Page 21 of 94
Posted: Wednesday 07 October 2015 10:19
by cbe78
Work perfectly on my DS213J (first try --> OK)
Many thanks for the work
Posted: Wednesday 07 October 2015 10:27
by mvveelen
V2.3256 is doing great on my DS414 (armadaxp). Updated this morning and no crashes or errors. Thanks for the package, Jumbotroll !
Posted: Friday 09 October 2015 20:12
by Flyer
Hello!
I would like update domoticz from manual install packages. It's possible? Befor update I must to be uninstall the ols version?
tks in advances
Flyer
Posted: Friday 09 October 2015 20:16
by mvveelen
Why wouldn't you just update using the Package Center?
If there is some reason why you don't want to use the PC, download the package from Jadahl's server (
http://jadahl.dscloud.me/sspks/index.php?fulllist=true) and install it. And yes, you can use it to upgrade the current version. And no, don't uninstall the current version. You could make a backup of the DB before updating, just to be sure.
Posted: Friday 09 October 2015 20:48
by Flyer
Tks you for your fast reply!
I've install from packages center all OK!
bye
Flyer
Posted: Saturday 10 October 2015 9:28
by pipitch
I have some X10 switches and I dont know how to install mochad inside the synology.
Anyone have a solution ?
Posted: Saturday 10 October 2015 12:29
by mvveelen
pipitch wrote:Hello,
You might want to open an new topic for this question.....
Posted: Saturday 10 October 2015 22:28
by Moppersmurf
Jumbotroll, just a word of thanks for the updates
Posted: Saturday 10 October 2015 23:41
by wboerhoop
Hello Jumbotroll, i'm glad with the new versions you compile for the synolgy,but i have a small problem automatic updates through packet centre.
Every update i the directory "/var/packages/domoticz/target/www/images/floorplans" is empty again. i'm using floorplans, so everytime i have to copy them manualy from a copy.
Can you change that.
Thanks.
Posted: Sunday 11 October 2015 0:00
by jumbotroll
wboerhoop wrote:Hello Jumbotroll, i'm glad with the new versions you compile for the synolgy,but i have a small problem automatic updates through packet centre.
Thanks.
EDIT:
/floorplans folder are now backed up and restored in my latest (v2.3299) Synology builds when updating
Jumbotroll
Posted: Sunday 11 October 2015 13:41
by wboerhoop
Jumbotroll
Installed the latest version V2.3299 and worked as expected.
Thanks for the quick response.
Willem
Posted: Monday 12 October 2015 22:12
by jumbotroll
Update!
Domoticz V2.3338.
New:
OpenZWave 1.3.500 (tested and found ok)
/floorplans folder are now backed up and restored when updating. (tested and found ok)
Jumbotroll
Posted: Tuesday 13 October 2015 8:53
by datzmazzie
Thnx. Updated and still working.
Posted: Friday 16 October 2015 10:43
by postman976
I have a question regarding adding hardware.
I want to control my X10 interface device (CM15pro bridge) over USB. For now only the LAN interface version is present.
Can someone add this device feature?
Best regards,
Albert
Posted: Friday 16 October 2015 10:46
by gizmocuz
maybe.... you could install 'ser2net' and bridge a tcp port to usb ?
(Dont know if this is possible on the synology, and if the commands are the same for usb)
Posted: Friday 16 October 2015 11:02
by mvveelen
Hi Jumbotroll, I guess you now have Z-Wave hardware so you can test before releasing the packages? The last few updates work flawlessly. Thanks for the regular updates
Posted: Friday 16 October 2015 12:05
by jumbotroll
mvveelen wrote:Hi Jumbotroll, I guess you now have Z-Wave hardware so you can test before releasing the packages? The last few updates work flawlessly. Thanks for the regular updates
I have borrowed some fibaro units and a z -stick from a friend , I test OpenZWave before I upload new versions of domoticz
Jumbotroll
Posted: Monday 19 October 2015 20:57
by jumbotroll
Update
Domoticz V.2.3397
https://github.com/domoticz/domoticz/commits/master
New
OpenZWave Version: 1.3.513.
http://www.jadahl.com
Jumbotroll
Posted: Tuesday 20 October 2015 14:53
by Eternity
ISSUE SOLVED!
It was a router setting that was blocking Domoticz to connect to external souces. I found out after seeing that email notifications were also not getting thru. ALtering the block in my router solved the problems.
I am running v2.3350 on my DS214plus Synology NAS.
I don't think I changed anything, but all of a sudden I have issues connecting from within Domoticz to external sources:
- ThermoSmart
- Harmony Hub
- Winddelen
And see the following errors (page after page):
2015-10-20 14:49:09.779 Error: Winddelen: Error connecting to: http://backend.windcentrale.nl/windcent ... ie_121.txt
2015-10-20 14:49:10.558 Error: Thermosmart: Error login!
2015-10-20 14:49:20.858 Error: Harmony Hub: Logitech web service login failed.
If i use a browser to login to Logitech, Winddelen or Thermosmart the credentials I use are accepted.
What can I do to solve this?
Posted: Wednesday 21 October 2015 18:07
by amz4u2nv
I've upgraded to the latest version and can see domoticz running on the nas drive.
But when I try to login via the interface it says domoticz is offline.
Any ideas how I can solve this issue.
