Page 3 of 5
Re: Hardware pron pics
Posted: Tuesday 26 August 2014 15:56
by mcpoowl
@MaffeMuis
What type of switch you do have linked to your laptop / Tv's / etc.
I only just started myself, but would like to know the state of my PC / or other devices.
Is this just a simple KAKU switch? Or did you do something else?
Posted: Tuesday 26 August 2014 22:00
by willie-p
thx Derik,
About the smartmeter, I don't want it either and am eligible by Dutch law to decline the smartmeter.
For other Dutch people that are reading: Be aware that there will be a big roll out starting from 1 January 2015. It is mandatory by law for energy companies to propose the smartmeter towards the retail consumers they have until 2020.
Correct me if I'm wrong
Cheers,
Will
Posted: Tuesday 02 September 2014 22:13
by maknij
@Gusimelo
Can you share your code for embedding domoticz and emoncms in the same page? I'm building a touchscreen into my kitchen cabinet and also want to show emoncms dials alongside domoticz controls.
Mark
Posted: Wednesday 03 September 2014 10:56
by Gusimelo
Simple, I use two iframes, one for domoticz and the other for emoncms with the embed param, which removes everything but the dashboard itself:
http://emoncms.org/YOUR_USER_NAME/?id=D ... ID&embed=1
If you need further help, please let me know
EDIT: you'll have to make each feed and dashboard public to be able to embed the dashboard
Posted: Thursday 11 September 2014 21:42
by beamzer
do you pass data on from domoticz to emoncms? or do you have energy in emoncms
and light switches and temp in domotics?
cheers,
Ewald...
Posted: Friday 12 September 2014 12:46
by Gusimelo
beamzer wrote:do you pass data on from domoticz to emoncms? or do you have energy in emoncms
cheers,
Ewald...
I log energy on both; I use a network OWL, that has a multicast broadcast of the data... I use a python script that gets this data and forwards it to emoncms, based on this:
https://github.com/micolous/intuition/b ... rotocol.py
I also have a php script running periodically from cron that gets the temp readings from domoticz and forwards them to emoncms
Posted: Saturday 13 September 2014 18:48
by MaffeMuis
mcpoowl wrote:@MaffeMuis
Hi, I just make a ping script to check if a device is on or offline
Posted: Saturday 13 September 2014 18:52
by MaffeMuis
Derik wrote:@ Maffe Muis
Hit F11 for fullscreen..
Like to see your selfmade screen in the future...
When i have my tablet wallmounted...
And yor GPS tracker working in Domoticz???
How do you main, hit F11? can not do that on the tablet.
No the GPS is a stand alown script. It's hard to find a gps script for windows phone
Posted: Saturday 13 September 2014 18:56
by Derik
MaffeMuis wrote:Derik wrote:@ Maffe Muis
@ muis.
Then download maxthon.. you get fulllllllscreen
Is there a how to for your script...
S0 Energy Meter dashboard
Posted: Wednesday 01 October 2014 12:58
by AWI
Just another use of Floorplan. All S0 meters are read by Domoticz (with correction via a LUA script) and with current usage displayed on the "Floorplan"
Posted: Sunday 19 October 2014 17:42
by maknij
Thanks Gusimelo
I've attached a screenshot of my first attempt. One question I still have for you - I'm also using an OWL Intuition-lc and have a python script running collecting the multicast data and uploading to Emoncms, however my script only seems to run for a day or so and then stops with an error. Can you send me the python script you're using?
Mark
Posted: Sunday 09 November 2014 20:08
by Gusimelo
maknij wrote:Thanks Gusimelo
Mark
Did the script I sent you work?... Here is working flawlessly for over a year...
Posted: Monday 17 November 2014 0:30
by thebeetleuk
Guys, this looks great! I'll have to find some time to give this a go!!
Posted: Friday 28 November 2014 22:09
by MaffeMuis
Did some changes on my script. Also I have an smart meter, so I make some tables to see the gas and power usage.
Its custom made with the json from domoticz and a mysql DB and own json commands.
Works great!
Posted: Wednesday 10 December 2014 22:06
by Derik
@ maffemuis...
Please make this nice look possible in a Wikipage....
Posted: Thursday 11 December 2014 8:06
by ThinkPad
Indeed, would be great if you could share the code and how to do this. I could use this really good on a cheap 7" Android tablet (Colorfly E708 Q1, 55 euros) that i use for Domoticz.
Posted: Tuesday 23 December 2014 22:15
by Lieuwke
My 16 channel relay board, not much compared to all the great stuff i've seen here, but hey, i'm just starting out and i am happy to have it up and running
- 16Relayboard.jpg (316.16 KiB) Viewed 9926 times
Posted: Tuesday 23 December 2014 22:19
by ThinkPad
Nice, where do you use it for? I have seen in French houses the lights are controlled from the metercabinet, with 'teleruptors' (a kind of relays). If you have that at your home it is quite easy to tap in with a relay board like you posted.
Posted: Tuesday 23 December 2014 22:34
by Lieuwke
Hi ThinkPad,
i actually have these babies which are going to be used for my garden lightning
- ACRelaisDIN.jpg (290.15 KiB) Viewed 9924 times
(my garden is quite big) and in my house i want to use z-wave (wich is going to be my next step.)
I have 11 DIN Relais for the garden wich will be mounted in a central cabinet in my garden. This way i can use two cheap UTP cables allready running there to drive those. The remaining relais on the 16 relay board will be used to interrupt the doorbell chime when i don't want to be disturbed and to switch the central heating. Some are not yet designated, but will be when idea's come to mind.
Posted: Wednesday 24 December 2014 16:28
by MaffeMuis
ThinkPad wrote:Indeed, would be great if you could share the code and how to do this. I could use this really good on a cheap 7" Android tablet (Colorfly E708 Q1, 55 euros) that i use for Domoticz.
Going to think about it. Because it take some time to make this usable for everybody.
