettin closer then
Any idea of what is going wrong with those script lines? rootcause or any hints?
Posted: Wednesday 29 May 2019 11:12
by Loky31
No ideas at all???
Still hoping to be able to use this addon properly :s
Posted: Monday 03 June 2019 13:05
by zak45
Loky31 wrote: Wednesday 29 May 2019 11:12
No ideas at all???
Looks like you try to use the import feature but not copied required files : jsonSubIr, jsonButton, jsonIrCode
