Do i need to use the icalurl? Don't know what it is and if i should use it. When i fill in the other values, my dashticz won't loadHansieNL wrote: ↑Thursday 06 September 2018 22:27These variables are emptyamauryverschooren wrote: ↑Thursday 06 September 2018 21:59Here you go.
- Spoiler: show
var config = {} config['language'] = 'nl_NL'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE config['domoticz_ip'] = 'http://192.168.0.185:8080'; config['app_title'] = 'Dashboard'; config['domoticz_refresh'] = '0.1'; config['dashticz_refresh'] = '60'; config['default_news_url'] = ''; config['news_scroll_after'] = '7'; config['standby_after'] = 0; config['auto_swipe_back_to'] = 1; config['auto_swipe_back_after'] = '10'; config['auto_slide_pages'] = 0; config['slide_effect'] = 'slide'; config['standard_graph'] = 'hours'; config['language'] = 'nl_NL'; config['timeformat'] = 'DD-MM-YY HH:mm'; config['calendarformat'] = 'dd DD.MM HH:mm'; config['calendarlanguage'] = 'nl_NL'; config['calendarurl'] = 0; config['boss_stationclock'] = 'RedBoss'; config['gm_api'] = 'XXX'; config['gm_zoomlevel'] = '8'; config['gm_latitude'] = 'XXX'; config['gm_longitude'] = 'XXX'; config['wu_api'] = 'xzxzzxz'; config['wu_city'] = 'Rapenberg'; config['wu_name'] = 'in Bazel'; config['wu_country'] = 'BE'; config['idx_moonpicture'] = 0; config['switch_horizon'] = 0; config['host_nzbget'] = 0; config['spot_clientid'] = 'xzxzx'; config['garbage_company'] = 0; config['garbage_icalurl'] = 0; config['garbage_zipcode'] = 0; config['garbage_street'] = 0; config['garbage_housenumber'] = 0; config['garbage_maxitems'] = 0; config['garbage_width'] = 0; config['selector_instead_of_buttons'] = 0; config['auto_positioning'] = 0; config['use_favorites'] = 1; config['last_update'] = 0; config['hide_topbar'] = 0; config['hide_seconds'] = 1; config['hide_seconds_stationclock'] = 0; config['use_fahrenheit'] = 0; config['use_beaufort'] = 0; config['translate_windspeed'] = 1; config['static_weathericons'] = 0; config['hide_mediaplayer'] = 0; var trashcan = {} trashcan.ophaalkalender = { trashapp: 'zxx', width:6,street:'zxzx',zxzx:'zxzx', country:'BE' } var trashnames = {} trashnames['Rest'] = 'Restafval'; trashnames['Gft'] = 'GFT'; trashnames['Pmd'] = 'Plastic'; var trashcolors = {} trashcolors['Gft'] = 'Lime'; trashcolors['Pmd'] = 'Orange'; var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.zx/domoticz/switch_horizon.php'; var _APIKEY_WUNDERGROUND = 'xxxxxxxxx'; var _WEATHER_CITY = 'Kruibeke'; var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY var _WEATHER_COUNTRY = 'BE'; var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning var _USE_FAVORITES = false; //only used when using auto positioning var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock var _HIDE_MEDIAPLAYER_WHEN_OFF = false; //when you have a mediaplayer connected, hide it if nothing is playing var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen'; var _USE_FAHRENHEIT = false; var _USE_BEAUFORT = false; //Bft instead of m/s var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes) var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds var _SHOW_LASTUPDATE = true; var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm'; var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip' // Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer' var _STREAMPLAYER_TRACKS = [ {"track":1,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"}, {"track":2,"name":"Radio 538","file":"http://vip-icecast.538.lw.triple-it.nl/RADIO538_MP3"}, {"track":3,"name":"Arrow Classic Rock","file":"http://www.garnierstreamingmedia.com/as ... stream=205"}, {"track":4,"name":"Radio Veronica","file":"http://live.icecast.kpnstreaming.nl/sky ... GSTR09.mp3"}, {"track":5,"name":"Q-music","file":"http://live.icecast.kpnstreaming.nl/omr ... bantHq.m3u"}, ]; var buttons = {} buttons.webcam1 = { width:6, isimage:true, refresh:5000, image: 'http://sensored/image.jpg', url: 'http://sensored/image.jpg' } buttons.webcam2 = { width:6, isimage:true, refresh:5000, image: 'sensored' } buttons.buienradar = {width:4, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=sensored', url: 'http://www.weeronline.nl/Europa/Nederland/Dordrecht/sensored'} buttons.radio = {width:12, image: 'img/radio_on.png', title: 'Radio', url: 'http://nederland.fm'} buttons.nzbget = {width:12, icon: 'fa-download', title: 'NZBget', url: 'http://sensored:6789'} buttons.log = {key:'log', width:12, icon:'fa-microchip', title: 'Domoticz Log', log:true, level: 2} //CUSTOM POSITIONING: //defining wich blocks to show, de numbers represents the IDX of the device in Domoticz //only define if you want to use a custom width instead of the default var blocks = {} //Groepen & Scenes //Schakelaars //Overige blocks[6] = {} blocks[6]['width'] = 6; blocks[6]['title'] = 'Temp. Kamer Amaury:' blocks[6]['switch'] = true; blocks[7] = {} blocks[7]['width'] = 6; blocks[7]['title'] = 'Temp. Kamer Valerie:' blocks[7]['switch'] = true; blocks[8] = {} blocks[8]['width'] = 6; blocks[8]['title'] = 'Temp. Woonkamer:' blocks[8]['switch'] = true; //Titels blocks['blocktitle_1'] = {} blocks['blocktitle_1']['type'] = 'blocktitle'; blocks['blocktitle_1']['title'] = 'Temperatuur sensors'; blocks['blocktitle_2'] = {} blocks['blocktitle_2']['type'] = 'blocktitle'; blocks['blocktitle_2']['title'] = 'Scenes'; blocks['blocktitle_3'] = {} blocks['blocktitle_3']['type'] = 'blocktitle'; blocks['blocktitle_3']['title'] = 'Schakelaars'; blocks['blocktitle_4'] = {} blocks['blocktitle_4']['type'] = 'blocktitle'; blocks['blocktitle_4']['title'] = 'Weer'; blocks['blocktitle_5'] = {} blocks['blocktitle_5']['type'] = 'blocktitle'; blocks['blocktitle_5']['title'] = 'Radio'; // Kolommen var columns = {} columns[1] = {} columns[1]['blocks'] = ['clock','sunrise', 'currentweather_big'] columns[1]['width'] = 2; columns[2] = {} columns[2]['blocks'] = ['blocktitle_1','6','7','8','blocktitle_2'] columns[2]['width'] = 5; columns[3] = {} columns[3]['blocks'] = ['blocktitle_3','1','2','5','blocktitle_4','weather'] columns[3]['width'] = 5; columns[4] = {} columns[4]['blocks'] = ['currentweather_big'] columns[4]['width'] = 6; columns[5] = {} columns[5]['blocks'] = [buttons.buienradar, buttons.radio, buttons.nunl] columns[5]['width'] = 6; columns[6] = {} columns[6]['blocks'] = [trashcan.ophaalkalender] //if you want to use multiple screens, use the code below: var screens = {} screens[1] = {} screens[1]['background'] = 'bg9.jpg'; screens[1]['background_night'] = 'bg12.jpg'; screens[1]['columns'] = [1,2,3] screens[2] = {} screens[2]['background'] = 'bg9.jpg'; screens[2]['background_night'] = 'bg12.jpg'; screens[2]['columns'] = [4,5,6]
You can take a look at the wiki https://www.domoticz.com/wiki/Dashticz_ ... _Collector how to do that.
I don't know what version of Dashticz you are using, because variables all have changed. Now it's a mix of very old and new in your config.js.
TIP: Remove personal info from your config.js if you post on a forum.
Dashticz - Module - Garbage collector Topic is solved
Re: Dashticz - Module - Garbage collector
- HansieNL
@amauryverschooren :
These settings are working here with latest stable (master):
config['garbage_company'] = 'ophaalkalender';
config['garbage_icalurl'] = '';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '9150';
config['garbage_street'] = 'kerkstraat';
config['garbage_housenumber'] = '';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = '';
config['garbage_width'] = '6';
columns[1] = {}
columns[1]['blocks'] = ['garbage']
columns[1]['width'] = 5;
Blah blah blah
Hi Guys,
After a year of working nicely, this week the garbage collector module isn't working any more.
Somehow it cannot find the desired data.
Is there a change on the provider end???
[I'm using 'HVC' data.]
hi rob,
i use rd4 garbage collector most is working fine but there are 2 problems when there is snoeiafval it shows as GFT and best-tas isn't showing at all
where do i have to look to solve this problem?
reagrds Jeffrey
reagrds Jeffrey
Same problem, also hvchve22 wrote:Hi Guys,
The following link gives a solution to the hvc problem:
https://r.tapatalk.com/shareLink?url=ht ... are_type=t
However, for Dashticz, the real work to collect data from HVC is done from the website www.dashticz.nl We therefore can't solve it locally and an update is needed on the server side.
- Domoticz version: Latest
Hi, is it possible to add Reinis?
https://www.reinis.nl/afvalkalender/
Also, i can image its a huge task to add and maintain all these different calendars. Is this actually still being worked on?
@robgeerts, can you please have a look at the changed HVC request? Since the old method is offline for some weeks now, I start to realize how much I liked it in the first place!
Thanks in advance.
Thanks in advance.
- kiddigital
+1, me and my family already mis it (the HVC data)
For the moment I am back to the old guesswork: put the garbage containter outside with the same color as those from some early neighbours.
Rob, your help to include the changed script into the 'garbage-code' on your server, is more and more welcome every passing day.
- gielie
- Domoticz version: latest β
I have a strange thing in my garbage layout, it shows a time (@00:00). It worked fine before but i don't know when this changed but it is really annoying with a time label in it.
Does someone know what is going wrong?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- HansieNL
@gielie : If you change in your garbage.js this.displayDate = garbage.date.locale(settings['calendarlanguage']).format(settings['calendarformat']); to this.displayDate = garbage.date.locale(settings['calendarlanguage']).format('l'); you get the old date format.
This issue is already logged in GitHub https://github.com/Dashticz/dashticz_v2/issues/375
Blah blah blah
- gielie
Yes, youre my hero. I missed it in the github issue list.HansieNL wrote: ↑Monday 08 October 2018 16:48 @gielie : If you change in your garbage.js this.displayDate = garbage.date.locale(settings['calendarlanguage']).format(settings['calendarformat']); to this.displayDate = garbage.date.locale(settings['calendarlanguage']).format('l'); you get the old date format.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Somehow I do not get it working. My local garbage collector is using "deafvalapp". So my config.js contains:
When I load my dashticz dashboard and using the 'inspect' within Chrome i see the following error:
jquery.min.js:4 GET https://dashticz.nl/afval/?service=deaf ... AA&nr=1&t= net::ERR_NAME_RESOLUTION_FAILED
I don't get it, why is it querying the (non-existing?) dashticz.nl domain?
config['garbage_company'] = 'deafvalapp';
config['garbage_zipcode'] = '1234AA';
config['garbage_street'] = '';
config['garbage_housenumber'] = '1';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = false;
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
Read this topic: viewtopic.php?f=67&t=24907edge wrote: ↑Wednesday 24 October 2018 20:17 Somehow I do not get it working. My local garbage collector is using "deafvalapp". So my config.js contains:
When I load my dashticz dashboard and using the 'inspect' within Chrome i see the following error:Code: Select all
config['garbage_company'] = 'deafvalapp'; config['garbage_icalurl'] = 0; config['garbage_zipcode'] = '1234AA'; config['garbage_street'] = ''; config['garbage_housenumber'] = '1'; config['garbage_maxitems'] = '12'; config['garbage_width'] = '12'; config['garbage_hideicon'] = 0; config['garbage_use_names'] = true; config['garbage_use_colors'] = true; config['garbage_icon_use_colors'] = true; config['garbage_use_cors_prefix'] = false; config['garbage'] = { gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'}, pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'}, rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'}, papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'}, kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'}, brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'}, black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'}, milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'}, kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'}, };
Oops.. Missed that. Thanks!Lokonli wrote: ↑Wednesday 24 October 2018 20:46Read this topic: viewtopic.php?f=67&t=24907edge wrote: ↑Wednesday 24 October 2018 20:17 Somehow I do not get it working. My local garbage collector is using "deafvalapp". So my config.js contains:
Sorry, another question
The garbage module is working for GFT but not for other garbagestreams.
My location uses 'deafvalapp'. If I follow the URL
http://dataservice.deafvalapp.nl/datase ... B&huisnr=X
The output is
So there are 3 streams "ZAK_BLAUW", "PBP" and "GFT". In my config I am using the following lines:
But somehow only the "gft" is working. PBD & zak_blauw aren't working... What can I do to make it work?
The output is
ZAK_BLAUW;21-12-2018;23-11-2018;26-10-2018;28-09-2018;31-08-2018;03-08-2018;06-07-2018;08-06-2018;11-05-2018;13-04-2018;16-03-2018;16-02-2018;19-01-2018;
PBP;28-12-2018;14-12-2018;30-11-2018;16-11-2018;02-11-2018;19-10-2018;05-10-2018;21-09-2018;07-09-2018;24-08-2018;10-08-2018;27-07-2018;13-07-2018;29-06-2018;15-06-2018;01-06-2018;18-05-2018;04-05-2018;20-04-2018;06-04-2018;23-03-2018;09-03-2018;23-02-2018;09-02-2018;26-01-2018;12-01-2018;
GFT;28-12-2018;21-12-2018;14-12-2018;07-12-2018;30-11-2018;23-11-2018;16-11-2018;09-11-2018;02-11-2018;26-10-2018;19-10-2018;12-10-2018;05-10-2018;28-09-2018;21-09-2018;14-09-2018;07-09-2018;31-08-2018;24-08-2018;17-08-2018;10-08-2018;03-08-2018;27-07-2018;20-07-2018;13-07-2018;06-07-2018;29-06-2018;22-06-2018;15-06-2018;08-06-2018;01-06-2018;25-05-2018;18-05-2018;11-05-2018;04-05-2018;28-04-2018;20-04-2018;13-04-2018;06-04-2018;30-03-2018;23-03-2018;16-03-2018;09-03-2018;02-03-2018;23-02-2018;16-02-2018;09-02-2018;02-02-2018;26-01-2018;19-01-2018;12-01-2018;05-01-2018;
"gft": {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
"pbp": {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
"zak_blauw": {kliko: 'blue', code: '#153477', name: 'ZAK', icon: 'img/garbage/kliko_blue.png'},
The garbage module uses an additional step in the name mapping, which is by default initialized as follows:edge wrote: ↑Tuesday 30 October 2018 22:12 Sorry, another question
The output is
So there are 3 streams "ZAK_BLAUW", "PBP" and "GFT". In my config I am using the following lines:Code: Select all
ZAK_BLAUW;21-12-2018;23-11-2018;26-10-2018;28-09-2018;31-08-2018;03-08-2018;06-07-2018;08-06-2018;11-05-2018;13-04-2018;16-03-2018;16-02-2018;19-01-2018; PBP;28-12-2018;14-12-2018;30-11-2018;16-11-2018;02-11-2018;19-10-2018;05-10-2018;21-09-2018;07-09-2018;24-08-2018;10-08-2018;27-07-2018;13-07-2018;29-06-2018;15-06-2018;01-06-2018;18-05-2018;04-05-2018;20-04-2018;06-04-2018;23-03-2018;09-03-2018;23-02-2018;09-02-2018;26-01-2018;12-01-2018; GFT;28-12-2018;21-12-2018;14-12-2018;07-12-2018;30-11-2018;23-11-2018;16-11-2018;09-11-2018;02-11-2018;26-10-2018;19-10-2018;12-10-2018;05-10-2018;28-09-2018;21-09-2018;14-09-2018;07-09-2018;31-08-2018;24-08-2018;17-08-2018;10-08-2018;03-08-2018;27-07-2018;20-07-2018;13-07-2018;06-07-2018;29-06-2018;22-06-2018;15-06-2018;08-06-2018;01-06-2018;25-05-2018;18-05-2018;11-05-2018;04-05-2018;28-04-2018;20-04-2018;13-04-2018;06-04-2018;30-03-2018;23-03-2018;16-03-2018;09-03-2018;02-03-2018;23-02-2018;16-02-2018;09-02-2018;02-02-2018;26-01-2018;19-01-2018;12-01-2018;05-01-2018;
But somehow only the "gft" is working. PBD & zak_blauw aren't working... What can I do to make it work?Code: Select all
config['garbage'] = { "gft": {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'}, "pbp": {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'}, "zak_blauw": {kliko: 'blue', code: '#153477', name: 'ZAK', icon: 'img/garbage/kliko_blue.png'},
config['garbage_mapping'] = {
gft: ['gft', 'tuin', 'refuse bin', 'green', 'groen', 'Biodégradables', 'snoei'],
pmd: ['plastic', 'pmd', 'verpakking', 'kunststof', 'valorlux'],
rest: ['restafval'],
papier: ['papier', 'blauw', 'blue', 'recycling bin collection'],
kca: ['chemisch', 'kca','kga'],
brown: ['brown', 'verre'],
black: ['black', 'zwart'],
milieu: ['milieu'],
kerstboom: ['kerst'],
"pmd": {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
"rest": {kliko: 'blue', code: '#153477', name: 'ZAK', icon: 'img/garbage/kliko_blue.png'}
gft: ['gft'],
pmd: ['pbp'],
rest: ['blauw'],
Many thanks! Got it working.
gft:['gft'],
pmd:['pbp'],
zak_blauw:['zak']
ia het mogelijk om deze garbage plaats ook in te lezen
deze lijkt erg op de zuidhorn koppeling
https://afval.katwijk.nl/nc/afvalkalender/
bv postcode 2221sb nummer 19
Yes, I think so. I've created a PR. Wait until Rob merges it into a new beta release.NicoLP wrote: ↑Thursday 22 November 2018 23:32 ia het mogelijk om deze garbage plaats ook in te lezen
Users browsing this forum: floris74 and 1 guest
