Page 22 of 29
Re: How to install Domoticz on a Synology NAS
Posted: Saturday 23 February 2019 20:48
by jumbotroll
MickFly3000 wrote: Saturday 23 February 2019 20:01
For your information, I also have the UsbSerial Driver Package installed. I replaced the ftdi_sio.ko file with your newly compiled file.
Executed chmod 777 /lib/modules/ftdi_sio.ko and restarted the NAS.
New test:
Have done some more fix in the ftdi_sio.c and ftdi_sio.h
I don't know this will fix the problem, but you are free to test
http://www.jadahl.com/synospk/ftdi_sio.ko
If you replace the ftdi_sio.ko in folder /lib/modules you don't need the usbserialdrivers package!
BTW I also updated usbserialdrivers.spk
Posted: Monday 25 February 2019 21:26
by MickFly3000
jumbotroll wrote:MickFly3000 wrote: Saturday 23 February 2019 20:01
New test:
You're great. The rfxcom XL is detected.
[177608.380000] usbcore: deregistering interface driver ftdi_sio
[177608.390000] USB Serial deregistering driver FTDI USB Serial Device
[177614.080000] USB Serial support registered for FTDI USB Serial Device
[177614.090000] usbcore: registered new interface driver ftdi_sio
[177614.090000] ftdi_sio: v1.5.0:USB FTDI Serial Converters Driver
[177833.600000] usb 1-1.3: new full speed USB device using orion-ehci and address 5
[177833.710000] usb 1-1.3: configuration #1 chosen from 1 choice
[177833.720000] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[177833.730000] usb 1-1.3: Detected FT-X
[177833.740000] usb 1-1.3: Number of endpoints 2
[177833.740000] usb 1-1.3: Endpoint 1 MaxPacketSize 64
[177833.740000] usb 1-1.3: Endpoint 2 MaxPacketSize 64
[177833.750000] usb 1-1.3: Setting MaxPacketSize 64
[177833.760000] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
But just to understand. Did you edit the driver file which means the original driver would just not work on a ds212+?
As provided here:
http://www.ftdichip.com/Drivers/VCP.htm
Verstuurd vanaf mijn SM-N960F met Tapatalk
Posted: Monday 25 February 2019 21:35
by jumbotroll
MickFly3000 wrote: Monday 25 February 2019 21:26
New test:
As provided here:
No you have to have the specific driver compiled for the linux kernel that your NAS is running, in this case arch-88f6282 and the original driver from synology do not support your device, so I modified the source code and added your device and recompiled the driver for you.
So only my FTDI driver will support RFXCOM XL for this NAS
Posted: Tuesday 26 February 2019 19:11
by teo1966
there is update from synology to this Version: 6.2.1-23824-6 update to this version ?
Posted: Tuesday 26 February 2019 19:18
by jumbotroll
teo1966 wrote: Tuesday 26 February 2019 19:11
What do you really mean?
Which NAS do you have?
Which version have you used before?
What are you looking for?
BTW latest domoticz beta for DSM 6.2 running on DSM 6.2.1-23824 Update 6 if you wonder.
Posted: Tuesday 26 February 2019 21:32
by teo1966
there were update from synology i was curious if there a risk was to update Version: 6.2.1-23824-6
i have ds1512+ en now has my DSM 6.2.1-23824 Update 4 whit Domoticz V4.10394
sorry for my bad English
Posted: Tuesday 26 February 2019 21:44
by teo1966
there i no risk i have now domoticz V4.10445 and DSM 6.2.1-23824 Update 6 on my DS1512+ no problem
Posted: Friday 08 March 2019 6:46
by hakaesbe
Hi there, I have a 916+ and I am unable to install UsbSerialDrivers_braswell-6.2_6-2.spk or usbutils_braswell-6.2_007-4.spk driver from
http://www.jadahl.com/drivers/DSM_6.2/
using `sudo synopkg install`
I only have a 290 error which is not very verbose, am I missing something?
Thank you!!!
Posted: Saturday 16 March 2019 19:13
by beic
hakaesbe wrote: Friday 08 March 2019 6:46
Thank you!!!
I have DS218 and I can tell you that on my side everything is working excellent (Manual Installation in Package Center)!
Posted: Tuesday 26 March 2019 9:59
by videodrome
@jumbotroll
I have a ds 216j with 2 USB 3.0 ports. I'm thinking of transferring domoticz to synology. Now on a raspy 2.0 I have connected: 1 zstick, 1 rfx.com and 1 sdm 220 modbus. If I purchased 1 USB 2.0 hub connecting it to a synology port, would I be able to make it all work?
Inviato dal mio SM-G955F utilizzando Tapatalk
Posted: Tuesday 26 March 2019 10:06
by jumbotroll
videodrome wrote: Tuesday 26 March 2019 9:59
@jumbotroll
That I can't answer, because I don't have tested on DS216j.
I also use USB 2.0 hub on my DS712+ and use 1 Zstick, 1 RFLink, Bluetooth device and RFXcom RFXcom E.
All working very well here
Posted: Wednesday 27 March 2019 12:42
by Eosfoto
@jumbotroll
In my case (218 Play) this works fine with a
Belkin F4U020VF USB hub. I've bought it on Amazon.de for €18....
Posted: Wednesday 27 March 2019 12:46
by videodrome
Eosfoto wrote:videodrome wrote: Tuesday 26 March 2019 9:59
@jumbotroll
Thanx a lot.
Eastron sdm 220c on synology?
Posted: Friday 29 March 2019 0:11
by videodrome
@jumbotroll
The installation of the package is very easy and the 4.97 version is very stable. One question: I use an eastron sdm 220 as smart meter on the raspberry that needs the libmodbus library, but I'm afraid it's not available for synology and makes this useful smart meter useless.
Re: Eastron sdm 220c on synology?
Posted: Friday 29 March 2019 2:03
by jumbotroll
videodrome wrote: Friday 29 March 2019 0:11
@jumbotroll
I build a test package for you with libmodbus.
http://www.jadahl.com/domoticz_beta_6.2/?arch=armada38x
I don't know if it's working, but you can test
Posted: Wednesday 15 May 2019 16:15
by Creaky
jumbotroll wrote: Sunday 03 February 2019 11:47
Ectholian wrote: Sunday 03 February 2019 9:02
What is the suggested way to update from the stable dsm to the beta (and vice versa)?
- backup config file
- backup database in domoricz just in case
- uninstall current package
- install new package
- restore config
- database should still be there configured?
Always take backup of database (domoticz.db)
Then you can download domoticz beta and update..
No need to reinstall.
Remember, you can't downgrade. If you want to use an older version (beta or stable), you have to uninstall/reininstall.
@Jumbotroll, does this mean I leave the current Domoticz (old) installation on my NAS, download the latest domoticz package from your site and install that manually in Synology Package Center? Does that update the current Domoticz installation that is already on my NAS?
Posted: Wednesday 15 May 2019 16:42
by MickFly3000
After updating my DS212+ Domoticz couldnt reach my RFXCOM XL. After reinstalling the UsbSerialDriverPackage and replacing ftdi_sio.ko it all worked again. Had to reboot the NAS but Im happy again. Is this the way it works after every DSM update?
Posted: Wednesday 15 May 2019 21:38
by jumbotroll
MickFly3000 wrote: Wednesday 15 May 2019 16:42
I don't know, but if synology mess with the drivers, you maybe have to, because I have made a special driver for 88f6281 NAS and synology driver do not support RFXCOM XL in older NAS
Posted: Thursday 16 May 2019 9:24
by Creaky
Hi All,
Since a couple of days I get a notification that there is an update of Domoticz, but clicking the button to install it, doesn't work.
I've searched through this thread to find update instructions, but coudn't find any. How do I update a Jadahl Domoticz install on Synology?
Posted: Thursday 16 May 2019 9:31
by Antori91
Creaky wrote: Wednesday 15 May 2019 16:15
Hello Creaky,
To upgrade my Domoticz on Synology, I use this procedure (again recently with the latest stable). It seems to work fine.
PS: don't forget to save before the old Domoticz install (tar -zcvf domoticz_backup.tar.gz /volume1/@appstore/domoticz/ >&/dev/null)
