That looks great.robgeerts wrote:Preview with multiple dashboards:
Can't wait to use it.
1 word: AWESOME!!!!robgeerts wrote:Preview with multiple dashboards:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
screens[2] = {}
screens[2]['background'] = 'bg1.jpg';
screens[2]['columns'] = [4,5,6]
Its seems that the scene is calling with idx=s1robgeerts wrote:Could you check in console (f12, network-tab) wich url it calls in my dashboard and compare this one with the url it calls in Domoticz?
http://192.168.1.216:8080/json.htm?type=command¶m=switchscene&idx=s1&switchcmd=On&level=0&passcode=&jsoncallback=jQuery112406344561574880356_1491554042079&_=1491554042156
Superrobgeerts wrote:MULTIPLE SCREENS!
Download the latest version from Gitlab for support for multiple screens, to use this, add the following code to the bottom of config.js and change according your needs:
var screens = {} screens[1] = {} screens[1]['background'] = 'bg1.jpg'; screens[1]['columns'] = [1,2,3] screens[2] = {} screens[2]['background'] = 'bg1.jpg'; screens[2]['columns'] = [4,5,6]
Sorry again.robgeerts wrote:Oops, my mistake!
Just pushed a fix to Gitlab..
Photoshop, but I try to find transparent icons/logo's via Google firstIerlandfan wrote:What do you use for making images with a transparant background?
Could you send me the contents of your config.js?SwordFish wrote: When i use the code for multiple screens all of my domoticz switches, scene ed. are gone. When i don't use the code everything is fine?
But the scene's are working again ( with one screen)
They work over here:HansieNL wrote: Buttons for train / traffic info don't work after last update.
var _LANGUAGE = 'nl_NL'; //or en_US
var _HOST_DOMOTICZ = 'http://192.168.1.216:8080';
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = '189dba77d783e7a4';
var _WEATHER_CITY = 'Helmond';
var _WEATHER_COUNTRY = 'NL';
var _BACKGROUND_IMAGE = 'bg8.jpg';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = true; //do not show the seconds in the clock
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
//CUSTOM POSITIONING;
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
var blocks = {}
blocks['s6'] = {}
blocks['s6']['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks['s1'] = {} //dimmer
blocks['s1']['width'] = 4;
blocks['s2'] = {} //dimmer
blocks['s2']['width'] = 4;
blocks['s5'] = {} //dimmer
blocks['s5']['width'] = 4;
blocks['s3'] = {}
blocks['s3']['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks['s4'] = {} //dimmer
blocks['s4']['width'] = 4;
blocks['s10'] = {} //dimmer
blocks['s10']['width'] = 4;
blocks[123] = {} //dimmer
blocks[123]['width'] = 4;
blocks[44] = {} //dimmer
blocks[44]['width'] = 4;
blocks['s9'] = {} //dimmer
blocks['s9']['width'] = 12;
blocks[46] = {} //dimmer
blocks[46]['width'] = 12;
blocks[29] = {} //dimmer
blocks[29]['width'] = 6;
blocks[196] = {} //dimmer
blocks[196]['width'] = 4;
blocks[195] = {} //dimmer
blocks[195]['width'] = 4;
blocks[49] = {} //dimmer
blocks[49]['width'] = 6;
blocks[268] = {} //dimmer
blocks[268]['width'] = 6;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['type'] = '';
blocks['blocktitle_1']['title'] = '';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['s6','s1','s2','s5','s3','s4','s10',123,44,'s9',29,196,195,49,268] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather','train',46]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise',buttons.nunl,buttons.buienradar]
columns[3]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg8.jpg';
screens[2] = {}
screens[2]['background'] = 'bg8.jpg';
screens[2] = {}
Its working now, thanksrobgeerts wrote:You defined a second screen but the columns you've enter (4,5,6) doesnt exist:
I've added an extra check so it should work with latest version!Code: Select all
screens[2] = {} screens[2]['background'] = 'bg8.jpg'; screens[2]['columns'] = [4,5,6]
(You can also remove that screen)
Could you test latest version?HansieNL wrote:Sorry... Button is working but not triggering the frame.
No output in console... or can it be this one? jquery.min.js:4
What was it?SwordFish wrote:nevermind, found the problem.
To many copie/paste.What was it?
Users browsing this forum: Eugene and 0 guests
