Locked
SwordFish
Domoticz version: V4.11375
Re: New Dashboard Design v2, with custom positioning
Post by SwordFish »
robgeerts wrote:Preview with multiple dashboards:
That looks great.
Can't wait to use it.
Dynamic
Post by Dynamic »
1 word: AWESOME!!!! :D
SwordFish
Post by SwordFish »
Its seems that the scene's buttons don't work. When i push them nothing happens. But when i push a on/off button it works?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Could you check in console (f12, network-tab) wich url it calls in my dashboard and compare this one with the url it calls in Domoticz?
robgeerts
Post by robgeerts »
MULTIPLE SCREENS!
Download the latest version from Gitlab for support for multiple screens, to use this, add the following code to the bottom of config.js and change according your needs:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
screens[2] = {}
screens[2]['background'] = 'bg1.jpg';
screens[2]['columns'] = [4,5,6]
robgeerts
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by robgeerts »
EdKo66 wrote:Kodi-logo's:
Image Image
Added the kodi logo as an icon:
SwordFish
Post by SwordFish »
robgeerts wrote:Could you check in console (f12, network-tab) wich url it calls in my dashboard and compare this one with the url it calls in Domoticz?
Its seems that the scene is calling with idx=s1
http://192.168.1.216:8080/json.htm?type=command&param=switchscene&idx=s1&switchcmd=On&level=0&passcode=&jsoncallback=jQuery112406344561574880356_1491554042079&_=1491554042156
SwordFish
Post by SwordFish »
robgeerts wrote:MULTIPLE SCREENS!
var screens = {}
screens[1] = {}
screens[2] = {}
Super
robgeerts
Post by robgeerts »
Oops, my mistake!
Just pushed a fix to Gitlab..
Ierlandfan
Post by Ierlandfan »
What do you use for making images with a transparant background?
SwordFish
Post by SwordFish »
robgeerts wrote:Oops, my mistake!
Sorry again.
When i use the code for multiple screens all of my domoticz switches, scene ed. are gone. When i don't use the code everything is fine?
But the scene's are working again ( with one screen)
HansieNL
Post by HansieNL »
Goodmorning Rob,
Buttons for train / traffic info don't work after last update.
Nice the option to have more than one dashboard page. Now I can place all my fav links on a seperate page :)
Blah blah blah
robgeerts
Post by robgeerts »
Ierlandfan wrote:What do you use for making images with a transparant background?
Photoshop, but I try to find transparent icons/logo's via Google first
SwordFish wrote: When i use the code for multiple screens all of my domoticz switches, scene ed. are gone. When i don't use the code everything is fine?
Could you send me the contents of your config.js?
HansieNL wrote: Buttons for train / traffic info don't work after last update.
They work over here:
Do you get any error?
SwordFish
Post by SwordFish »
Here you go.
Also by me the train info isn't working.
var _LANGUAGE 				= 'nl_NL'; //or en_US
var _HOST_DOMOTICZ		  	= 'http://192.168.1.216:8080';
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= '189dba77d783e7a4';
var _WEATHER_CITY 			= 'Helmond';
var _WEATHER_COUNTRY 		= 'NL';
var _BACKGROUND_IMAGE		= 'bg8.jpg';
var _USE_AUTO_POSITIONING 	= false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = true; //do not show the seconds in the clock
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
//CUSTOM POSITIONING;
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks['s6'] = {}
blocks['s6']['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks['s1'] = {} //dimmer
blocks['s1']['width'] = 4;
blocks['s2'] = {} //dimmer
blocks['s2']['width'] = 4;
blocks['s5'] = {} //dimmer
blocks['s5']['width'] = 4;
blocks['s3'] = {}
blocks['s3']['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks['s4'] = {} //dimmer
blocks['s4']['width'] = 4;
blocks['s10'] = {} //dimmer
blocks['s10']['width'] = 4;
blocks[123] = {} //dimmer
blocks[123]['width'] = 4;
blocks[44] = {} //dimmer
blocks[44]['width'] = 4;
blocks['s9'] = {} //dimmer
blocks['s9']['width'] = 12;
blocks[46] = {} //dimmer
blocks[46]['width'] = 12;
blocks[29] = {} //dimmer
blocks[29]['width'] = 6;
blocks[196] = {} //dimmer
blocks[196]['width'] = 4;
blocks[195] = {} //dimmer
blocks[195]['width'] = 4;
blocks[49] = {} //dimmer
blocks[49]['width'] = 6;
blocks[268] = {} //dimmer
blocks[268]['width'] = 6;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['type'] = '';
blocks['blocktitle_1']['title'] = '';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['s6','s1','s2','s5','s3','s4','s10',123,44,'s9',29,196,195,49,268] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather','train',46]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.nunl,buttons.buienradar]
columns[3]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg8.jpg';
screens[2] = {}
screens[2]['background'] = 'bg8.jpg';
HansieNL
Post by HansieNL »
Sorry... :oops: Button is working but not triggering the frame.
No output in console... or can it be this one? jquery.min.js:4
Blah blah blah
robgeerts
Post by robgeerts »
You defined a second screen but the columns you've enter (4,5,6) doesnt exist:
screens[2] = {}
I've added an extra check so it should work with latest version!
(You can also remove that screen)
SwordFish
Post by SwordFish »
robgeerts wrote:You defined a second screen but the columns you've enter (4,5,6) doesnt exist:
screens[2] = {}
Its working now, thanks
Do you had a change to look why the calendar button doesn't have a border like the radio or nu.nl button?
Edit:
nevermind, found the problem.
robgeerts
Post by robgeerts »
HansieNL wrote:Sorry... :oops: Button is working but not triggering the frame.
Could you test latest version?
SwordFish wrote:nevermind, found the problem.
What was it?
SwordFish
Post by SwordFish »
What was it?
To many copie/paste.
Noticed that the " width:12 " was missing :oops:
robgeerts
Post by robgeerts »
Ok, but I can change it uses a default if it doesnt exists :)
Edit: Done!
Locked
