Page 27 of 94
Posted: Friday 08 January 2016 23:09
by jumbotroll
lampje25 wrote:Hello,
I'm new on this forum.
I have a Synology DS215 with DSM 5.2-5644 Update 1.
Under community, I can see Domoticz from Jumbotroll (version 2.0.4031-7)
When i try to install then "kan "Domoticz" niet installeren"
How to resolve this?
Sorry for the bad English...
Did you activate "Any Publisher" in package senter?
Jumbotroll
Posted: Friday 08 January 2016 23:54
by lampje25
Thank you!! that was the problem!!
Posted: Saturday 09 January 2016 1:41
by gevegest
jumbotroll wrote:
cwvs wrote:Hey Jumbotroll, first of all great work!
I have been using it for quite some time now and it works great!
One thing i am realy eager to experiment with is the possibility for Homekit integration. It is already done with Domoticz (https://www.domoticz.com/wiki/Homekit_Siri) is this something that can be incorporated to the package or is there an other solution for this?
Thanks in advance!
This may be relatively much work. I must then cross compile Homekit for all the different Synology NAS (archs) and implement it when I compile domoticz , but I will see how much work it is , before I dismiss it 8-)
Jumbotroll
Hi Jumbotroll, thank you for your answer. Just to be clear i was referring to this post. Can you maybe help with another solution?
Posted: Sunday 10 January 2016 12:26
by amwr
I just updated the package from 2.0.35xx to 2.0.4075-7.
Since then, Domoticz won't start anymore:
/usr/local/domoticz/bin/domoticz: error while loading shared libraries: libusb-1.0.so.0: cannot open shared object file: No such file or directory
The libs look like this:
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb-0.1.so.4 -> libusb-0.1.so.4.4.4
-rwxr-xr-x    1 domoticz root         27062 Jan 10 00:15 libusb-0.1.so.4.4.4
-rw-r--r--    1 domoticz root        118814 Jan 10 00:15 libusb-1.0.a
-rwxr-xr-x    1 domoticz root          1118 Jan 10 00:15 libusb-1.0.la
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb-1.0.so -> libusb-1.0.so.0.1.0
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb-1.0.so.0 -> libusb-1.0.so.0.1.0
-rw-r--r--    1 domoticz root         22314 Jan 10 00:15 libusb.a
-rwxr-xr-x    1 domoticz root          1359 Jan 10 00:15 libusb.la
lrwxrwxrwx    1 root     root            19 Jan 10 00:15 libusb.so -> libusb-0.1.so.4.4.4
What went wrong and how can I fix it?
amwr
Posted: Sunday 10 January 2016 13:37
by jumbotroll
amwr wrote:Hi
amwr
Fixed in 2.0.4078-7.
Jumbotroll
Posted: Sunday 10 January 2016 13:42
by smika
Here the same problem with a 716+ synology NAS.
Posted: Sunday 10 January 2016 14:21
by jumbotroll
smika wrote:Here the same problem with a 716+ synology NAS.
V2.4078 is uploaded.
Jumbotroll
Posted: Sunday 10 January 2016 14:38
by smika
Works perfect. Thanks for the great support.
Posted: Sunday 10 January 2016 17:45
by sincze
Did you allow the install packages from other (untrusted) communities option??
Sent from my SM-G925F using Tapatalk
Posted: Sunday 10 January 2016 18:44
by amwr
Jumbotroll
Works! What a great support, thanks!
Posted: Sunday 10 January 2016 22:07
by dtech
Jumbotroll
Jumbotroll,
Can you please let me know if problem with battery level is fixed ?
Posted: Monday 11 January 2016 12:08
by jumbotroll
dtech wrote:
Jumbotroll
Jumbotroll,
It's fixed in V2.4088, so in next update from me, battery levels with RFXcom devices work again.
Jumbotroll
Posted: Monday 11 January 2016 18:15
by dtech
jumbotroll wrote: It's fixed in V2.4088, so in next update from me, battery levels with RFXcom devices work again.
Jumbotroll
Thank you for this info.
Posted: Tuesday 12 January 2016 10:46
by cherowley
Hi!
Over the last few days I'm having the problem where the domoticz package on my sinology box stops running for no apparent reason.
I come to look at the domoticz web page but find its offline. The log doesn't show anything obvious.
It starts fine when selecting run and will continue but at some point stops again after say 10 - 30 hours.
Is there another log somewhere I can look at?
Any ideas? It was working fine until Friday ish.
I've added a couple of espeasy sensors if that makes any difference? Could they be overloading it with log entries or something?
Cheers!
Posted: Tuesday 12 January 2016 11:44
by gielie
harrytasker wrote:Affer getting it to work i am running into a new problem.
On adding the stick from the hardware menu, i see both programmed devices that added to the stick, one a dimmer and one wall plug.
Everything fine so far. When i test both they work fine. But like 5 minutes later all the nodes go dead.
I delete the stick and add it again and the nodes work again straight away but same thing happens again, all dead nodes.
And there is no way of getting it to work again besides removing the stick from the hardware tab and adding it again.
I can choose between ttyACM0 and ttyACM1, it doesnt matter what i choose, happens on both ports.
What is strange though, i dont have to change the stick physically from the front USB port? Is that normal?
Update: I installed Domoticz on my Windows 10 PC and the stick is running fine, network health is perfect, so i guess it must be something with the installation on the NAS?
I have the same problem on my 415play, i must conclude domoticz is not working verry well on synology, maybe i have to switch to a raspberry pi.
Dit u find any solution yet?
Posted: Wednesday 13 January 2016 19:05
by jumbotroll
UPDATE
Domoticz V2.4169.
New:
OpenZWave 1.4.3
Added SSL on port 8443
Added think-theme style.
Posted: Thursday 14 January 2016 1:49
by truongdq54
Hi jumbotroll,
Great work!
I would be very appreciated if you could post a tutorial how you compile domoticz packages on Synology.
Regards,
Truong
Posted: Thursday 14 January 2016 7:34
by dtech
jumbotroll wrote:UPDATE
Domoticz V2.4169.
New:
OpenZWave 1.4.3
I can confirm that everything is working fine, no issue found. Thank you
Posted: Thursday 14 January 2016 23:05
by dtech
Domoticz V2.4169.
New:
OpenZWave 1.4.3
Jumbotroll,
I already have ssl certificate on the synology, do you know how can I use it with the domoticz. If I enter domoticz with the port 8443 I got message that certyficate is not valid. On be other synology services certyfiace is valid.
Posted: Thursday 14 January 2016 23:44
by jumbotroll
dtech wrote: I already have ssl certificate on the synology, do you know how can I use it with the domoticz. If I enter domoticz with the port 8443 I got message that certyficate is not valid. On be other synology services certyfiace is valid.
certificate server_cert.pem is located in the folder usr/local/domoticz.
I do not have much time to test this myself.
