Page 25 of 55
Re: [MyDomoAtHome] Support thread
Posted: Thursday 03 March 2016 20:27
by lowca
epierre wrote:@Iowca I was working on water and the new Energy yesterday
this is round number, I can multiply by 1000 and display Watt
I thought about to see in kWh in format x.xxx
"Iowca I was working on water and the new Energy yesterday
" , do you have some beta version , changlog ,
or all changes are in new version .. (sorry i'm new here
Posted: Friday 04 March 2016 19:41
by aleceuta
Hello:
I try now fresh install of MyDomoAtHome on preconfigured SD with Domoticz 3.4834 for raspberry
I follow the wiki tutorial
https://www.domoticz.com/wiki/ImperiHome
I have problem with sh ./run-once.sh never finish
I created any modificate script run-once2.sh that include 2 lines in verbose mode
run-once2.sh
#!/bin/sh
echo "Will update packages list first..."
clear
#sudo apt-get update 2>&1 > /dev/null
echo "Now getting the needed software..."
sudo apt-get -y install whiptail 2>&1 > /dev/null
if ! whiptail --backtitle "MyDomoAtHome ISS Interface" --yesno "Have you configured MyDomoAtHome.sh with your parameters before continuing ? Otherwise please say NO" 0 0; then
whiptail --backtitle "MyDomoAtHome ISS Interface" --msgbox "Understood! Aborting!" 0 0
return
fi
echo "Now getting getting and installing dependencies..."
sudo apt-get -y install libdancer-perl libdancer2-perl libfile-slurp-perl liblwp-protocol-psgi-perl 2>&1
sudo apt-get -y install libtime-piece-perl libjson-perl libplack-perl starman libcrypt-ssleay-perl libdatetime-perl libdatetime-format-strptime-perl 2>&1
sudo apt-get -y install libdbd-sqlite3-perl libdbi-perl sqlite3 2>&1
sudo apt-get -y install libaudio-mpd-perl libnet-upnp-perl libpoe-component-client-mpd-perl 2>&1
sudo curl -L https://cpanmin.us | perl - --sudo App::cpanminus
sudo cpanm Task::Plack --verbose --force
sudo cpanm Time::Moment --verbose --force
echo "Now installing the service"
sudo cp MyDomoAtHome.sh /etc/init.d/MyDomoAtHome.sh
sudo chmod +x /etc/init.d/MyDomoAtHome.sh
sudo update-rc.d MyDomoAtHome.sh defaults
whiptail --backtitle "MyDomoAtHome ISS Interface" --msgbox "Everything has been installed ! Please remember default port is 3001." 0 0
and here the result
pi@raspberrypi:~/domoticz/MyDomoAtHome$ ./run-once2.sh
Reading package lists... Done
Building dependency tree
Reading state information... Done
libdancer-perl is already the newest version.
libdancer2-perl is already the newest version.
libfile-slurp-perl is already the newest version.
liblwp-protocol-psgi-perl is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Note, selecting 'perl' instead of 'libtime-piece-perl'
libcrypt-ssleay-perl is already the newest version.
libdatetime-format-strptime-perl is already the newest version.
libdatetime-perl is already the newest version.
libjson-perl is already the newest version.
libplack-perl is already the newest version.
starman is already the newest version.
libdbd-sqlite3-perl is already the newest version.
libdbi-perl is already the newest version.
sqlite3 is already the newest version.
libaudio-mpd-perl is already the newest version.
libnet-upnp-perl is already the newest version.
libpoe-component-client-mpd-perl is already the newest version.
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 314 0 314 0 0 283 0 --:--:-- 0:00:01 --:--:-- 287
100 296k 100 296k 0 0 159k 0 0:00:01 0:00:01 --:--:-- 405k
App::cpanminus is up to date. (1.7040)
cpanm (App::cpanminus) 1.7040 on perl 5.020002 built for arm-linux-gnueabihf-thread-multi-64int
Work directory is /root/.cpanm/work/1457115373.16925
You have make /usr/bin/make
You have LWP 6.08
You have /bin/tar: tar (GNU tar) 1.27.1
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>.
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by John Gilmore and Jay Fenlason.
You have /usr/bin/unzip
Searching Task::Plack () on cpanmetadb ...
--> Working on Task::Plack
Fetching http://www.cpan.org/authors/id/M/MI/MIYAGAWA/Task-Plack-0.28.tar.gz ... OK
Unpacking Task-Plack-0.28.tar.gz
Task-Plack-0.28/
Task-Plack-0.28/Build.PL
Task-Plack-0.28/Changes
Task-Plack-0.28/cpanfile
Task-Plack-0.28/dist.ini
Task-Plack-0.28/lib/
Task-Plack-0.28/LICENSE
Task-Plack-0.28/maint/
Task-Plack-0.28/MANIFEST
Task-Plack-0.28/META.json
Task-Plack-0.28/META.yml
Task-Plack-0.28/README
Task-Plack-0.28/t/
Task-Plack-0.28/xt/
Task-Plack-0.28/xt/perlcritic.t
Task-Plack-0.28/xt/pod.t
Task-Plack-0.28/xt/podspell.t
Task-Plack-0.28/xt/synopsis.t
Task-Plack-0.28/t/00_compile.t
Task-Plack-0.28/t/release-pod-syntax.t
Task-Plack-0.28/maint/bump.pl
Task-Plack-0.28/lib/Task/
Task-Plack-0.28/lib/Task/Plack.pm
Entering Task-Plack-0.28
Checking configure dependencies from META.json
Checking if you have Module::Build::Tiny 0.019 ... Yes (0.039)
Running Build.PL
Configuring Task-Plack-0.28 ... Creating new 'Build' script for 'Task-Plack' version '0.28'
OK
Checking dependencies from MYMETA.json ...
Checking if you have IO::Handle::Util 0.01 ... Yes (0.01)
Checking if you have Plack::Middleware::Debug 0.14 ... Yes (0.16)
Checking if you have FCGI::ProcManager 0.24 ... Yes (0.24)
Checking if you have Plack 1.0023 ... Yes (1.0033)
Checking if you have Starlet 0.18 ... No
Checking if you have Plack::Middleware::Auth::Digest 0.04 ... Yes (0.05)
Checking if you have Corona 0.1004 ... Yes (0.1004)
Checking if you have Plack::Middleware::Header 0.04 ... Yes (0.04)
Checking if you have Plack::Middleware::ReverseProxy 0.15 ... Yes (0.15)
Checking if you have PSGI 1.101 ... Yes (1.102)
Checking if you have HTTP::Server::Simple::PSGI 0.14 ... Yes (0.16)
Checking if you have Plack::Middleware::Session 0.18 ... Yes (0.30)
Checking if you have Twiggy 0.1021 ... Yes (0.1025)
Checking if you have Net::FastCGI 0.14 ... Yes (0.14)
Checking if you have Starman 0.3011 ... Yes (0.4010)
Checking if you have FCGI 0.74 ... Yes (0.77)
Checking if you have FCGI::Client 0.08 ... Yes (0.08)
Checking if you have Plack::Middleware::ConsoleLogger 0.04 ... Yes (0.05)
Checking if you have Plack::Middleware::Deflater 0.08 ... Yes (0.12)
Checking if you have Plack::App::Proxy 0.27 ... Yes (0.29)
Checking if you have CGI::PSGI 0.15 ... Yes (0.15)
Checking if you have CGI::Compile 0.16 ... Yes (0.17)
Checking if you have CGI::Emulate::PSGI 0.15 ... Yes (0.20)
==> Found dependencies: Starlet
Searching Starlet (0.18) on cpanmetadb ...
--> Working on Starlet
Fetching http://www.cpan.org/authors/id/K/KA/KAZUHO/Starlet-0.29.tar.gz ... OK
Unpacking Starlet-0.29.tar.gz
Starlet-0.29/
Starlet-0.29/.gitignore
Starlet-0.29/Changes
Starlet-0.29/inc/
Starlet-0.29/inc/Module/
Starlet-0.29/inc/Module/Install/
Starlet-0.29/inc/Module/Install/Base.pm
Starlet-0.29/inc/Module/Install/Can.pm
Starlet-0.29/inc/Module/Install/Fetch.pm
Starlet-0.29/inc/Module/Install/Makefile.pm
Starlet-0.29/inc/Module/Install/Metadata.pm
Starlet-0.29/inc/Module/Install/ReadmeFromPod.pm
Starlet-0.29/inc/Module/Install/Win32.pm
Starlet-0.29/inc/Module/Install/WriteAll.pm
Starlet-0.29/inc/Module/Install.pm
Starlet-0.29/lib/
Starlet-0.29/lib/Plack/
Starlet-0.29/lib/Plack/Handler/
Starlet-0.29/lib/Plack/Handler/Starlet.pm
Starlet-0.29/lib/Starlet/
Starlet-0.29/lib/Starlet/Server.pm
Starlet-0.29/lib/Starlet.pm
Starlet-0.29/Makefile.PL
Starlet-0.29/MANIFEST
Starlet-0.29/META.yml
Starlet-0.29/MYMETA.json
Starlet-0.29/MYMETA.yml
Starlet-0.29/README
Starlet-0.29/t/
Starlet-0.29/t/00base-hello.psgi
Starlet-0.29/t/00base.t
Starlet-0.29/t/01plack-test.t
Starlet-0.29/t/02graceful.t
Starlet-0.29/t/03post.t
Starlet-0.29/t/04-bumpy-life.t
Starlet-0.29/t/05server-header.t
Starlet-0.29/t/06harakiri.t
Starlet-0.29/t/07remote_port.t
Starlet-0.29/t/08chunked_req.t
Starlet-0.29/t/09chunked_zero_length.t
Starlet-0.29/t/10unix_domain_socket.t
Starlet-0.29/t/11multi-sockets.t
Starlet-0.29/t/12bad_request_line.t
Starlet-0.29/t/13spawn_interval.t
Starlet-0.29/t/assets/
Starlet-0.29/t/assets/baybridge.jpg
Entering Starlet-0.29
Checking configure dependencies from META.yml
Checking if you have ExtUtils::MakeMaker 6.59 ... Yes (6.98)
Running Makefile.PL
Configuring Starlet-0.29 ... Checking if your kit is complete...
Looks good
Generating a Unix-style Makefile
Writing Makefile for Starlet
Writing MYMETA.yml and MYMETA.json
OK
Checking if you have Plack 0.992 ... Yes (1.0033)
Checking if you have Parallel::Prefork 0.17 ... Yes (0.18)
Checking if you have ExtUtils::MakeMaker 0 ... Yes (6.98)
Checking if you have Test::More 0.88 ... Yes (1.001002)
Checking if you have Server::Starter 0.06 ... Yes (0.17)
Checking if you have LWP::UserAgent 5.8 ... Yes (6.06)
Checking if you have Test::TCP 2.1 ... Yes (2.14)
Building and testing Starlet-0.29 ... cp lib/Plack/Handler/Starlet.pm blib/lib/Plack/Handler/Starlet.pm
cp lib/Starlet/Server.pm blib/lib/Starlet/Server.pm
cp lib/Starlet.pm blib/lib/Starlet.pm
Manifying blib/man3/Starlet.3pm
PERL_DL_NONLAZY=1 /usr/bin/perl "-MExtUtils::Command::MM" "-MTest::Harness" "-e" "undef *Test::Harness::Switches; test_harness(0, 'inc', 'blib/lib', 'blib/arch')" t/*.t
t/00base.t ................. 2/?
# Failed test 'request successfull'
# at t/00base.t line 49.
t/00base.t ................. 3/?
# Failed test 'content is hello'
# at t/00base.t line 50.
# got: 'Can't connect to 127.0.0.1:50364
# Connection refused at /usr/share/perl5/LWP/Protocol/http.pm line 49.
# expected: 'hello'
# Looks like you failed 2 tests of 3.
t/00base.t ................. Dubious, test returned 2 (wstat 512, 0x200)
Failed 2/3 subtests
t/01plack-test.t ........... ok
t/02graceful.t ............. 18036 at t/02graceful.t line 11.
18036 at t/02graceful.t line 30.
18110 at t/02graceful.t line 16.
t/02graceful.t ............. ok
t/03post.t ................. 18154 at t/03post.t line 9.
Plack::Handler::Starlet: Accepting connections at http://0:50646/
127.0.0.1 - - [04/Mar/2016:18:19:07 +0000] "POST / HTTP/1.1" 200 3 "-" "libwww-perl/6.08"
t/03post.t ................. ok
t/04-bumpy-life.t .......... ok
t/05server-header.t ........ ok
t/06harakiri.t ............. ok
t/07remote_port.t .......... ok
t/08chunked_req.t .......... ok
t/09chunked_zero_length.t .. ok
t/10unix_domain_socket.t ... failed to listen to socket /tmp/B7bs9bOXhw:No such file or directory at t/10unix_domain_socket.t line 35.
# Child (direct) exited without calling finalize()
t/10unix_domain_socket.t ... 1/?
# Failed test 'direct'
# at /usr/share/perl/5.20/Test/Builder.pm line 276.
# Tests were run but no plan was declared and done_testing() was not seen.
# Looks like your test exited with 2 just after 1.
on this line # Looks like your test exited with 2 just after 1. newer finish
I try step by step of the script.
But when I try start
sudo service MyDomoAtHome.sh start
when test it
not working
Nevertheless when start
works
Posted: Friday 04 March 2016 21:56
by epierre
Posted: Friday 04 March 2016 21:58
by epierre
not mine, but it seems package maintainer has some issues... and so people there... this is why I'm rewriting it in nodeJS
when test it
not working
works
try:
service mydomoathome start
and then:
service mydomoathome status
to see the system status
Posted: Saturday 05 March 2016 15:29
by epierre
need some testers here:
viewtopic.php?f=21&t=8951
mostly on blinds and docker, please send me your email either pm or
[email protected]
Posted: Saturday 05 March 2016 16:23
by epierre
lowca wrote:Hello..
I'm trying to run Counter Incremental .,
It looks like it worked:.
if (($f->{"Type"} eq "General") and ($f->{"SubType"} eq "Counter Incremental")) {
In debug("CounterToday:$v\n"); have [hit #91]CounterToday:1.463 ImpireHome show 1. Not showing numbers after decimal.
My question is how can i do that , or is it on Imperihome side ..[/quote]
@lowca I did it in the new version in nodeJS, this is not that simple, 4 types, 4 fixed units and one dynamic...
I need more testers but now only graphs are now missing, all new and updated devices are here
Posted: Saturday 05 March 2016 17:56
by lowca
Ok. later i will install node js version and make some test ..
update:
Node version: 4.3.2
MDAH version: 0.0.19
in Imerihome Counter Incremental show N/A
console.log(res[1]); show good value , total and usage.. need some more time to get deeper in nodejs version ..
update:
On my other pi system same node and mdah version , showing good values .. hmm,.
Posted: Monday 07 March 2016 13:35
by aleceuta
When I test
sudo service MyDomoAtHome.sh status
say is failed not working.
Posted: Monday 07 March 2016 13:37
by aleceuta
Is not possible generate any log´s to see the problem.
Posted: Monday 07 March 2016 14:22
by lowca
Problem is in { key: 'Watts', value: '6.791
kWh', unit: undefined },
For test i remove kWh from usage varible ,and static unit "kWh" it shows in watts.
usage = usage.substr(0, usage.length-3);
console.log(usage);
Method is not the best, but its working now .,
Posted: Monday 07 March 2016 19:54
by lowca
aleceuta wrote:Is not possible generate any log´s to see the problem.
Try to start manualy ,, In Your MyDomoAtHome directory try to run start2.sh
pi@raspberrypi:~/domoticz/MyDomoAtHome $ sh ./start2.sh
Posted: Tuesday 08 March 2016 12:45
by aleceuta
Yes lowca at moment start with ./start2.sh
But not is good solution. I want start as service.
Posted: Tuesday 08 March 2016 12:56
by lowca
Try: sudo /etc/init.d/MyDomoAtHome.sh start
and send as output ..
Posted: Wednesday 09 March 2016 11:41
by hendrik6073
used search cannot find anything on this issue
i added 8 test dummy tekst devices. i use them to post the heater thermostat schedule information . I want to display the devices using ImperiHome.
In ImperiHome the dummy text devices are not visible (
http://imperihome:5001/devices) ? should i do some extra ?
thanks
Posted: Sunday 13 March 2016 18:28
by rafal
Hello everybody,
I have Domoticz v3.4834 by Jadahl on NAS Synology and i installed docker on nas with MyDomoAtHome to connect imperihome on samsung android.
my domoticz on nas is on 192.168.0.11:8084, so i try connect but i have different range ip:
MyDomoAtHome Dev
MDAH:
http://172.17.0.11:3002
MDAH ver: 0.0.23
Domoticz:
http://127.0.0.1:8080
NodeJS: v4.3.0
Webmanager: EJS
Renderer: Express
how i can change domoticz http for 192.168.0.11:8084???
i conected from my phone to the gatway but i'cant see any sensors
Is it possible to connect MyDomotAtHome in any different way expect raspberry pi?? for example:
Domoticz on windows --any "system" with gate ---imperihome or
Domoticz on NAS --- any "system" with gate(like docker) ---imperihome
https://drive.google.com/file/d/0B5vmlS ... sp=sharing
Thank You for any anwer and help
Posted: Sunday 13 March 2016 18:54
by epierre
aleceuta wrote:When I test
Posted: Sunday 13 March 2016 18:55
by epierre
hendrik6073 wrote:used search cannot find anything on this issue
can you send me the output of your
http://192.168.0.xx:8080/json.htm?type= ... order=Name
Posted: Sunday 13 March 2016 18:58
by epierre
rafal wrote:Hello everybody,
MyDomoAtHome Dev
MDAH:
MDAH ver: 0.0.23
Domoticz:
NodeJS: v4.3.0
Webmanager: EJS
Renderer: Express
Normally this should start as :
docker run --name=mdah --env DOMO="http://your_ip:8080" -it --rm -p 3002:3002 epierre/mdah
the environment variable would change the IP/PORT in the DOMO variable, and if you want to use something different as port 3002 you could change -p 3002:your_port
If you can't change environment, can you "mount" the image and modify in it /etc/mydomoathome/config.json ?
Posted: Sunday 13 March 2016 20:08
by rafal
"Remember to change the IP below and authorize in Domoticz the docker IP range
docker run --name=mdah --env DOMO="http://your_ip:8080" -it --rm -p 3002:3002 epierre/mdah"
i did same way with instrukction on github and you container is added but when i try switching on and i had error:
meybe i doing something wrong...??
i do not think i using port 3002 for something else.
how to i can modifay it /etc/mydomoathome/config.json ? in docker is terminal bash? i newbie on linux bash etc anyway when i config manually
and config ip and domoticz port i have error:
i know is terminal in docker but i dont't know how to use it :
Thank You for help
Rafal
Posted: Sunday 13 March 2016 21:00
by rafal
second question how i can use these commands in docker on synology????:
Check running docker processes
docker ps
Stoping a docker process
docker stop mdah
