Page 24 of 31
Re: Cheap chinese z-wave products
Posted: Wednesday 25 October 2017 12:54
by LouiS22
TheCondor wrote: Wednesday 25 October 2017 12:42
I've a domux/heiman flood sensor, correctly paired and recognized. By the way every two days it turns ON without any logic. I already tried to repair, reset etc etc but nothing change. Stays off for two-three days and after.... bang, ON without sense.
Could be a fault unit or maybe an error in the xml? The flood parameter in the OWZW web gui is always at 254...
Heiman's stuff are tend to do this: their smoke sensor does the same (ie triggers without sense). You can try to report them this as an issue (they already corrected their buggy firmware for temp/hum sensor). Downside: you cannot upgrade the firmware by yourself.
I don't own this sensor, and according to my knowledge, fellow user micha_pr (
http://www.zwave-review.com/tests/Heima ... sensor.php) haven't noticed this behaviour. So it's possible that your sensor is faulty or... are you really sure that it's not contacted with water (or any liquid, or dew?) Try remove it from the current place and place it somewhere else (ie a dry environment) to see what happens.
Posted: Wednesday 25 October 2017 12:58
by LouiS22
N1co wrote: Tuesday 24 October 2017 12:02
I have a neo coolcam door sensor now for a month, but battery level is still at 100%. This can not be possible right?
It depends on the usage. Does the door opens/closes a lot, or once in a while? If the latter, then it's possible that the battery is still at 100%. But you have to know that there's something fishy with battery reporting in openzwave (or domoticz, I don't know): there were reports in the past with other stuff not reporting correcly (or not reporting at all). Also, if possible, try remove the battery and do a voltage metering with a proper device. Then you will know the battery's actual voltage (and have an estimate if 100% is correct or not). In my own oberservation Neo's firmware is pretty good handling voltage, their stuff's are not battery eaters.
Posted: Wednesday 25 October 2017 17:32
by micha_pr
Yes, this is ok. The sensor is very good designed.
I have it since 3 months - and still a full battery (have checked with volt meter)
Posted: Wednesday 25 October 2017 17:40
by micha_pr
EddyG wrote: Sunday 02 July 2017 13:01
I saw that in openzwave the manufacturer ID of Domux is now 0x021c and Heiman is 0x0260
Only for information - this is wrong too. I will correct it also at OpenZwave within next days.
0x21C - this is
isurpass, a manufacturer from Shenzhen, China (
www.isurpass.com.cn).
Can be checked at Z-Wave alliance page.
I already have got a product list (with the id's) from them and will change it.
It's bad that "everybody" can insert wrong manufacturers in the manufacture XML without checking.
Posted: Thursday 26 October 2017 12:54
by LouiS22
micha_pr wrote: Wednesday 25 October 2017 17:40
0x21C - this is
Isn't that possible Issurpass "lost" this id, or "sold" it? The only certified device from them is from 2015. Or am I wrong?
Posted: Thursday 26 October 2017 13:16
by micha_pr
LouiS22 wrote: Thursday 26 October 2017 12:54
Yes, you are wrong
isurpass is official Z-Wave manufacturer and Domux is an OEM.
you can look as sample here
https://z-wavealliance.org/z-wave_allia ... companies/
or in product list - by manufacturer.
And yes, they have only one certified product - some in certification, some will be certified by the OEM with own brand.
There are some such identical products - certified with different brands
BTW: new manufacturer will never get the same ID from Alliance...
Posted: Thursday 26 October 2017 13:30
by LouiS22
micha_pr wrote: Thursday 26 October 2017 13:16
Yes, you are wrong
I'm such an idiot: domux is an OEM, produced by Heiman.
Posted: Thursday 26 October 2017 16:10
by IDANIT
Has anyone has a huge lag after hitting Light Switch? 1-3sec. Not in Domoticz, the switch itself.
Posted: Thursday 26 October 2017 16:34
by LouiS22
IDANIT wrote: Thursday 26 October 2017 16:10
Neo's light switch?
There's a slight lag - I would say around 1 sec (or less, didn't measure it), but I can live with that. But it's certainly not 3 seconds or so. Touch, clicking noise, light goes on.
Posted: Thursday 26 October 2017 17:20
by IDANIT
Well, touch, 2 sec, clicking noise, light go on, here.
Posted: Thursday 26 October 2017 21:03
by LouiS22
IDANIT wrote: Thursday 26 October 2017 17:20
Ok, I measure it: it's less than 1 sec here. Wild guess: maybe your bulbs need to "warm up"?
Posted: Thursday 26 October 2017 21:18
by IDANIT
LouiS22 wrote: Thursday 26 October 2017 21:03
once again touch,
2sec, clicking noise, light go on
Posted: Thursday 26 October 2017 21:55
by LouiS22
IDANIT wrote: Thursday 26 October 2017 21:18
once again touch,
Weird.
Posted: Friday 27 October 2017 15:14
by LouiS22
once again touch,
Have you checked your OZW network and also the logs? The clicking noise is obviously the relay which controls the lights, and it seems the command takes 2 seconds to route via your network. Pretty weird, I've just tested with my other switch and it's almost instantly routed (ie turned the light on).
Posted: Saturday 28 October 2017 8:35
by IDANIT
I restored the factory settings (hold the button for 10 seconds) so no connection with z-wave network at all. But nothing changed. So next I will check in wall connection, and probably send it for RMA.
Posted: Saturday 28 October 2017 8:50
by LouiS22
IDANIT wrote: Saturday 28 October 2017 8:35
Yeah, pretty sure that's the wisest solution.
Posted: Saturday 04 November 2017 10:02
by sincze
For people who are interested in this offer. This is a sharp price. And EU version. So it seems OK
https://www.tomtop.com/p-s1473eu.html[I ... 871916.jpg[/IMG]
Sent from my SM-G925F using Tapatalk
Posted: Friday 10 November 2017 21:07
by bink
geezerrr wrote: Tuesday 17 October 2017 13:28
Yes I have! Working very well! One remark it’s a a+++ freezer. Max usage 170watt
Did you need to do anything special to get the energy readings? I currently only get watt, but no kwh data seems to be logged. Tried to get it working by enabling "polling" and changing parameter "6. Configure power report: " to 1 but that doesn't seem to make a difference...
Posted: Monday 13 November 2017 9:31
by LouiS22
bink wrote: Friday 10 November 2017 21:07
With which device?
Neo? (Sorry, lost between lines)
Posted: Monday 13 November 2017 9:35
by gielie
I have the same problem with my neo power plugs, when i exclude/include them again it is back but only a few days. They have been working correctly for months. Maybe this is the downside of cheap chinese plugs.
