Page 21 of 24
Re: Aurora theme
Posted: Sunday 05 August 2018 1:41
by step
I have trouble adding my two cameras to the Dashboard. I've tried several things (I thought maybe my Hikvision DS-2CD2112-I camera's may be the problem but they work fine everywhere else including the browser).
- Screen Shot 2018-08-05 at 01.28.35.jpg (105.69 KiB) Viewed 7452 times
- I've set the substream to mjpg:
* used the link
http://IP/Streaming/Channels/102/httppreview (real substream with mjpg)
* used the link
http://IP/Streaming/Channels/1/picture (main stream with h264)
- I've set theme modes to Compact and Normal
- Made a virtual switch with a text sensor (with the links instead of Hello World)
- Tried an on/off virtual light switch with the cameras added to the active scene
- In the cameras in Domoticz, the cameras work fine:
- Screen Shot 2018-08-05 at 01.22.35.png (21.69 KiB) Viewed 7452 times
- I made sure that the "camera preview in Dashboard" is set to ON in the Aurora theme settings
- I read something about a bug in domoticz where the link may have to be changed but I am unable to find the escaping characters to do so...
-- Domoticz V4.9797
-- Aurora version (most recent)
Anyone else have an idea how to get the cameras into an iFrame on the Dashboard?
Re: Aurora theme
Posted: Tuesday 07 August 2018 9:41
by blauwebuis
The Aurora theme actually has a special mode for getting camera preview images on the dashboard. But that doesn't use the iFrame feature. Instead, you attach a camera to a switch, and then place the switch on the dashboard.
Re: Aurora theme
Posted: Wednesday 08 August 2018 11:16
by step
blauwebuis wrote: Tuesday 07 August 2018 9:41
Please do explain. I've connected the camera's to a virtual switch, an existing switch, a group and a group scene (all lights and blinds) and put them on the Dashboard to no avail. Am I missing something here? What kind of switch?
The camera works if I click on the camera on the Dashboard while it pops up... however no preview image on the Dashboard.
Type of switches I just tried:
- onoff.png (28.66 KiB) Viewed 7344 times
- light.png (26.95 KiB) Viewed 7344 times
Re: Aurora theme
Posted: Wednesday 08 August 2018 11:54
by blauwebuis
You're doing it correctly.
Are you in compact mode perhaps?
Re: Aurora theme
Posted: Wednesday 08 August 2018 23:37
by step
blauwebuis wrote: Wednesday 08 August 2018 11:54
I was, but changing it to Normal mode doesn't change anything. Except for the larger columns etc.
- Checked to see if camera was still connected to the switch
- Popup camera mode works (clicking the small icon to enlarge)
- Switched browser (Safari to Firefox)
- Cleared cache etc
Re: Aurora theme
Posted: Saturday 11 August 2018 19:51
by blauwebuis
And you've enabled showing the 3 highlighted items? And it's in those 3?
Re: Aurora theme
Posted: Sunday 12 August 2018 22:41
by step
blauwebuis wrote: Saturday 11 August 2018 19:51
Yes:
- Screen Shot 2018-08-12 at 22.40.54.png (42.1 KiB) Viewed 7135 times
Re: Aurora theme
Posted: Tuesday 14 August 2018 9:49
by dpui7736
I have some problems.
I only see Room selector in Temperature page. Not in utility neither Switches page.
- Captura.PNG (215.92 KiB) Viewed 7059 times
Utility page have different style (Black letters not white,...)
- Captura2.PNG (261.66 KiB) Viewed 7059 times
- Captura3.PNG (338.24 KiB) Viewed 7059 times
Thanks,
Re: Aurora theme
Posted: Wednesday 05 September 2018 22:24
by madpatrick
I hope some one can help me on this.
I like to change the background color on the mobile theme.
This is now white, but i like to change this to for examply light grey
Where can i change this and which line do i need to change
thanks for the support
Re: Aurora theme
Posted: Thursday 13 September 2018 0:16
by jannnfe
step wrote: Wednesday 08 August 2018 11:16
Same thing here. Nothing works. Someone any ideas?
Re: Aurora theme
Posted: Thursday 13 September 2018 7:53
by jeanclic
I have a camera in my highlighted items on my dashboard, and it is working perfectly...
Maybe try to put your camera as first in your switch list ?
Send via Tapatalk
Re: Aurora theme
Posted: Friday 21 September 2018 8:59
by CLEMENT99
In the system settings, check your Dashboard Mode, it must be set in normal mode.
In the theme settings, check Show three highlighted items (must be checked) and Camera previews on the dashboard (must be checked).
Re: Aurora theme
Posted: Saturday 13 October 2018 22:53
by andyesten
I am using Domoticz version 4.9700 and have installed the Aurora theme as described, and restarted Domoticz. But the theme is not showing up in the theme select list. Am I overlooking something?
Alexander
Re: Aurora theme
Posted: Saturday 20 October 2018 17:43
by itjensen
jeanclic wrote: Thursday 13 September 2018 7:53
Send via Tapatalk
Thanks, I have tried many things and putting the camera first in switch list solved my preview problem.
I am using a Xiaomi Dafang camera. My selector switch now both display video and have up, down, left, right control buttons.
Re: Aurora theme
Posted: Sunday 28 October 2018 9:09
by Pandabeer
I'm facing problems with the Aurora theme - When in dashboard or other sreens I try to get the trend from e.g. power usage - but no new window will be shown - when I use another theme - without any problems I will get the requested graphs from power usage / consumption / heat / temperature etc (I use the latest version of Chrome and Domoticz v4.10111)
Hope somebody can help,
Thank you
Bug found
Posted: Wednesday 31 October 2018 11:19
by Patricen
I mentioned that there is not a sufficient space on the page footer for switches log.
Clicking on the chart context menu works, but it is not possible to reach "Download CSV" line.
Best,
Patrice
Re: Aurora theme
Posted: Thursday 01 November 2018 17:36
by blauwebuis
I fixed the events page. It should now work fine.
Re: Aurora theme
Posted: Friday 02 November 2018 15:53
by Ivanhoe1
Really nice theme!
How can I change the boxsize for my camera picture on dashboard? Now it gets croped so im missing like 50% in height.
Re: Aurora theme
Posted: Saturday 03 November 2018 10:11
by madpatrick
dpui7736 wrote: Tuesday 14 August 2018 9:49
How can i change the color of the text at the Utility page ?
These are still black and not easy to read
Re: Aurora theme
Posted: Sunday 04 November 2018 18:58
by JHO01
Great theme, is it possible to get Spotify on the dashboard, showing the current song?
