Page 25 of 29
Re: How to install Domoticz on a Synology NAS
Posted: Friday 27 March 2020 11:57
by smedest
Since latest version from Jadahl on my DS216+II
Browser is not refreshing anymore automatically.
how can that be fixed?
Version: 2020.1
Build Hash: 0
Compile Date: 1970-01-01 01:00:00
dzVents Version: 3.0.1
Python Version: 3.5.1 (default, Jan 29 2018, 14:18:59) [GCC 4.9.3 20150311 (prerelease)]
installed package from jadahl.com:
Package domoticz
Version 2020.1.11804-8
Display Name Domoticz
Maintainer Domoticz
Arch braswell
Firmware 6.2-22259
Posted: Friday 27 March 2020 14:13
by jumbotroll
smedest wrote: Friday 27 March 2020 11:57
Version: 2020.1
Build Hash: 0
Package domoticz
Maintainer Domoticz
Arch braswell
Firmware 6.2-22259
Clear cache in your browser.
Posted: Friday 27 March 2020 14:35
by smedest
Clear cache is not working either.
Even tried it on browse which never used domoticz before.
Posted: Friday 27 March 2020 20:46
by teo1966
restart domoticz and try and dan restart your synology and try
Posted: Saturday 28 March 2020 12:08
by harrykausl
For all who have problems with their sensative strips. If you put the magnet on the round side of the strip (light goes on) , remove it and redo 2 (or 3) times, the strip is awake. After that I saw it in the hardware configuration of z-wave. All batterie controlled devices have to be awakend. The awakening is also described in the manual of the strip.
Posted: Wednesday 01 April 2020 14:55
by SystemLord
alkempter wrote: Tuesday 24 March 2020 11:32
Is there a sound description of a safe way how to install it and still keep all what you implemented before?
edit: solved, new Domoticz level up and running (minor problem, see below).
Curious what you did to keep all implemented before? Was a restore of the database,scripts and plugins sufficient?
Thx!
Posted: Friday 03 April 2020 8:25
by francouai
waaren wrote: Monday 23 March 2020 10:41
monfiston wrote: Monday 23 March 2020 10:13
since yesterday, I have this message which appears in domoticz. I clicked on the link to update it, but the update looks like it won't start
This button has no function with domoticz on a Synology NAS. You will have to wait until @jumbotroll prepared a package (if at all possible for the ds115j)
You can get rid of the message by unmarking
Software Updates:
Check for Updates (Not working on windows systems)
in tab
[setup][settings][system]
Same message/problem on my 1618+
I see no update for the Synology Nas on the Jumbtroll page so I have unchecked the SW update check.
Let's wait ..
Posted: Friday 03 April 2020 19:01
by alkempter
SystemLord wrote: Wednesday 01 April 2020 14:55
Thx!
Sorry, this was my first serious change in my installation. The restore of the database was sufficient. I had the LUA scripts stored on my PC, no extra plugins. The old blocklys were stored in the database.
BTW, replaced the NAS meanwhile (pulled it forward because of excess time at home
This sort of migration (new install) went OK, too. Only difference was the OPENZwave on the USB. Had to add it again and then the rest was the same (except for one device I had to delete and add again).
Unfortunately the browser keeps telling me there is a new version available (delete of browser cache and cookies did not change that).
Best regards
Al
Posted: Sunday 05 April 2020 8:37
by Stormryder
The upgrade to 2020.1 stable completely messed up my home automation due to MQTT-loopback not working any more.
And although there is an issue made in Github and maybe they will implement a solution, I fear this will take to long for wife and kids to keep sane
https://github.com/domoticz/domoticz/is ... -607198133
Therefor I would really like to roll back to the previous version. I searched this thread and the rest of the forum/internet but can not really find a definite answer whether this is possible or not.
What I have done so far:
1. I manually downloaded domoticz_avoton-6.2_4.0.10717-8.spk
2. I downloaded a back up from my Domoticz DB
3. I did not add any hardware (like Buienradar or anything from the new version)
Question; I
s it possible to go back to the previous version by manually installing the downloaded spk?
Or do I need to delete Domoticz as a package and reinstall it manually. And in that last case; is the backup of the database sufficient for all scripts, etc. I have made quite a few mods and scripts and would hate to see al that work go to waste.
Posted: Thursday 23 April 2020 8:02
by Pacman42
FlatBread wrote: Wednesday 25 March 2020 9:35
Still not working for me. I tried to install the Python version, but then Domoticz doesn't start at all. So back to the non Python version, that starts, but stops everytime after 25 seconds.
Here are the last lines from my logfile, this is what happens everytime when I try to start Domoticz:
2020-03-25 08:01:47.725 Error: Domoticz(pid:10151, tid:10179('EvoHome')) received fatal signal 6 (Aborted)
2020-03-25 08:01:47.725 Error: siginfo address=0x27a7, address=0x7f1128dda907
2020-03-25 08:01:47.737 Error: Failed to start gdb, will use backtrace() for printing stack frame
2020-03-25 08:01:47.738 Error: #0 /usr/local/domoticz/bin/domoticz() [0x565040]
2020-03-25 08:01:47.738 Error: #1 /usr/local/domoticz/bin/domoticz() [0x565d4d]
2020-03-25 08:01:47.738 Error: #2 /lib/libpthread.so.0 : + 0x101c0 [0x7f112a2dc1c0]
2020-03-25 08:01:47.738 Error: #3 /lib/libc.so.6 : gsignal + 0x37 [0x7f1128dda907]
2020-03-25 08:01:47.738 Error: #4 /lib/libc.so.6 : abort + 0x16a [0x7f1128ddbcda]
2020-03-25 08:01:47.738 Error: #5 /usr/local/domoticz/bin/domoticz : __gnu_cxx::__verbose_terminate_handler() + 0xbf [0xbfc859]
2020-03-25 08:01:47.739 Error: #6 /usr/local/domoticz/bin/domoticz : __cxxabiv1::__terminate(void (*)()) + 0x3 [0xbc776a]
2020-03-25 08:01:47.739 Error: #7 /usr/local/domoticz/bin/domoticz : __cxxabiv1::__unexpected(void (*)()) + 0 [0xbc77a0]
2020-03-25 08:01:47.739 Error: #8 /usr/local/domoticz/bin/domoticz : std::thread::_M_start_thread(std::shared_ptr<std::thread::_Impl_base>) + 0 [0xbf4e18]
2020-03-25 08:01:47.739 Error: #9 /lib/libpthread.so.0 : + 0x72c4 [0x7f112a2d32c4]
2020-03-25 08:01:47.739 Error: #10 /lib/libc.so.6 : clone + 0x6d [0x7f1128e9110d]
I have exactly the same problem om my DS216j.
I had to make go back to the previous release by making a clean reinstall of that and copy my backup scripts and DB into it. I will wait for the next release instead if the issue is not resolved.
Posted: Thursday 23 April 2020 8:05
by Pacman42
Stormryder wrote: Sunday 05 April 2020 8:37
Question; I
1) Save your scripts and your database.
2) make a clean installation.
3) move your scripts and databases back inte the installed app
4) now it should work.
This is how I do all installations on Synology. Upgrading Domoticz has not worked even once for me on Synology.
Posted: Thursday 23 April 2020 8:33
by Ayep
Good thread thanks for the input. Also looking into rolling back.
How must one go about a " clean install" ? Simple uninstall via dsm or anything else ?
Posted: Friday 01 May 2020 22:47
by sammyke007
Ayep wrote: Thursday 23 April 2020 8:33
Uninstalling via DSM will result in a complete wipe of all folders, so make sure that you've got your scripts and plugins backed-up!
Posted: Wednesday 06 May 2020 11:50
by teo1966
from the jadahl.com site
There is a lot of work to update domoticz packages for synology, and unfortunately
I do not have time for this project for a long time, so do not expect any updates for a long time.
I will not respond to any inquiries by email.
i think we most respect en patience whit updates for or synology nas whit domoticz
i hope everything is good whit jadahl
Posted: Wednesday 06 May 2020 15:14
by gomario
If there is any chance that Jadahl will read this:
Can you set up a Patreon account? I'm sure most of us would happily send some money your way every month. Domoticz on Synology is by far the most stable, convenient and dependable solution (at lest for me) and I have become pretty dependent on it. I would love to support you in order to keep you going... Hope you're OK and doing fine in these times....that goes for everyone here!
Posted: Monday 11 May 2020 10:51
by Ayep
I can only
assume something is on the cards for synology users. Check out the "News and updates" section, and the post about Domoticz 2020.2 stable being released :
If you are using Domoticz on other platforms (Like for instance on a Synology NAS), it could be some time before it is ready. Please be patient, we are all trying to do our best to get it released as soon as possible!
Let's hope it is indeed on the way. Nonetheless donations towards developers is indeed something I personaly think we should all do to support their work, not only towards jumbotroll but also towards the Domoticz community and other app developpers.
I'm also relying on synology, have no desire for an extra RPi lying about, so following this thread closely. Let's be patient, and look forward to a new spk at some point
Posted: Tuesday 12 May 2020 15:13
by Robbie
Who do I need to contact to explain me the process for building the spk's? Once I know the bottleneck, I'm willing to create an automation for it.
Please let me know by sending me a PM.
Posted: Wednesday 13 May 2020 9:39
by tof92130
I have exactly same problem on my synology with domoticz
latest version from Jadahl on my 916+
Version: 2020.1
Build Hash: 0
Package domoticz
Maintainer Domoticz
Arch braswell
Firmware 6.2-22259
Posted: Wednesday 13 May 2020 21:49
by Robbie
tof92130 wrote: Wednesday 13 May 2020 9:39
Are you using reverse-proxy? If so, you'll have to add WebSocket to your header since Domoticz 2020.1.
Instructions:
https://mlohr.com/websockets-for-synology-dsm/
Posted: Wednesday 13 May 2020 21:57
by sammyke007
Indeed, websockets need to be enabled!
