Page 3 of 3
Re: OpenZwave & Fibaro Motion Sensor
Posted: Friday 23 October 2015 10:20
by mschut
pvm wrote:Did you:
-wait for 24 hours
Not yet....
-make big changes in light and temperature (it can be set to only report big changes,)
Definitely in light (day and night).
-check the device settings?
Did check all the settings. Didn't change the standard settings, and can't find a setting which would cause it not to work.
Posted: Saturday 24 October 2015 0:47
by pvm
Can you try changing report interval and required change in light level?
Posted: Saturday 24 October 2015 11:33
by mschut
Fixed. Apparently the default setting for reporting temperature and light is 0, meaning, no updates to the controller.
Posted: Monday 19 September 2016 9:40
by nizaga
hello, i have 3 fibaro motion sensors but temp and lux decive is only created for one of them. sensors are working fine but no related lux/temp devices.
any idea how this is happening? i have not changed default conf parameters.
thanks,
Posted: Monday 19 September 2016 14:13
by Glatzi
nizaga wrote:hello, i have 3 fibaro motion sensors but temp and lux decive is only created for one of them. sensors are working fine but no related lux/temp devices.
thanks,
Take a look in the "Groups & Nework" menu & check, if node 1 is in group 1 & 3 of the sensors.
If it is not the case you have to wake the sensor manually before adding node 1 to the mentioned group.
Posted: Monday 19 September 2016 14:58
by nizaga
hi, yes, node 1 is in group 1 & 3 of the sensors, just verified. I just verified again the temp and lux.
I only have LUX in one of the nodes, the temp is available for the 3 nodes, so missing 2 lux
