Page 23 of 52
Re: Controlicz - Easy Domoticz to Alexa Integration
Posted: Thursday 30 November 2017 21:17
by Chakkie
Little progress
The temperature sensor is now recognized as thermostat. Alexa responsed with ....does not support that when ask about the temperature
- Domo.JPG (46.26 KiB) Viewed 7094 times
Posted: Thursday 30 November 2017 21:23
by sach
It's almost working perfectly for me now. Can see both temps and setpoint of my sensor and thermostat via the app. Can query the current temp and setpoint perfectly via voice. Only small thing is when I ask to change setpoint or change via the app it comes up with an error but it works regardless....so not a major.
Posted: Thursday 30 November 2017 21:31
by Madgeni
hey Sach - working on that right now
'WFH' tomorrow, so will nail it.
Hi Chakkie - yep, sorry, sensors are a pain for me, I don't have any, so coding blind
Posted: Thursday 30 November 2017 21:46
by sach
Sounds like a great way for you to receive donations of smart home gear from people so you can get their hardware working.
Posted: Thursday 30 November 2017 22:05
by Scoobydoo
Sorry for the late reply I've been out all day.
Just tried and the temperature is working fine on my system now, the fix you've applied today has certainly worked for me.
Thanks for all the hard work.
Awesome job.
Posted: Friday 01 December 2017 10:31
by Madgeni
sach wrote: Thursday 30 November 2017 21:46
Mrs Madgeni would not be impressed
Posted: Friday 01 December 2017 14:00
by Calzor Suzay
Madgeni wrote: Wednesday 29 November 2017 20:50
Hi and welcome
So you just need Room plans (at least one), you don't need floor plans. The reason Controlicz uses domoticz Room Plans is just to allow you to filter which devices Alexa sees (I copied this from the HA bridge at someone's request).
Controlicz should know lights are lights, so you should be good. To turn off lights by 'room' in Alexa, I think the best option is to set up Routines in the alexa app.
You can also control the name of the light in Alexa by adding - Controlicz: <nameyouwantalexatouse> in the Domoticz description field.
Thanks I'll have a play
Posted: Sunday 03 December 2017 11:23
by SHadley1138
This may have been answered already, but can Alexa/controlicz give feed back on power consumption the is presented in domoticz
For example
“Alexa, how much electricity am I using?”
“Alexa, how much solar power am I generating?”
Posted: Sunday 03 December 2017 16:09
by freijn
So much to Whish for !!
Power usage is really On my whishlist as well but
Would really like to read /speak the content of a text item too.... ( General text )
Posted: Sunday 03 December 2017 19:13
by RedRaven
I have a question or perhaps a feature request.
My ISP does not provide me with a publicly reachable IP so I use my.domoticz.com for managing my Domoticz. Though currently I am using HA Bridge, I would definitely want to switch to Controlicz but since my Domoticz instance is not directly reachable how do I do it?
Is there a way you guys can recommend or something that can be done?
Posted: Monday 04 December 2017 8:56
by freijn
@Madgeni
I am having troubles with the commands of Alexa. Am I the only one??
Switchinh ON/OFF Alexa replies with "OK" but nothing happens and nothing to see in the log's
Asking Temperature Alexa replies that Temp is not possible for device bla bla.
Anything i can check on my end???
Cheers,
Frank
Posted: Monday 04 December 2017 9:09
by dgilbert2
@freijn
I'm having the same issues as you since last night also. Alexa says "OK" but Domoticz is not changing.
Posted: Monday 04 December 2017 9:16
by Madgeni
Hi there - can you disable and re-enable the skill? I think Amazon have had some issue with handling tokens, not sure it's refreshing them
Posted: Monday 04 December 2017 9:18
by dgilbert2
Will try this when I get home this evening, thanks.
Posted: Monday 04 December 2017 9:26
by Alcloud
Madgeni wrote: Monday 04 December 2017 9:16
yes, it works!
Posted: Monday 04 December 2017 11:13
by Scoobydoo
I can confirm this works. Thanks.
Had to disable and then re enable the skill last night to get the skill working again.
Posted: Monday 04 December 2017 11:44
by freijn
YESS YESS YESS success
Alexa behaves again
Thanks Nick !
Frank
Posted: Monday 04 December 2017 11:50
by freijn
Ohhhh Nick , I bought then next Pint for you. THanks for all your work here.
Posted: Monday 04 December 2017 12:01
by Madgeni
Hey thanks freijn - that's really generous
Posted: Monday 04 December 2017 20:07
by dgilbert2
Hi, does the enable / disable delete the groups which I have setup or do they remain?
