Page 27 of 49
Re: Dashticz - Module - Garbage collector
Posted: Thursday 20 December 2018 22:58
by dvwerkhoven
Is it also possible to integrate the https://inzamelkalender.gad.nl/ for Hilversum ?
Posted: Tuesday 01 January 2019 11:52
by Ynco
From 2019.01.01 mijnafvalwijzer doesn't work anymore ;( maybe someone knows which service works for Ede- i tried few but nothing works.
Posted: Tuesday 01 January 2019 15:37
by HansieNL
@Ynco : can you check mijnafvalwijzer again? Yesterday it didn't show info here, but now it does.
Posted: Tuesday 01 January 2019 20:28
by Ynco
No, still the same "geen gegevens gevonden". I got on my phone message that from 2019 mijn avfal wijzer stops working. i had to download new app- ACV.
Posted: Friday 04 January 2019 12:38
by cyberclwn
Ynco wrote: Tuesday 01 January 2019 11:52 From 2019.01.01 mijnafvalwijzer doesn't work anymore ;( maybe someone knows which service works for Ede- i tried few but nothing works.
I emailed with mijnafvalwijzer.nl about the garbage information of the ACV.
They said the ACV isn't working together with mijnafvalwijzer.nl anymore. So no information of ACV on mijnafvalwijzer.nl anymore.
but ACV has it own website/url:
http://www.acv-afvalkalender.nl/ which calls:
https://afvalportaal.2go-mobile.com/modules/f8e2844a-095e-48f9-9f98-71fceb51d2c3/kalender/calendar.html?294321&<street>---<number>%20%20%20---<postalcode>---EDE%20GLD---EDE
But my programming skills aren't up to level to get this fixed in the script.
Maybe it helps you guys :)
Posted: Sunday 20 January 2019 14:54
by evildonkey
And knows if i can get it to work with the Gemeente Leiden?
Posted: Monday 21 January 2019 19:17
by Lokonli
evildonkey wrote: Sunday 20 January 2019 14:54 And knows if i can get it to work with the Gemeente Leiden?
Do you know whether Leiden provides a link to download the garbage calendar data?
Posted: Monday 21 January 2019 20:01
by evildonkey
could not find it on the website, i will send them a email.
Posted: Tuesday 22 January 2019 19:03
by evildonkey
Lokonli wrote: Monday 21 January 2019 19:17
If i put my postcode in there i can see when.
https://gemeente.leiden.nl/inwoners-en- ... ema-afval/
Posted: Tuesday 29 January 2019 20:09
by clsgroen2
dvwerkhoven wrote: Thursday 20 December 2018 22:58 Is it also possible to integrate the https://inzamelkalender.gad.nl/ for Hilversum ?
You can use ical for Hilversum eo:
- go to https://inzamelkalender.gad.nl/
- enter zipcode and housenr
- click 'naar maand- en jaarkalender'
- copy the url and configure in dashticz
Posted: Saturday 09 February 2019 23:55
by BarryT
When using garbage, my dashticz keeps saying that i need a php enabled webserver..?
I'm trying to use mijnafvalwijzer, but whatever i do, it doesnt work at all :(
What did i doing wrong?
Posted: Sunday 10 February 2019 0:05
by HansieNL
@BarryT : Since version 2.4.6 for some functions a webserver with php is needed. It's described in the wiki.
Posted: Sunday 10 February 2019 0:11
by BarryT
I have nginx with php7.2 and the php-mod-curl installed..?
Posted: Sunday 10 February 2019 1:14
by HansieNL
@BarryT : have you checked if your PHP is running fine. Can you check with http://<nginx-ip>:<nginx-port>/index.php
Posted: Sunday 10 February 2019 1:20
by BarryT
My php info is correct and the dashticz also works correct.. its just the garbage wich gives an error :(
Posted: Sunday 10 February 2019 10:06
by ehelms
Do any one know the code for ACV afvalwijzer?
Posted: Tuesday 12 February 2019 0:01
by BarryT
I'm going to test on another server these days, maybe the curl didnt do its job correctly...
I'll let you know asap :)
Posted: Tuesday 12 February 2019 8:29
by Lokonli
BarryT wrote: Tuesday 12 February 2019 0:01 I'm going to test on another server these days, maybe the curl didnt do its job correctly...
You might need to install php-xml as well.
Posted: Tuesday 12 February 2019 8:38
by BarryT
Lokonli wrote: Tuesday 12 February 2019 8:29
Okay, thnx for the tip!💪🏽
Posted: Sunday 17 March 2019 11:56
by naitsirhc
Could someone give me a walk through to configure my gmail calendar (Ical) with this nice add on?
Until now i've got:
config['garbage_icalurl'] = 'https://calendar.google.com/calendar/ic ... /basic.ics';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
//gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
//pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
//Restabfallbehaelter: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
//papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
//kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
//brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
//black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
Restabfallbehaelter: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
//kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Unfortunately my Dashticz does show up, but the garbage add on shows loading and doesn't continue....
thanks in advance
