Traffic with waze in Domoticz
salvation
Re: Traffic with waze in Domoticz
Post by salvation »
Great tip, I will try later today.
Changed this part
$traffic=file_get_contents('https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'.$startlon.'+y%3A'.$startlat.'&to=x%3A'.$endlon.'+y%3A'.$endlat.'&at=0&returnJSON=true&timeout=60000&nPaths=1&clientVersion=4.0.0');
to
   $curl = curl_init();
   curl_setopt_array($curl, array(
       CURLOPT_RETURNTRANSFER => 1,
       CURLOPT_URL => 'https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'.$startlon.'+y%3A'.$startlat.'&to=x%3A'.$endlon.'+y%3A'.$endlat.'&at=0&returnJSON=true&timeout=60000&nPaths=1&clientVersion=4.0.0',
       CURLOPT_USERAGENT => 'Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.8.1.13) Gecko/20080311 Firefox/2.0.0.13'
   $traffic = curl_exec($curl);
   curl_close($curl);
and that did the trick indeed.
D'rMorris
Post by D'rMorris »
I also implemented this functionality, but then with a LUA script. I like to keep scripts in one language preferably and since everything else is also LUA (with the exception of some python scripts to control my LCD screens), I went for the LUA solution. Next to that, I like that LUA is controlled by Domoticz, whereas bash or python run more standalone.
I chose to have a LUA time script (so it runs every minute), but in the script I have a lastupdate timeout of 10 minutes. I still need to add additional time variables, because I only want to run the script between 6AM and 10AM and 3PM and 7PM.
print('<b style="color:Blue">>   Monitoring Traveltimes</b>')
------------- Begin time functions -------------
function timedifference_lastupdate_homework (s)
  year = string.sub(s, 1, 4)
  month = string.sub(s, 6, 7)
  day = string.sub(s, 9, 10)
  hour = string.sub(s, 12, 13)
  t1 = os.time()
  difference_lastupdate_homework = os.difftime (t1, t2)
  return difference_lastupdate_homework
function timedifference_lastupdate_workhome (s)
  t1 = os.time()
  difference_lastupdate_workhome = os.difftime (t1, t2)
  return difference_lastupdate_workhome
------------- End time functions -------------
------------- Begin local variables -------------
-- Debug variables:
debug                  = uservariables["debug_general"]
timeout                = uservariables["timeout_general"]
difference_homework    = timedifference_lastupdate_homework(otherdevices_lastupdate['TravelToWork'])
difference_workhome    = timedifference_lastupdate_workhome(otherdevices_lastupdate['TravelToHome'])
------------- End local variables -------------
------------- Begin debug statements -------------
if debug=="Y"
  then
  print('<b style="color:Red">>> Debug is set to: ' .. debug .. '</b>')
  print('<b style="color:Red">>> Update timeout: ' .. timeout .. '</b>')
  print('<b style="color:Red">>> Lastupdate HomeWork  : ' .. difference_homework .. '</b>')
  print('<b style="color:Red">>> Lastupdate WorkHome  : ' .. difference_workhome .. '</b>')
------------- End debug statements -------------
------------- Begin code -------------
if (difference_homework > timeout and difference_workhome > timeout)
then
function traveltime(departx,departy,arrivex,arrivey)
   --get route from WAZE--
   local waze=assert(io.popen('curl "https://www.waze.com/row-RoutingManager/routingRequest?from=x%3A'..departx..'+y%3A'..departy..'&to=x%3A'..arrivex..'+y%3A'..arrivey..'&returnJSON=true&returnGeometries=true&returnInstructions=true&timeout=60000&nPaths=1&clientVersion=4.0.0&options=AVOID_TRAILS%3At%2CALLOW_UTURNS"'))
   local trajet = waze:read('*all')
   waze:close()
   print("========================================================================================================")
   print(trajet)
   local jsonTrajet = json:decode(trajet)
   --Get major road from JSON
   routeName = jsonTrajet['response']['routeName']
   --Get route steps from JSON info
   route = jsonTrajet['response']['results']
   --Calculate the total time by adding the time of all sections
   routeTotalTimeSec = 0
   for response,results in pairs(route) do
      routeTotalTimeSec = routeTotalTimeSec + results['crossTime']
   --translate the number of seconds to minutes
   routeTotalTimeMin = routeTotalTimeSec/60-((routeTotalTimeSec%60)/60)
   return routeTotalTimeMin
--import JSON addin (already used with DTGBOT and stored in the standard library)
json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")()
-- Update these variables ---------------
--idx of devices for capturing the travel minutes in both direction
idxhomework = 'xxx'
idxworkhome = 'xxx'
--coordinates Home
departy="xx.xxxxxx"
departx="x.xxxxxx"
--Coordinates Work
arrivey="xx.xxxxxx"
arrivex="x.xxxxxx"
-- get travel time
homework=traveltime(departx,departy,arrivex,arrivey)
workhome=traveltime(arrivex,arrivey,departx,departy)
print("homework:",homework,"workhome:",workhome)
-- update Domoticz devices
url='http://IP:PORT/json.htm?type=command&param=udevice&idx=' .. idxhomework .. '&nvalue=0&svalue=' .. homework
read = os.execute('curl -s "'..url..'"')
url='http://IP:PORT/json.htm?type=command&param=udevice&idx=' .. idxworkhome .. '&nvalue=0&svalue=' .. workhome
   print('<b style="color:Red">>> HomeWork lastupdate: ' .. difference_homework .. ' seconds ago</b>')
   print('<b style="color:Red">>> WorkHome lastupdate: ' .. difference_workhome .. ' seconds ago</b>')
------------- End code -------------
sjefk
Post by sjefk »
Hi D'rMorris,
i used you LUA solution but get an error 6 Bad argument #1 'sub' (string expected, got nil).
Am i doing something wrong ?
D'rMorris
Post by D'rMorris »
sjefk wrote:Hi D'rMorris,
Did you create the 2 user variables debug_general (type: string, value either Y or N) & timeout_general (type: integer, value in my case is 600 (10 minutes))?
Next to that, did you create 2 virtual devices called TravelToWork and TravelToHome? In my case I created virtual sensors of the type "pressure".
sjefk
Post by sjefk »
I forgot the uservariables :(
Just added them and renamed my 2 virtual pressure sensor as described in your code.
But still i get the some error, immediatly after the blue text Monitoring Traveltimes
D'rMorris
Post by D'rMorris »
Did you also put the JSON file here: json = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")()?
sjefk
Post by sjefk »
Yep..
pi@raspberrypi ~/domoticz/scripts/lua $ ls -lrt JS*
-rw-r--r-- 1 pi pi 34843 Oct 12 18:06 JSON.lua
And the JSON was in uppercase so i changed it in the lua script to:
json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
But this also did not help..
sjefk
Post by sjefk »
Problem is clearly in otherdevices_lastupdate, when i use a different device as example i get this:
LUA: 2016-01-07 05:20:25
So perhaps i did not create the virtual pressure sensor correctly.
D'rMorris
Post by D'rMorris »
When you renamed the virtual sensors, did you copy it exactly like this:
TravelToWork
TravelToHome
The device names are case sensitive, so device TravelToWork is not the same as traveltowork for example.
sjefk
Post by sjefk »
Yes i copy, paste'd it.
I put these print lines at the top of the script.
print(otherdevices_lastupdate['TravelToWork'])
print(otherdevices_lastupdate['TravelToHome'])
print(otherdevices_lastupdate['Weegschaal'])
print(otherdevices_lastupdate['Denon Status'])
And it only reports the last 2, one of which is also a virtual (text) sensor.
2016-01-07 11:35:00.419 LUA: > Monitoring Traveltimes
2016-01-07 11:35:00.419 LUA: test
2016-01-07 11:35:00.419 LUA: 2016-01-07 05:20:25
2016-01-07 11:35:00.419 LUA: 2016-01-07 11:34:02
D'rMorris
Post by D'rMorris »
Strange... When I look at my devices, the 2 virtual sensors are:
Hardware:VirtualSwitches
Type: General
Subtype: Pressure
Data: 56.0 Bar
Lastupdate: 2016-01-07 11:41:20
and
Type: General
Subtype: Pressure
Data: 56.0 Bar
Can you check if the lastupdate has a value in the devices section? Otherwise, first start with the script below.
       waze:close()
       print(trajet)
    idxhomework = 'xxx'
    idxworkhome = 'xxx'
    --coordinates Home
    departy="xx.xxxxxx"
    departx="x.xxxxxx"
    --Coordinates Work
    arrivey="xx.xxxxxx"
    arrivex="x.xxxxxx"
    -- get travel time
sjefk
Post by sjefk »
I found out the problem was indeed that there was no data in the virtual sensor
I updated the values manually via JSON.
Now it works :)
Thanks for your time D'rMorris !
ubfssF
Domoticz version: 2.2364
Post by ubfssF »
Forget this post
ubfssF
Post by ubfssF »
D'rMorris wrote:Strange... When I look at my devices, the 2 virtual sensors are:
Type: General
Subtype: Pressure
Data: 56.0 Bar
and
Type: General
Subtype: Pressure
Data: 56.0 Bar
       waze:close()
       print(trajet)
    idxhomework = 'xxx'
    idxworkhome = 'xxx'
    --coordinates Home
    departy="xx.xxxxxx"
    departx="x.xxxxxx"
    --Coordinates Work
    arrivey="xx.xxxxxx"
    arrivex="x.xxxxxx"
    -- get travel time
I got an error after retrieving data from Waze:
{"x":4.4859796245308,"y":51.905177579834,"z":"NaN"},{"x":4.4859796245308,"y":51.905177579834,"z":"NaN"},{"x":4.485384204847058,"y":51.90486958680452,"z":"NaN"},{"x":4.485384204847058,"y":51.90486958680452,"z":"NaN"},{"x":4.4847550607899835,"y":51.90454488519832,"z":"NaN"},{"x":4.4847550607899835,"y":51.90454488519832,"z":"NaN"},{"x":4.484661151354932,"y":51.904497777241176,"z":"NaN"},{"x":4.484617489349021,"y":51.90447587497455,"z":"NaN"},{"x":4.484617489349021,"y":51.90447587497455,"z":"NaN"},{"x":4.484446818065281,"y":51.904488792804386,"z":"NaN"},{"x":4.484350476380506,"y":51.90454638986189,"z":"NaN"}],"segCoords":null}
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 48 100 48 0 0 301 0 --:--:-- --:--:-- --:--:-- 303
{ "error" : "Error: 503|Could not find a route"}
lua: script_waze_reistijden.lua:18: attempt to index field 'response' (a nil value)
stack traceback:
script_waze_reistijden.lua:18: in function 'traveltime'
script_waze_reistijden.lua:52: in main chunk
[C]: in ?
____________________________________________________________________________________________________________________________
After changing the lat-lon at my work a bit it worked; in front of it is a one way road and Waze couldn't cope with that apparantly. :D
Now the log displays:
2016-01-25 16:35:02.588 LUA: homework:
2016-01-25 16:35:02.588 LUA: 26
2016-01-25 16:35:02.588 LUA: workhome:
Only the virtual devices get no values :evil:
When I put http://192.168.123.127:8080/json.htm?ty ... evice&idx=' .. 64 .. '&nvalue=0&svalue=' .. 26 in a browser, I get "status" : "ERR"
I had to change the last part of the script and then it worked! Now the scripts ends like this:
    -- get travel time
    -- url='http://IP:PORT/json.htm?type=command&param=udevice&idx=' .. idxhomework .. '&nvalue=0&svalue=' .. homework
    -- read = os.execute('curl -s "'..url..'"')
    -- url='http://IP:PORT/json.htm?type=command&param=udevice&idx=' .. idxworkhome .. '&nvalue=0&svalue=' .. workhome
    commandArray[1] = {['UpdateDevice'] = idxhomework .. '|0|' .. homework}
    commandArray[2] = {['UpdateDevice'] = idxworkhome .. '|0|' .. workhome}
D'rMorris
Post by D'rMorris »
Did you try settings --> more --> user variables ;-)?
Raspberry Piet
Post by Raspberry Piet »
Since yesterday possible to choose for custom sensor in Domoticz! Very nice option i think.
remb0
Post by remb0 »
Raspberry Piet wrote:Since yesterday possible to choose for custom sensor in Domoticz! Very nice option i think.
Great tip! I made also the icons, thanks :)
Waze_icons.zip
(14.51 KiB) Downloaded 190 times
Pierryck
Post by Pierryck »
My virtual device is a general text, which one do you take to change the icon ?
Raspberry Piet
Good! And here are the icons for the people don't like their job ;) :
Waze_sad_icons.zip
(7.16 KiB) Downloaded 146 times
Raspberry Piet
Pierryck wrote:My virtual device is a general text, which one do you take to change the icon ?
Custom Sensor. Available in Beta version.
