corbin
Post by corbin »
mKotek wrote: Almost everything is working fine, except, my Temp + Humidity sensor gets detected and created as temp only, even though I can see the humidity reported:
Thanks for reporting - I added temperature and humidity support based on the docs, which says there is one message for both. It looks to now come through as separate messages. I've updated my code to handle, and will be in the next beta update or my github code if you want to test now.
mKotek
Post by mKotek »
That seems to be really complicated. I have switched off and on the gateway and now I have 3 sensors updated at the same time: temp only, humidity only and temp&humidity. So the initial message (after gateway power off and on was the combined one and updates seem to be coming separate.
Have not updated Domoticz to your beta channel though.
Also, regarding multiple gateways, it seems, it will be necessity in my home as single gateway does not cover all areas I need the sensors to be placed (multiple floors). Will check when the rest of the sensors arrive though.
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
Mat2Vence
Domoticz version: 3.7449
Post by Mat2Vence »
corbin wrote:
Mat2Vence wrote:Good job guys! I have just seen the RGB has been added!
Is there any plan to ass the alarm/sounds feature?
Thanks, the sound control will be added if it becomes available - like the RGB which wasn't available initially.
Understood. I am looking forward ;)
deennoo
Post by deennoo »
xiaomi temp.PNG (68.61 KiB) Viewed 2215 times
Nothing different since last fw update corbin,
Still got 3 messages and 3 devices, reporting value when only change, temp / hum and temp+hum
http://domo-attitude.fr
MouCo
Post by MouCo »
corbin wrote:
MouCo wrote:
any sugestions... :)
Don't use multiple gateways :)
But seriously, are you using multiple because you can, or is there an actual need?
One Xiaomi Gateway didn't allowed me to have 3 independent zones concerning to the Alarm feature.
I wanted to be at home with the garage armed... wanted to be a sleep with the garage and part of the home armed... and wanted to be away from home with the all the zones armed... that was the first reason to buy 3 gateways...
The other reason was zigbee coverage.... garage is 2 floors down... and at home sometimes some zigbee devices i have on my room would be offline.
With the 3 gateways all works 100% because my wifi coverage is good everywhere.. :)
corbin
Post by corbin »
MouCo wrote: One Xiaomi Gateway didn't allowed me to have 3 independent zones concerning to the Alarm feature.
Is the zone support no longer an issue since you would now be using Domoticz rules?
mKotek
Post by mKotek »
Is the zone support is no longer an issue since you would now be using Domoticz rules?
Actual coverage is an issue in my case. Already on second floor I am unable to have the devices reporting to Gateway, so multiple ones would help.
corbin
Post by corbin »
Do you have any of the Xiaomi Zigbee power sockets, since they are supposed to act as a repeater?
Also, did your temperature and humidity devices get fixed with my update?
One of the reasons I haven't added multiple gateway support is that I couldn't see an existing way to add multiple passwords and ips for a single hardware device.
deennoo
Post by deennoo »
Following Zigbee protocol each device on main power have to act as a "router" / range extender
Fact is to know if the gateway is a coordinator or a router.
deennoo
Post by deennoo »
Guess what's in it ? Image
A full switch familly !
Put the 2 button switch on main
Definitly need to separate channel 0 and 1 to add them on a floorplan
Coldman
Post by Coldman »
Perfect!
deennoo
Post by deennoo »
Coldman wrote:
Perfect!
Yeap and easy to set, tooks 5 minutes :
- openning
- read instruction
- remove old
- wire new and test
- add to the gateway
- add to domoticz
- put to definitive place
Coldman
Post by Coldman »
deennoo wrote:
Coldman wrote:
Perfect!
- openning
- read instruction
- remove old
- wire new and test
- add to domoticz
In your image I see that mounting box is square but in Russia used round mounting boxes 67 mm in diameter. I also ordered two wall switches, but I have not yet come up with how to mount a square in a circle :?
deennoo
Post by deennoo »
Yeap square not usual in France too, but fit perfectly.
For round 67 is ok as back switch is 55*55*35.
Will made a news on my blog soon about it
Coldman
Post by Coldman »
deennoo wrote:Yeap square not usual in France too, but fit perfectly.
Ok, thanks
corbin
Post by corbin »
deennoo wrote:Following Zigbee protocol each device on main power have to act as a "router" / range extender
I haven't tested conclusively, but it seems like the smart plugs function as a repeater. I'm not sure because messages did not come through for a far away sensor I added, then they started to after a while.
corbin
Post by corbin »
deennoo wrote: Image
Great work by the community!
Coldman
Post by Coldman »
@Corbin
Hi, after last update, I can't to check status of Smart Plug in Lua script like this command
print ('SmartPlug02 ' .. devicechanged['SmartPlug02'])
before it worked, could you check out what I'm doing wrong?
deennoo
Post by deennoo »
Using domoticz beta 3.6395 sending order doesn't work to wall switch.
Will try your git tonight
Having 2 simples on/off (channel 0 & channel 1)device will make more sense than a selector one.
Got a simple wirless switch not reconize too 86sw1 type too will try it with you github
Coldman
Post by Coldman »
deennoo wrote:
I checked simple json request for Smart Plug
...8080/json.htm?type=command&param=switchlight&idx=99&switchcmd=On
response:
   "status" : "OK",
   "title" : "SwitchLight"
but nothing happened
same json for Yeelight is ok
