Page 26 of 52
Re: Controlicz - Easy Domoticz to Alexa Integration
Posted: Thursday 14 December 2017 9:19
by page3
Hello all,
I'm trying to track down a problem which I suspect (but don't know for sure) is a Controlicz issue - each morning one of my living room lights is ON even though I switch it OFF the night before.
It's a LightwaveRF light switch connect to Domoticz running on a Raspberry Pi with a RFXLink.
- The problem had never happened before I got an Echo/Controlicz
- Controlicz Works great to control the lights throughout the day
- There is NOTHING logged on Domoticz regarding a light ON command (which is weird!)
- I've taken the batteries out of the LightwaveRF controller in case its gone bad.
- I do see some incoming connections in to Domotocz overnight (see below) but that's all on the log except backups.
2017-12-13 23:34:23.286 Incoming connection from: 208.113.204.247
2017-12-14 00:48:27.492 Incoming connection from: 198.143.158.180
2017-12-14 01:19:47.271 Incoming connection from: 158.85.81.121
2017-12-14 02:04:46.352 Incoming connection from: 218.28.0.150
2017-12-14 04:12:30.467 Incoming connection from: 82.221.105.6
It's baffling, especially as I'm convinced Domoticz logs everything.
Any help or pointers what to try next really appreciated!
Posted: Thursday 14 December 2017 10:34
by freijn
35.176.67.167 is the only ipadress which can reach my Domoticz from the internet.
Weird I do not see that in your logs.
Some remarks :
All your listed ipadresses to me are scripts/hackers trying to get into your domoticz.
Please make sure you have a strong password and block (if possible to do so) unknown ipadresses to your domoticz.
change the lightwave switch address and make sure its unique ( my christmastree was same as my office lights
do you have a spare lightwave ? Exchange it
I am just a happy end-user of controlicz, but alomost convinced its NOT controlicz doing this.
last resort: make a lightsensor and log when at what time the light is switched on.....
Good luck... Frank
Posted: Thursday 14 December 2017 10:50
by Madgeni
Yep, i'm not convinced Controlicz is sentient
Don't forget, Controlicz is 'just' a broker between Alexa (and Google) and your Domoticz - so if your Alexa isn't being asked to turn off/on a light then it's unlikely to be Controlicz.
I will look in the logs however, and see if i can find anything odd
Posted: Thursday 14 December 2017 14:40
by Madgeni
For those with connectivity issues, have updated your Profile page in Controlicz with functionality to test connections
Posted: Thursday 14 December 2017 15:57
by IDANIT
page3 wrote: Thursday 14 December 2017 9:19
It is hacking attempt!!!! In port forwording add Controlicz source IP!!!! 35.176.67.167 instead blank field!!!!
Posted: Thursday 14 December 2017 16:00
by IDANIT
Madgeni wrote: Thursday 14 December 2017 14:40
No connectivity issues here, I just check it... and it does nothing
Posted: Thursday 14 December 2017 17:00
by Madgeni
dammit! It works now
Posted: Thursday 14 December 2017 18:10
by page3
freijn wrote: Thursday 14 December 2017 10:34
Some remarks :
Good luck... Frank
Thanks Frank (and others) for all the suggestions. I'll give them a try.
I'm pretty convinced its not Controlicz.
Unfortunately my router (Apple Airport Extreme) cannot specify source IP address, only local. Probably time to upgrade to something a bit more feature rich, although the reliability has been excellent.
Posted: Friday 15 December 2017 17:07
by page3
I know its a bit OT, but I moved port 443 to something non-standard and much higher and have not had a single unexpected IP try to connect since.
Posted: Friday 15 December 2017 17:09
by Madgeni
it makes sense, a lot of bots will just try hitting standard ports
Posted: Friday 15 December 2017 19:40
by Ro8in
When I try to update my profile the websites gives me an authentication screen... Can't update my profile :/
Posted: Friday 15 December 2017 19:42
by Madgeni
I don't understand - you've logged in to Controlicz, then clicked Update Profile and then you get an auth screen?
Posted: Saturday 16 December 2017 18:46
by RedRaven
Does Controlicz support 'status' questions for devices? For e.g. Can I ask "Is the Bedroom Light On?"
Posted: Saturday 16 December 2017 18:53
by Madgeni
Hi - i'm afraid that until Alexa add the query requests in for lights etc, then no. Controlicz is ready and waiting
Re: Easy Domoticz to Alexa Integration
Posted: Saturday 16 December 2017 22:21
by skybehind
farhanito wrote: Thursday 02 November 2017 16:34
hi @madgeni,
what's proper device type/subtype for a door lock? it's a Yale ZigBee doorlock (as dummy switch)
this is the only thing that isn't working for me..
I want to follow up on this as the door lock doesn't work for me either. I can say turn on or turn off, but Alexa sees it as a light switch, rather than a door lock
Posted: Sunday 17 December 2017 10:02
by Madgeni
skybehind wrote: Saturday 16 December 2017 22:21
hi @madgeni,
Hi you two, star wars today, but will look at it this evening
Posted: Sunday 17 December 2017 13:12
by slash909
Hi all
just started using controlicz with my setup. Was working OK for a few days, today I am getting 'device unresponsive' failures for setting my lounge thermostat. Wierdly Alexa can read it just fine, just cant change it! I can still work couple of lighting devices. Any idea what's up here?
I have tried to reset Alexa by deleting all devices and re-enabling the skill/adding devices again. No difference made.
Also getting failure to connect when I use the 'test button' on home page, but as I said Alexa is working OK for some things.
Any help appreciated! Obviously after you are done with Star Wars day today..
Stu
Posted: Sunday 17 December 2017 16:43
by RedRaven
Madgeni wrote: Saturday 16 December 2017 18:53
Are you sure about that? I was reading this
https://10xnation.com/blog/voice-contro ... e-service/, they seem to be support status query.
Posted: Sunday 17 December 2017 17:02
by Madgeni
Yep, pretty sure. What you've linked to is how to roll your own custom skill "Alexa ask the house what light is on" etc etc. All those intents need to be created and handled.
What you have with controlicz is a bona fide Alexa smart home skill, with direct interaction, however it depends on them adding functionality on their side.
The latest version provides status reporting ( everything reports it's state to controlicz), but won't be available to query until Alexa add the relevant request intents
Posted: Sunday 17 December 2017 23:02
by Ro8in
Madgeni wrote: Friday 15 December 2017 19:42
Yes exactly that!
