Page 24 of 26
Re: Python Plugin: TUYA
Posted: Monday 08 May 2023 20:57
by Xenomes
ricorico94 wrote: Monday 08 May 2023 16:23
I've been using the great pugin for long time now, with several switches devices : great job and thanks a lot !
I've just added through my android App Smart Life a new device, an "irrigation device" "ie this :
https://fr.aliexpress.com/item/10050050 ... pt=glo2fra
It seems working well when using the android app.
However, when I stop/start the plugin in domoticz, it doesn't see that device. If I use the debug_discovery.py script, I can also see my other switching devices, but not that one.
Any idea of what I can try to get it listed and working ? (in practice the oly thing I'd like to do through Domoticz is to switch it on/off, like standard electric switches..)
br,
Ricorico94
A lot of new devices are not detected by the old Tuyaha module, you can try the newer
https://github.com/Xenomes/Domoticz-TinyTUYA-Plugin
Python Plugin: TUYA
Posted: Tuesday 16 May 2023 11:46
by martins
My devices all of a sudden stopped working with the following error in the log file : Error: Smart: handleThread: Get accesstoken failed. Username or password error! line 218
I changed the password and put the new one in the hardware tab but still gets the same error. Any suggestions ?
Posted: Tuesday 16 May 2023 20:19
by Xenomes
martins wrote: Tuesday 16 May 2023 11:46
There is a issue with special characters, if you new password have one change it to a other or remove it and try again.
Posted: Saturday 20 May 2023 17:45
by Cizetta
I was using the plugin (Domoticz-TUYA) on a Raspberry Pi for some time and it was working fine. Recently I got a strange issue with it - when I add/update it in Domoticz in the logs I can only see and nothing more logged for that Hardware:
Hardware is named "Tuya2".
I have the required python packages - tuyaha and requests
Tried deleting it in Domoticz and the plugin folder, reinstalling it - via PP Manager, directly downloading it via git, restarting Domoticz, restarting Raspberry Pi, making upgrade of the OS - same result. Debug script is showing the devices and plugin is working fine on a secondary Raspberry Pi I have.
I know it is a hard-to-check issue since there in nothing logged and I would be please if you can help me with some guidance what to check.
Thank you in advance.
Posted: Saturday 20 May 2023 21:41
by Xenomes
T
Cizetta wrote: Saturday 20 May 2023 17:45
The plugin should put out more log information then only this line.
Posted: Saturday 20 May 2023 21:54
by Cizetta
Yes, it should generate more logs. That's the strange part - no additional messages, no errors, no devices added. Like it somehow stops/hangs. I know it is not a common issue and it is hard for investigation with that lack of info.
Posted: Saturday 20 May 2023 22:12
by Xenomes
Check if the plugin is active and three boxes of log level are selected, set debug to All. update the settings.
Posted: Sunday 21 May 2023 13:15
by Cizetta
After starting Domoticz manually with all debug and logging flags set I got the error:
[686f3200] Error: Tuya2: AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
Now I'm fighting with cryptography and pyOpenSSL packages.
Update:
Issue is resolved. According to the debug logs the plugin is using modules from python 3.7 (Domoticz uses python 3.7) but after the OS upgrade I'm using python 3.10. So pyopenssl just had to updated with pip3.7.
Thank you for the help!
Posted: Tuesday 05 December 2023 19:55
by jpvaneijk
The post below had been placed in the wrong forum topic due to a misunderstanding. So restored in this one.
I'm on a RPi 5 running on Bookworm. Bullseye is no longer supported for this hardware. see:
https://www.raspberrypi.com/documentati ... spberry-pi
Due to changes in the way pip should be handled now, I seem to be running into a problem with getting Tuya working.
2023-12-02 15:04:27.517 Error: Smart Life: (tuya) failed to load 'plugin.py', Python Path used was '/home/MYUSERNAME/domoticz/plugins/Domoticz-TUYA-Plugin/:/usr/lib/python311.zip:/usr/lib/python3.11:/usr/lib/python3.11/lib-dynload:/usr/local/lib/python3.11/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.11/dist-packages'.
2023-12-02 15:04:27.544 Error: Smart Life: Traceback (most recent call last):
2023-12-02 15:04:27.544 Error: Smart Life: File "/home/MYUSERNAME/domoticz/plugins/Domoticz-TUYA-Plugin/plugin.py", line 65, in <module>
2023-12-02 15:04:27.544 Error: Smart Life: import tuyaha
2023-12-02 15:04:27.544 Error: Smart Life: ModuleNotFoundError: No module named 'tuyaha'
In accordance with the descriptions in the link above, I have created a virtual environment in which pip installations like this can be processed. In doing so, I no longer get the annoying error message that prevents you from continuing the installation process.
It seems to me that from the Plugins folder in Domoticz, in the Plugin.py file is being searched for components that can no longer be found in the default location.
Can you help me get this sorted out?
Posted: Tuesday 05 December 2023 21:31
by waltervl
From the Zigbee for Domoticz plugin wiki I read that for bookworm they need to add
(double dash!) to the pip install command. Perhaps this helps you.
sudo pip3 install -r requirements.txt
Note : With Debian 12 Bookworm, you have to add
–break-system-packages at the end of the previous command line. Be careful to take the two dash at the beginning.
Posted: Tuesday 05 December 2023 22:40
by Xenomes
I see the issue, and Waltervl's solution is the best option until Domoticz has its own virtual Python environment where modules can be installed. I tested it, and it works. The only thing is that Domoticz service needs an update to use/start the virtual Python environment.
Posted: Saturday 09 December 2023 13:14
by jpvaneijk
This does not seem to work, or I am doing something wrong of course. To make sure it wasn't due to the current installation, I did a new Bookworm installation with the latest Domoticz version.
I keep getting the message that the virtual environment is externally managed.
I looked up the relevant Wiki:
https://zigbeefordomoticz.github.io/wik ... ation.html
I used the following commands (Obviously taking into account the double dash):
sudo pip3 install tuyaha requests==2.23.0 –break-system-packages
sudo pip3 install tuyaha requests –break-system-packages
What I get back in both situations is:
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
I agree with Xenomes that it would be good if Domoticz got an update with its own virtual environment.
@Xenomes: You indicate that you have tested this. So I'm curious how you did that then.
Thanx so far for taking the time guys!
Posted: Saturday 09 December 2023 19:58
by Xenomes
jpvaneijk wrote: Saturday 09 December 2023 13:14
Warning: I performed this on a test system within my VM environment, so it is not a viable solution for a live system.
python -m venv ~/domoticz # install Python Virtual Environment
cd ~/domoticz
source bin/activate # Activate Virtual Environment
./domoticz -www 8080 -sslwww 0 # Working python modules
deactivate
./domoticz -www 8080 -sslwww 0 # Not working python modules
Maybe you need: sudo apt install python3-full
Posted: Sunday 10 December 2023 14:13
by jpvaneijk
Now working with:
sudo pip3 install tuyaha requests --break-system-packages
It was the double dash I think
Thanx for working with me guys
Posted: Friday 23 February 2024 10:38
by papryk18
Hello!
Please, help me!
Python Version: 3.7.3 (default, Oct 11 2023, 09:51:27) [GCC 8.3.0]
2024-02-23 10:17:13.930 Status: New sensors allowed for 5 minutes...
2024-02-23 10:17:15.783 Status: TuyaXenomes: Entering work loop.
2024-02-23 10:17:15.783 Status: TuyaXenomes: Started.
2024-02-23 10:17:16.456 Status: TuyaXenomes: Initialized version 1.0.16, author 'Wagner Oliveira contributed Xenomes'
2024-02-23 10:18:16.520 TuyaXenomes: 'Key':'tuya'
2024-02-23 10:18:16.520 TuyaXenomes: 'Mode1':'48'
2024-02-23 10:18:16.520 TuyaXenomes: 'Mode2':'smart_life'
2024-02-23 10:18:16.520 TuyaXenomes: 'Mode6':'18'
2024-02-23 10:18:16.520 TuyaXenomes: 'DomoticzVersion':'2024.4'
2024-02-23 10:18:16.520 TuyaXenomes: 'DomoticzHash':'731719420'
2024-02-23 10:18:16.520 TuyaXenomes: 'DomoticzBuildTime':'2024-01-30 09:16:34'
2024-02-23 10:18:16.520 TuyaXenomes: Device count: 0
2024-02-23 10:18:16.521 TuyaXenomes: in handlethread
2024-02-23 10:18:16.623 TuyaXenomes: onHeartbeat called time=1708679896.6235979
2024-02-23 10:18:16.624 TuyaXenomes: in handlethread
2024-02-23 10:18:16.624 TuyaXenomes: Device count: 0
2024-02-23 10:18:16.356 [b]Error: TuyaXenomes hardware (10) thread seems to have ended unexpectedly[/b]
2024-02-23 10:18:30.932 TuyaXenomes: onStop called
2024-02-23 10:18:30.931 Status: TuyaXenomes: Stop directive received.
2024-02-23 10:18:31.059 Status: TuyaXenomes: Exiting work loop.
2024-02-23 10:18:31.132 Status: TuyaXenomes: Stopping threads.
2024-02-23 10:18:31.132 Status: TuyaXenomes: Stopped.
2024-02-23 10:18:47.591 Oswietlenie: Inclusion mode=0
2024-02-23 10:26:02.966 Status: New sensors allowed for 5 minutes...
2024-02-23 10:26:06.814 TuyaXenomes: Worker thread started.
2024-02-23 10:26:06.813 Status: TuyaXenomes: Entering work loop.
2024-02-23 10:26:06.814 Status: TuyaXenomes: Started.
2024-02-23 10:26:07.454 TuyaXenomes: Waiting 60 seconds to connect TuyaApi login error timeout
2024-02-23 10:26:07.454 TuyaXenomes: Waiting 50 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:26:07.453 Status: TuyaXenomes: Initialized version 1.0.16, author 'Wagner Oliveira contributed Xenomes'
2024-02-23 10:26:10.825 Status: TuyaXenomes: Stop directive received.
2024-02-23 10:26:17.465 TuyaXenomes: Waiting 40 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:26:27.475 TuyaXenomes: Waiting 30 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:26:37.485 TuyaXenomes: Waiting 20 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:26:47.495 TuyaXenomes: Waiting 10 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:26:57.505 TuyaXenomes: Waiting 0 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:27:07.515 TuyaXenomes: TUYA plugin started
2024-02-23 10:27:07.515 TuyaXenomes: Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE
2024-02-23 10:27:07.516 TuyaXenomes: 'HardwareID':'10'
2024-02-23 10:27:07.516 TuyaXenomes: 'HomeFolder':'/home/pi/domoticz/plugins/Domoticz-TUYA-Plugin/'
2024-02-23 10:27:07.516 TuyaXenomes: 'StartupFolder':'/home/pi/domoticz/'
2024-02-23 10:27:07.516 TuyaXenomes: 'UserDataFolder':'/home/pi/domoticz/'
2024-02-23 10:27:07.516 TuyaXenomes: 'Database':'/home/pi/domoticz/domoticz.db'
2024-02-23 10:27:07.516 TuyaXenomes: 'Language':'pl'
2024-02-23 10:27:07.516 TuyaXenomes: 'Version':'1.0.16'
2024-02-23 10:27:07.516 TuyaXenomes: 'Author':'Wagner Oliveira contributed Xenomes'
2024-02-23 10:27:07.516 TuyaXenomes: 'Name':'TuyaXenomes'
2024-02-23 10:27:07.516 TuyaXenomes: 'Port':'0'
2024-02-23 10:27:07.516 TuyaXenomes: 'Username':'**************'
2024-02-23 10:27:07.516 TuyaXenomes: 'Password':'**************'
2024-02-23 10:27:07.516 TuyaXenomes: 'Key':'tuya'
2024-02-23 10:27:07.516 TuyaXenomes: 'Mode1':'48'
2024-02-23 10:27:07.516 TuyaXenomes: 'Mode2':'smart_life'
2024-02-23 10:27:07.516 TuyaXenomes: 'Mode6':'-1'
2024-02-23 10:27:07.516 TuyaXenomes: 'DomoticzVersion':'2024.4'
2024-02-23 10:27:07.516 TuyaXenomes: 'DomoticzHash':'731719420'
2024-02-23 10:27:07.516 TuyaXenomes: 'DomoticzBuildTime':'2024-01-30 09:16:34'
2024-02-23 10:27:07.516 TuyaXenomes: Device count: 0
2024-02-23 10:27:07.517 TuyaXenomes: in handlethread
2024-02-23 10:27:07.519 TuyaXenomes: Acquiring GIL for 'onStartCallback'
2024-02-23 10:27:07.520 TuyaXenomes: Processing 'onStopCallback' message
2024-02-23 10:27:07.520 TuyaXenomes: Acquiring GIL for 'onStopCallback'
2024-02-23 10:27:07.520 TuyaXenomes: Calling message handler 'onStop' on 'module' type object.
2024-02-23 10:27:07.520 TuyaXenomes: onStop called
2024-02-23 10:27:09.676 TuyaXenomes: Worker thread started.
2024-02-23 10:27:09.627 Status: TuyaXenomes: Exiting work loop.
2024-02-23 10:27:09.676 Status: TuyaXenomes: Stopping threads.
2024-02-23 10:27:09.676 Status: TuyaXenomes: Stopped.
2024-02-23 10:27:09.676 Status: TuyaXenomes: Entering work loop.
2024-02-23 10:27:09.676 Status: TuyaXenomes: Started.
2024-02-23 10:27:10.265 TuyaXenomes: Waiting 60 seconds to connect TuyaApi login error timeout
2024-02-23 10:27:10.265 TuyaXenomes: Waiting 50 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:27:10.264 Status: TuyaXenomes: Initialized version 1.0.16, author 'Wagner Oliveira contributed Xenomes'
2024-02-23 10:27:20.275 TuyaXenomes: Waiting 40 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:27:30.285 TuyaXenomes: Waiting 30 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:27:40.296 TuyaXenomes: Waiting 20 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:27:50.306 TuyaXenomes: Waiting 10 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:28:00.316 TuyaXenomes: Waiting 0 seconds to connect TuyaApi (Tuya Plug-in)
2024-02-23 10:28:10.326 TuyaXenomes: TUYA plugin started
2024-02-23 10:28:10.326 TuyaXenomes: Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE
2024-02-23 10:28:10.326 TuyaXenomes: 'HardwareID':'10'
2024-02-23 10:28:10.327 TuyaXenomes: 'HomeFolder':'/home/pi/domoticz/plugins/Domoticz-TUYA-Plugin/'
2024-02-23 10:28:10.327 TuyaXenomes: 'StartupFolder':'/home/pi/domoticz/'
2024-02-23 10:28:10.327 TuyaXenomes: 'UserDataFolder':'/home/pi/domoticz/'
2024-02-23 10:28:10.327 TuyaXenomes: 'Database':'/home/pi/domoticz/domoticz.db'
2024-02-23 10:28:10.327 TuyaXenomes: 'Language':'pl'
2024-02-23 10:28:10.327 TuyaXenomes: 'Version':'1.0.16'
2024-02-23 10:28:10.327 TuyaXenomes: 'Author':'Wagner Oliveira contributed Xenomes'
2024-02-23 10:28:10.327 TuyaXenomes: 'Name':'TuyaXenomes'
2024-02-23 10:28:10.327 TuyaXenomes: 'Port':'0'
2024-02-23 10:28:10.327 TuyaXenomes: 'Username':'**************'
2024-02-23 10:28:10.327 TuyaXenomes: 'Password':'**************'
2024-02-23 10:28:10.327 TuyaXenomes: 'Key':'tuya'
2024-02-23 10:28:10.327 TuyaXenomes: 'Mode1':'48'
2024-02-23 10:28:10.327 TuyaXenomes: 'Mode2':'smart_life'
2024-02-23 10:28:10.327 TuyaXenomes: 'Mode6':'-1'
2024-02-23 10:28:10.327 TuyaXenomes: 'DomoticzVersion':'2024.4'
2024-02-23 10:28:10.327 TuyaXenomes: 'DomoticzHash':'731719420'
2024-02-23 10:28:10.327 TuyaXenomes: 'DomoticzBuildTime':'2024-01-30 09:16:34'
2024-02-23 10:28:10.327 TuyaXenomes: Device count: 0
2024-02-23 10:28:10.329 TuyaXenomes: in handlethread
2024-02-23 10:28:10.331 TuyaXenomes: Acquiring GIL for 'onStartCallback'
2024-02-23 10:28:10.382 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 10:28:10.432 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 10:28:10.432 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 10:28:10.432 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 10:28:10.432 TuyaXenomes: onHeartbeat called time=1708680490.4323788
2024-02-23 10:28:10.433 TuyaXenomes: in handlethread
2024-02-23 10:28:10.437 TuyaXenomes: Device count: 0
2024-02-23 10:28:10.437 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 10:28:11.191 [b]Error: TuyaXenomes: handleThread: you cannot auth exceed once in 180 seconds line 218[/b]
2024-02-23 10:28:20.007 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 10:28:20.057 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 10:28:20.057 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 10:28:20.057 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 10:28:26.492 TuyaXenomes: Pushing 'onStopCallback' on to queue
2024-02-23 10:28:26.492 TuyaXenomes: Processing 'onStopCallback' message
2024-02-23 10:28:26.492 TuyaXenomes: Acquiring GIL for 'onStopCallback'
2024-02-23 10:28:26.492 TuyaXenomes: Calling message handler 'onStop' on 'module' type object.
2024-02-23 10:28:26.492 TuyaXenomes: onStop called
2024-02-23 10:28:26.492 Status: TuyaXenomes: Stop directive received.
2024-02-23 10:28:26.616 Status: TuyaXenomes: Exiting work loop.
2024-02-23 10:28:26.692 Status: TuyaXenomes: Stopping threads.
2024-02-23 10:28:26.692 Status: TuyaXenomes: Stopped.
later...
2024-02-23 11:20:37.062 TuyaXenomes: Device count: 0
2024-02-23 11:20:37.062 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:20:47.030 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:20:47.081 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:20:47.081 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:20:47.081 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:20:57.000 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:20:57.050 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:20:57.050 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:20:57.050 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:21:07.020 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:21:07.070 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:21:07.070 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:21:07.070 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:21:17.040 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:21:17.090 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:21:17.090 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:21:17.090 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:21:27.010 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:21:27.060 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:21:27.060 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:21:27.060 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:21:37.028 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:21:37.078 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:21:37.078 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:21:37.078 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:21:47.048 TuyaXenomes: Pushing 'onHeartbeatCallback' on to queue
2024-02-23 11:21:47.098 TuyaXenomes: Processing 'onHeartbeatCallback' message
2024-02-23 11:21:47.098 TuyaXenomes: Acquiring GIL for 'onHeartbeatCallback'
2024-02-23 11:21:47.098 TuyaXenomes: Calling message handler 'onHeartbeat' on 'module' type object.
2024-02-23 11:21:47.098 TuyaXenomes: onHeartbeat called time=1708683707.0985184
2024-02-23 11:21:47.099 TuyaXenomes: in handlethread
2024-02-23 11:21:47.099 TuyaXenomes: Device count: 0
How to add my Tuya Valve Controller (gas/water) to my Domoticz?
tuyaha plugin also results 'Device count: 0' and many messages like "onHeartbeat called time="
a screenshot from my SmartLife app:
link
My anti-flooding home system doesn't make sense without this integration.
Please, help!
Posted: Friday 23 February 2024 20:05
by Xenomes
papryk18 wrote: Friday 23 February 2024 10:38
Newer Tuya devices are not supported by the old Tuyaha (which is archived on GitHub). You can try using
https://github.com/Xenomes/Domoticz-TinyTUYA-Plugin, which is based on the tinytuya module.
Posted: Saturday 24 February 2024 13:53
by papryk18
Works fine. Thanks a lot.
Posted: Monday 26 February 2024 16:23
by Markef
Hello everyone,
Has anyone installed the plugin "
https://github.com/Xenomes/Domoticz-TinyTUYA-Plugin" on Windows ?
I follow the procedure to the letter and do not see where we enter "your apiRegion, apiKey, apiSecret and Search deviceID".
I must be wrong somewhere.
Thanking you,
Mark
Posted: Thursday 29 February 2024 22:08
by Xenomes
Yes the plugin works under Windows.
Markef wrote: Monday 26 February 2024 16:23
In the old version these where used, it could be changed to the names used on the pdf / oit.tuya.com.
Posted: Saturday 26 October 2024 11:51
by manjh
I have been using TUYA plugin version 1.0.13 for quite some time now, it used to work OK but recently I find it non-responding. No apparent error code, just "not working".
I have tried to disable and then enable the plugin, but that sometimes fails and locksup Domoticz.
The solution that works OK is to log in to the Pi, and restart the Domoticz service.
Any clues?
I have thought about migrating to another plugin (tinyTuya??), but am a bit worried about the migration path. Would I lose all devices, and then manually have to re-install?
