Re: GarbageCalendar (new version) lua scripts
Posted: Saturday 08 March 2025 9:36
Oke, i'v updated and it's 100% again
Join 16,000+ members discussing home automation with Domoticz. Get help with Zigbee, ZWave, MQTT, scripting, and 150+ integrations
https://forum.domoticz.com/
--> testing module m_opzet
+ 1.08 (1):Zipcode=6x0xEx Housenr=2x Street= Hostname=rwm.nl Woonplaats=Echt
RunErr:0 RunWarn:0 WebErr:0 WebWarn:0 WTable:3 Found 16 data records, Schedule: vri 4 apr: gft afval ; din 8 apr: Grijze bak ; don 10 apr: pmd ; vri 11 apr: gft afval ; vri 18 apr: gft afval ;
Done...
The explanation for the "#!# Warning: These records are missing in your garbagecalendarconfig.lua file, so no notifications will be send!" can be found here.15:37:18 gc_main: 624: -> Start looping through data to find the first 5 events to show:
15:37:18 gc_main: 671: > first type:gft afval Icon:"nil"
>> GarbageDate:2025-4-4 GarbageType:gft afval; Calc Days Diff=2; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
>> GarbageDate:2025-4-8 GarbageType:restafval; Notify: Active=on Time=15:59 DaysBefore=1 reminder=6 Calc Days Diff=6
>> GarbageDate:2025-4-10 GarbageType:pmd; Calc Days Diff=8; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
>> GarbageDate:2025-4-11 GarbageType:gft afval; Calc Days Diff=9; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
>> GarbageDate:2025-4-18 GarbageType:gft afval; Calc Days Diff=16; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
15:37:18 gc_main: 773: -< End data loop
15:37:18 gc_main: 775: #!# Warning: These records are missing in your garbagecalendarconfig.lua file, so no notifications will be send!
15:37:18 gc_main: 776: #!# Add these records into the garbagetype_cfg table and adapt the schedule, text and icon info to your needs:
["gft afval"] ={hour=19,min=02,daysbefore=1,reminder=0,text="gft afval", icon=nil},
["pmd"] ={hour=19,min=02,daysbefore=1,reminder=0,text="pmd", icon=nil},
["grof tuinafval"] ={hour=19,min=02,daysbefore=1,reminder=0,text="grof tuinafval", icon=nil},
15:37:18 gc_main: 778: #!# -- end ----------------------------
apt update
apt install lua5.4The script should test for the version of LUA installed and in case it isn't, it will run it in the foreground instead of background.eddieb wrote: Saturday 14 June 2025 8:34 There must be a cleaner way to do this, lua is availiable on the host
LUA: => check LUA not found -> Run foreground to use internal LUA.Code: Select all
2025-06-14 08:16:00.377 Status: LUA: @GarbageCal(m_opzet_api): #### start garbagecalendar script v20200211-1430
2025-06-14 08:16:00.377 Status: LUA: @GarbageCal(m_opzet_api): #### Debuging with extra messages because "mydebug=true" in garbagecalendarconfig.lua
2025-06-14 08:16:00.377 Status: LUA: @GarbageCal(m_opzet_api): #### please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
2025-06-14 08:16:00.377 Status: LUA: @GarbageCal(m_opzet_api): domoticzjsonpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:16:00.377 Status: LUA: @GarbageCal(m_opzet_api): datafilepath: /var/tmp/
2025-06-14 08:16:00.377 Status: LUA: @GarbageCal(m_opzet_api): scriptpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:15:00.370 Status: LUA: @GarbageCal(m_opzet_api): #### please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
2025-06-14 08:15:00.370 Status: LUA: @GarbageCal(m_opzet_api): domoticzjsonpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:15:00.370 Status: LUA: @GarbageCal(m_opzet_api): datafilepath: /var/tmp/
2025-06-14 08:15:00.370 Status: LUA: @GarbageCal(m_opzet_api): scriptpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): Loaded /opt/domoticz/userdata/scripts/lua/garbagecalendar/garbagecalendarconfig.lua.
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): Loaded /opt/domoticz/userdata/scripts/lua/garbagecalendar/tablefuncs.lua.
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): Start checking garbagetype_cfg table:
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22 Garbagetype:Plastic, blik en drinkpakken
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22 Garbagetype:Textiel
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22 Garbagetype:Restafval, minicontainers.
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:2:30 Garbagetype:reloaddata
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:7:15 Garbagetype:dummy1
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22 Garbagetype:Groente-, fruit, tuinafval en etensresten
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22 Garbagetype:Papier en karton
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:15:15 Garbagetype:dummy2
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22 Garbagetype:Kerstbomen
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): Start update for text device:
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): Warning: Datafile not found:/var/tmp/garbagecalendar_m_opzet_api.data . Start webupdate now.
2025-06-14 08:15:00.371 Status: LUA: @GarbageCal(m_opzet_api): start foreground webupdate for module m_opzet_api of file /var/tmp/garbagecalendar_m_opzet_api.data
2025-06-14 08:15:00.373 Status: LUA: @GarbageCal(m_opzet_api): lua /opt/domoticz/userdata/scripts/lua/garbagecalendar/m_opzet_api.lua "/opt/domoticz/userdata/scripts/lua/" "9999AA" "99" "" "/var/tmp/garbagecalendar_m_opzet_api.data" "/var/tmp/garbagecalendar_web_m_opzet_api.log" "inzamelkalender.gad.nl" ""
2025-06-14 08:15:00.374 Status: LUA: @GarbageCal(m_opzet_api): Unable to load the data. please check your setup and runlogfile :/var/tmp/garbagecalendar_run_m_opzet_api.log
2025-06-14 08:15:00.374 Status: LUA: @GarbageCal(m_opzet_api): - End -----------------
2025-06-14 08:15:00.374 Status: LUA: @GarbageCal(m_opzet_api): ==> found schedule:
2025-06-14 08:15:00.374 Status: LUA: @GarbageCal(m_opzet_api): Update device from:
0
replace with:
lua /opt/domoticz/userdata/scripts/lua/garbagecalendar/m_opzet_api.lua "/opt/domoticz/userdata/scripts/lua/" "9999AA" "99" "" "/var/tmp/garbagecalendar_m_opzet_api.data" "/var/tmp/garbagecalendar_web_m_opzet_api.log" "inzamelkalender.gad.nl" ""Code: Select all
['Groente-, fruit, etensresten en klein tuinafval'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Groente-, fruit en tuinafval', icon = 'garbagecalendar_green'},
['Restafval'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Restafval', icon = 'garbagecalendar_grey'},
['Papier en karton'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Papier en karton', icon = 'garbagecalendar_blue'},
['Plastic, blik en drinkpakken'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Plastic, blik en drinkpakken', icon = 'garbagecalendar_orange'},
['Textiel'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Textiel'},
['Kerstbomen'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Kerstbomen'},
--> testing module m_mijnafvalwijzer_api
+ 1.30 (1):Zipcode=5624NM Housenr=17 Street= Hostname=
RunErr:0 RunWarn:0 WebErr:0 WebWarn:0 WTable:2 Found 10 data records, Schedule: maa 4 aug: gft ; din 5 aug: Grijze bak ; don 14 aug: papier ; maa 18 aug: gft ; din 19 aug: Grijze bak ;
Done...
