Page 27 of 123
Posted: Tuesday 24 January 2017 9:18
by galadril
The humidity values appeared automaticly this morning! And I could also add the gateway.
Would love to see the alarm feature of the gateway implemented
Thanks guys for your work.
Posted: Tuesday 24 January 2017 9:23
by woody4165
corbin wrote:woody4165 wrote:
I still don't see the other fileds in the Xiaomi Gtw HW setup.
If you have ruled out it being caused by caching, then you don't have the latest web files for whatever reason, or there could be a bug in the web page. Do you see in errors in the chrome developer console?
I see this error on chrome console:
Failed to load resource: http://192.168.xx.xx:xxxx/js/jquery-1.12.0.min.js
Posted: Tuesday 24 January 2017 10:20
by corbin
I'm not seeing that error, but... now my hardware page is not working! There was recently a pull request that changed the hardware page code, and it might have caused our problem.
Posted: Tuesday 24 January 2017 10:31
by woody4165
Now, with latest beta 3.6454, I don't see anymore the previous error.
I can see the HW page, but still no other fields in the Xiaomi Gtw.
As also nogo said, the beta prior 3.6441 was working fine, at least at me.
Posted: Tuesday 24 January 2017 12:21
by joebar
woody4165 wrote:Now, with latest beta 3.6454, I don't see anymore the previous error.
Same here, just compiled Corbin's version and ran that for test, that displays the full gateway options so something is off in the official beta channel
Posted: Tuesday 24 January 2017 13:05
by zaraki673
it's work now, with v3.6464
Posted: Tuesday 24 January 2017 13:10
by woody4165
Yeah!
It's working again...
Posted: Tuesday 24 January 2017 13:53
by jjnj
Hi guys, again, loving your work on Domoticz!
I have one question regarding the button and the selector switch. With the long press, the switch is triggered twice, once for press, once for release. Normally this wouldn't be a big issue because sending a on action twice still will result in an on action. In my case it's different since I want to use it as a toggle switch. Long press > toggle switch. Now it toggles: switch is off > long press xiaomi button > switch on > release long press button > switch off.
How can i fix this?
Posted: Tuesday 24 January 2017 14:34
by nogo
It's OK for me.
With the last version 3.6478
Thanks everybody or your really good job and actions !!!
Posted: Tuesday 24 January 2017 17:00
by jjnj
nogo wrote:It's OK for me.
The long press is working you mean?
Posted: Tuesday 24 January 2017 17:22
by deennoo
jjnj wrote:Hi guys, again, loving your work on Domoticz!
How can i fix this?
Which switch ?
Round one ?
Wired 1 button
Wired 2 buttons
Wireless 1 button
Wireless 2 button ?
Be more precise please ! There is 5 switch now.
And give use which domoticz version you have ? Official beta ? Or corbin github which date ?
Just update to last domoticz beta and looks ok for me.
Just waiting to get rotation value for cube on a text device. And 2 switch on/off for wired 2 button.
Posted: Tuesday 24 January 2017 17:42
by jjnj
deennoo wrote:
Which switch ?
Round one ?
Wired 1 button
Wired 2 buttons
Wireless 1 button
Wireless 2 button ?
I wasn't aware other products also supported long press. My question is regarding the round one supporting 1 click, double click and long press.
I'm using the latest beta 3.6478 on windows and as for as i know the latest available software version of the Xiaomi hub..
It wouldn't be an issue if you would send an on or off command. It simply would power on twice, in this case because it's a toggle it creates a problem.
Posted: Tuesday 24 January 2017 18:08
by joebar
Strange, mine (the round wireless switch) does react as expected, click, double click and long press is detected without the release as a new trigger. Does the xiaomi app detect it properly?
Posted: Tuesday 24 January 2017 18:11
by joebar
Probably known already to the devs, but I stumbled onto this sheet where the devices and the data types is explained.
https://translate.google.com/translate? ... ition.html
You can see that the zigbee smart socket sends the status, voltage, power and even energy costs
Posted: Tuesday 24 January 2017 18:12
by levynger
jjnj wrote:deennoo wrote:
Which switch ?
Round one ?
Wired 1 button
Wired 2 buttons
Wireless 1 button
Wireless 2 button ?
This is currently by design. And can be changed though.
By adding another level to the selector for 'long press release'
can change that if this make more sense and make a pull request to @corbin later on.
After I figure out how to create different index devices from the same id.
Having trouble with it, as I'm trying to change the switch selectors of the Aqara to on/off type.
Posted: Tuesday 24 January 2017 18:16
by deennoo
How can i fix this?
Ok understand and test it, got the same probleme !
Press for long click : set selector to long click
Release long click : set selector to long click again.
Press for long clik at 18:13:55
Release long click at 18:13:58
Domoticz beta 3.6478
As i got a script who run when selector : long click he run twice
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Posted: Tuesday 24 January 2017 18:46
by deennoo
Depending of usage !
For a ringbell
If long click : ring on, if long click release ring off.
On my case i just need long click order to set a milight bulb on disco mode (don't care if long click begin or end)
Maybe can you ask to gizmocuz some help about this.
Posted: Tuesday 24 January 2017 19:24
by jjnj
It would be great if it could be changed.
Just out of curiosity, why is it by design?
Posted: Tuesday 24 January 2017 20:48
by levynger
Sorry, i will rephrase, it was discussed previously,
But didn't find good use case, so it was left that way.
I will change it and create pull request for corbin's git hub.
Posted: Tuesday 24 January 2017 21:26
by Mat2Vence
The last beta update has killed my domoticz installation... nothing working anymore. I have "Domoticz offline" that is shown".
Any idea how I could recover from command line? I am running on ubuntu.
Ok I've found how to do it. And it's working back.
