Dashticz - Module - Garbage collector Topic is solved
amauryverschooren
Re: Dashticz - Module - Garbage collector
Post by amauryverschooren »
HansieNL wrote: Thursday 06 September 2018 22:27
amauryverschooren wrote: Thursday 06 September 2018 21:59
HansieNL wrote: Thursday 06 September 2018 21:55
Dear Amaury,
Maybe you can post your config.js as code. You can do that by selecting </>
Here you go.
var config = {}
config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
config['domoticz_ip'] = 'http://192.168.0.185:8080';
config['app_title'] = 'Dashboard';
config['domoticz_refresh'] = '0.1';
config['default_news_url'] = '';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '10';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'hours';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = 0;
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'XXX';
config['gm_zoomlevel'] = '8';
config['gm_latitude'] = 'XXX';
config['gm_longitude'] = 'XXX';
config['wu_api'] = 'xzxzzxz';
config['wu_city'] = 'Rapenberg';
config['wu_name'] = 'in Bazel';
config['wu_country'] = 'BE';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 0;
config['spot_clientid'] = 'xzxzx';
config['garbage_company'] = 0;
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 0;
config['garbage_street'] = 0;
config['garbage_housenumber'] = 0;
config['garbage_maxitems'] = 0;
config['garbage_width'] = 0;
config['selector_instead_of_buttons'] = 0;
config['auto_positioning'] = 0;
config['use_favorites'] = 1;
config['last_update'] = 0;
config['hide_topbar'] = 0;
config['hide_seconds'] = 1;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 0;
config['hide_mediaplayer'] = 0;
var trashcan = {}
trashcan.ophaalkalender = { trashapp: 'zxx', width:6,street:'zxzx',zxzx:'zxzx', country:'BE' }
var trashnames = {}
trashnames['Rest'] = 'Restafval';
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
var trashcolors = {}
trashcolors['Gft'] = 'Lime';
trashcolors['Pmd'] = 'Orange';
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.zx/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = 'xxxxxxxxx';
var _WEATHER_CITY = 'Kruibeke';
var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'BE';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = false; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
// Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer'
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
{"track":2,"name":"Radio 538","file":"http://vip-icecast.538.lw.triple-it.nl/RADIO538_MP3"},
{"track":3,"name":"Arrow Classic Rock","file":"http://www.garnierstreamingmedia.com/as ... stream=205"},
{"track":4,"name":"Radio Veronica","file":"http://live.icecast.kpnstreaming.nl/sky ... GSTR09.mp3"},
{"track":5,"name":"Q-music","file":"http://live.icecast.kpnstreaming.nl/omr ... bantHq.m3u"},
var buttons = {}
buttons.webcam1 = { width:6, isimage:true, refresh:5000, image: 'http://sensored/image.jpg', url: 'http://sensored/image.jpg' }
buttons.webcam2 = { width:6, isimage:true, refresh:5000, image: 'sensored' }
buttons.buienradar = {width:4, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=sensored', url: 'http://www.weeronline.nl/Europa/Nederland/Dordrecht/sensored'}
buttons.nzbget = {width:12, icon: 'fa-download', title: 'NZBget', url: 'http://sensored:6789'}
buttons.log = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
//Groepen & Scenes
//Schakelaars
//Overige
blocks[6] = {}
blocks[6]['width'] = 6;
blocks[6]['title'] = 'Temp. Kamer Amaury:'
blocks[6]['switch'] = true;
blocks[7] = {}
blocks[7]['width'] = 6;
blocks[7]['title'] = 'Temp. Kamer Valerie:'
blocks[7]['switch'] = true;
blocks[8] = {}
blocks[8]['width'] = 6;
blocks[8]['title'] = 'Temp. Woonkamer:'
blocks[8]['switch'] = true;
//Titels
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Temperatuur sensors';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Scenes';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Schakelaars';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Weer';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Radio';
// Kolommen
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['clock','sunrise', 'currentweather_big']
columns[1]['width'] = 2;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1','6','7','8','blocktitle_2']
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_3','1','2','5','blocktitle_4','weather']
columns[3]['width'] = 5;
columns[4] = {}
columns[4]['blocks'] = ['currentweather_big']
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = [buttons.buienradar, buttons.radio, buttons.nunl]
columns[5]['width'] = 6;
columns[6] = {}
columns[6]['blocks'] = [trashcan.ophaalkalender]
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg9.jpg';
screens[1]['background_night'] = 'bg12.jpg';
screens[2] = {}
screens[2]['background'] = 'bg9.jpg';
screens[2]['background_night'] = 'bg12.jpg';
screens[2]['columns'] = [4,5,6]
These variables are empty
You can take a look at the wiki https://www.domoticz.com/wiki/Dashticz_ ... _Collector how to do that.
I don't know what version of Dashticz you are using, because variables all have changed. Now it's a mix of very old and new in your config.js.
TIP: Remove personal info from your config.js if you post on a forum.
Do i need to use the icalurl? Don't know what it is and if i should use it. When i fill in the other values, my dashticz won't load
HansieNL
Post by HansieNL »
@amauryverschooren :
These settings are working here with latest stable (master):
config['garbage_company'] = 'ophaalkalender';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '9150';
config['garbage_street'] = 'kerkstraat';
config['garbage_housenumber'] = '';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '';
config['garbage_width'] = '6';
columns[1] = {}
columns[1]['blocks'] = ['garbage']
columns[1]['width'] = 5;
Blah blah blah
hve22
Post by hve22 »
Hi Guys,
After a year of working nicely, this week the garbage collector module isn't working any more.
Somehow it cannot find the desired data.
Is there a change on the provider end???
[I'm using 'HVC' data.]
jdemas
Post by jdemas »
hi rob,
i use rd4 garbage collector most is working fine but there are 2 problems when there is snoeiafval it shows as GFT and best-tas isn't showing at all
where do i have to look to solve this problem?
reagrds Jeffrey
jake
Post by jake »
hve22 wrote:Hi Guys,
Same problem, also hvc
The following link gives a solution to the hvc problem:
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
However, for Dashticz, the real work to collect data from HVC is done from the website www.dashticz.nl We therefore can't solve it locally and an update is needed on the server side.
Recky
Domoticz version: Latest
Post by Recky »
Hi, is it possible to add Reinis?
https://www.reinis.nl/afvalkalender/
Also, i can image its a huge task to add and maintain all these different calendars. Is this actually still being worked on?
jake
Post by jake »
@robgeerts, can you please have a look at the changed HVC request? Since the old method is offline for some weeks now, I start to realize how much I liked it in the first place!
Thanks in advance.
kiddigital
Post by kiddigital »
+1, me and my family already mis it (the HVC data)
jake
Post by jake »
For the moment I am back to the old guesswork: put the garbage containter outside with the same color as those from some early neighbours.
Rob, your help to include the changed script into the 'garbage-code' on your server, is more and more welcome every passing day.
gielie
Domoticz version: latest β
Post by gielie »
I have a strange thing in my garbage layout, it shows a time (@00:00). It worked fine before but i don't know when this changed but it is really annoying with a time label in it.
Does someone know what is going wrong?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
HansieNL
Post by HansieNL »
@gielie : If you change in your garbage.js this.displayDate = garbage.date.locale(settings['calendarlanguage']).format(settings['calendarformat']); to this.displayDate = garbage.date.locale(settings['calendarlanguage']).format('l'); you get the old date format.
This issue is already logged in GitHub https://github.com/Dashticz/dashticz_v2/issues/375
Blah blah blah
gielie
Post by gielie »
HansieNL wrote: Monday 08 October 2018 16:48 @gielie : If you change in your garbage.js this.displayDate = garbage.date.locale(settings['calendarlanguage']).format(settings['calendarformat']); to this.displayDate = garbage.date.locale(settings['calendarlanguage']).format('l'); you get the old date format.
Yes, youre my hero. I missed it in the github issue list.
- FIBARO FGS223
- Toon
- Kodi Media Server
edge
Post by edge »
Somehow I do not get it working. My local garbage collector is using "deafvalapp". So my config.js contains:
config['garbage_company'] = 'deafvalapp';
config['garbage_zipcode'] = '1234AA';
config['garbage_street'] = '';
config['garbage_housenumber'] = '1';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = false;
config['garbage'] = {
    gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
    pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
    rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
    papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
    kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
    brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
    black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
    milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
    kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
When I load my dashticz dashboard and using the 'inspect' within Chrome i see the following error:
jquery.min.js:4 GET https://dashticz.nl/afval/?service=deaf ... AA&nr=1&t= net::ERR_NAME_RESOLUTION_FAILED
I don't get it, why is it querying the (non-existing?) dashticz.nl domain?
Lokonli
Post by Lokonli »
edge wrote: Wednesday 24 October 2018 20:17 Somehow I do not get it working. My local garbage collector is using "deafvalapp". So my config.js contains:
Read this topic: viewtopic.php?f=67&t=24907
edge
Post by edge »
Lokonli wrote: Wednesday 24 October 2018 20:46
Oops.. Missed that. Thanks!
edge
Post by edge »
Sorry, another question :)
The garbage module is working for GFT but not for other garbagestreams.
My location uses 'deafvalapp'. If I follow the URL
http://dataservice.deafvalapp.nl/datase ... B&huisnr=X
The output is
ZAK_BLAUW;21-12-2018;23-11-2018;26-10-2018;28-09-2018;31-08-2018;03-08-2018;06-07-2018;08-06-2018;11-05-2018;13-04-2018;16-03-2018;16-02-2018;19-01-2018;
PBP;28-12-2018;14-12-2018;30-11-2018;16-11-2018;02-11-2018;19-10-2018;05-10-2018;21-09-2018;07-09-2018;24-08-2018;10-08-2018;27-07-2018;13-07-2018;29-06-2018;15-06-2018;01-06-2018;18-05-2018;04-05-2018;20-04-2018;06-04-2018;23-03-2018;09-03-2018;23-02-2018;09-02-2018;26-01-2018;12-01-2018;
GFT;28-12-2018;21-12-2018;14-12-2018;07-12-2018;30-11-2018;23-11-2018;16-11-2018;09-11-2018;02-11-2018;26-10-2018;19-10-2018;12-10-2018;05-10-2018;28-09-2018;21-09-2018;14-09-2018;07-09-2018;31-08-2018;24-08-2018;17-08-2018;10-08-2018;03-08-2018;27-07-2018;20-07-2018;13-07-2018;06-07-2018;29-06-2018;22-06-2018;15-06-2018;08-06-2018;01-06-2018;25-05-2018;18-05-2018;11-05-2018;04-05-2018;28-04-2018;20-04-2018;13-04-2018;06-04-2018;30-03-2018;23-03-2018;16-03-2018;09-03-2018;02-03-2018;23-02-2018;16-02-2018;09-02-2018;02-02-2018;26-01-2018;19-01-2018;12-01-2018;05-01-2018;
So there are 3 streams "ZAK_BLAUW", "PBP" and "GFT". In my config I am using the following lines:
		"gft": 	{kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
		"pbp": 		{kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
		"zak_blauw": 	{kliko: 'blue', code: '#153477', name: 'ZAK', icon: 'img/garbage/kliko_blue.png'},
But somehow only the "gft" is working. PBD & zak_blauw aren't working... What can I do to make it work?
Lokonli
Post by Lokonli »
edge wrote: Tuesday 30 October 2018 22:12 Sorry, another question :)
The output is
The garbage module uses an additional step in the name mapping, which is by default initialized as follows:
config['garbage_mapping'] = {
      gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
      pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
      rest: ['restafval'],
      papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
      kca: ['chemisch', 'kca','kga'],
      brown: ['brown', 'verre'],
      black: ['black', 'zwart'],
      milieu: ['milieu'],
      kerstboom: ['kerst'],
In your case it should work with something like the following settings: (I did not test)
		"pmd": 	{kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
		"rest": 	{kliko: 'blue', code: '#153477', name: 'ZAK', icon: 'img/garbage/kliko_blue.png'}
      gft: ['gft'],
      pmd: ['pbp'],
      rest: ['blauw'],
edge
Post by edge »
Many thanks! Got it working.
		gft:['gft'],
		pmd:['pbp'],
		zak_blauw:['zak']
NicoLP
Post by NicoLP »
ia het mogelijk om deze garbage plaats ook in te lezen
deze lijkt erg op de zuidhorn koppeling
https://afval.katwijk.nl/nc/afvalkalender/
bv postcode 2221sb nummer 19
Lokonli
Post by Lokonli »
NicoLP wrote: Thursday 22 November 2018 23:32 ia het mogelijk om deze garbage plaats ook in te lezen
Yes, I think so. I've created a PR. Wait until Rob merges it into a new beta release.
