Siri / HomeKit support for Domoticz
simon_rb
Post by simon_rb »
SwordFish wrote:this works great.
But when i close the putty sessie after run npm run start its stop working?
Is there a way to keep it running? Or do i mis something.
Have you tried the forever command? It's about 8 comments up I think.. I've not set this ups yet but intend to today so can't really help.. Sorry.
SwordFish
Domoticz version: V4.11375
Re: Siri / HomeKit support for Domoticz
Post by SwordFish »
Yes i tried, but i get this warning.
root@domoticzpi:~# forever start /root/homebridge/app.js
warn:    --minUptime not set. Defaulting to: 1000ms
warn:    --spinSleepTime not set. Your script will exit if it does not stay up for at least 1000ms
info:    Forever processing file: /root/homebridge/app.js
G3rard
Domoticz version: No
Post by G3rard »
I am using Eve and it's working great :D
Thanks for sharing this!!!
Not using Domoticz anymore
G3rard
Post by G3rard »
SwordFish wrote:Yes i tried, but i get this warning.
I get those warnings to when running forever, but apparently this doesn't matter because homebridge is working.
emke
Post by emke »
That's not a critica's warming. After that it should run.
I also got a couple of switches that disconnected and can't find anymore. Restarting homebridge doesn't have any effect. Someone found a solution?
simon_rb
Post by simon_rb »
Your a lot closer than I am. I followed the wiki to the letter and I get this error when trying to run npm run startImage
gizmocuz
Post by gizmocuz »
simon_rb wrote:Your a lot closer than I am. I followed the wiki to the letter and I get this error when trying to run npm run start
i think you should use the program "putty", and i think there is a lot more debug log above
i remember i had an error with "mdns" not sure how i solved it, but for sure you have to add the required packages first (with apt-get) before installing this.
if you did not do the apt-get , i suggest to remove the solver, do this, and start again
something like
sudo apt-get update
sudo apt-get install libnss-mdns libavahi-compat-libdnssd-dev
simon_rb
Post by simon_rb »
Start from the beginning you mean? I did use apt-get. I don't know how to remove it though. I'm not too good with the command line side of raspberry pi. Thank you for the reply Image
gizmocuz
Post by gizmocuz »
simon_rb wrote:Start from the beginning you mean? I did use apt-get. I don't know how to remove it though. I'm not too good with the command line side of raspberry pi. Thank you for the reply Image
you should have a homebridge folder in your home folder
cd ~
sudo rm -Rf homebridge
simonrg
Domoticz version: 3.8807
Post by simonrg »
cd ~
It looks like simon_rb might have the same problem as I do, as gizmocuz says the errors above are more informative - it seems to try to use a port out of bounds - which is in a dns routine, gizmocuz what did you do with mdns to sort this out?:
/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56
  dns_sd.DNSServiceRegister(self.serviceRef, flags, ifaceIdx, name,
Error: argument 8: port number is out of bounds.
    at Error (native)
    at new Advertisement (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:56:10)
    at Object.create [as createAdvertisement] (/home/pi/homebridge/lib/HAP-NodeJS/node_modules/mdns/lib/advertisement.js:64:10)
    at Object.startAdvertising (/home/pi/homebridge/lib/HAP-NodeJS/Advertiser.js:7:28)
    at Object.publishAccessory (/home/pi/homebridge/lib/HAP-NodeJS/Accessory.js:10:29)
    at createHAPServer (/home/pi/homebridge/app.js:167:15)
    at /home/pi/homebridge/app.js:92:17
    at Request._callback (/home/pi/homebridge/platforms/Domoticz.js:62:5)
    at Request.self.callback (/home/pi/homebridge/node_modules/request/request.js:373:22)
    at Request.emit (events.js:110:17)
gizmocuz
Post by gizmocuz »
good question, not sure anymore
#1 use the above apt-get command
#2 install the mdns packet
npm install mdns
#3 remove the homebridge folder
#4 start the homebridge tutorial again
something like this, and google helped me too
simon_rb
Post by simon_rb »
gizmocuz wrote:good question, not sure anymore
npm install mdns
Done above and I have the same errors. It does find all my devices but can control them as it doesn't stay running. I am running default ports on Domoticz.. I'm completely at a loss. No idea what to google to try and get it working.
v40jlt4
Domoticz version: 2021.1
Post by v40jlt4 »
Tried npm install --verbose and get:
npm verb request uri https://registry.npmjs.org/ip
npm verb request no auth needed
npm info attempt registry request try #1 at 15:50:40
npm verb etag "2CPEK6B74CEVLLFG2E792DIY5"
npm http request GET https://registry.npmjs.org/ip
npm verb gentlyRm vacuuming /home/pi/homebridge/node_modules/wemo/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
npm http 200 https://registry.npmjs.org/bunyan-prettystream
npm verb get saving bunyan-prettystream to /home/pi/.npm/registry.npmjs.org/bunyan-prettystream/.cache.json
npm verb get saving bunyan to /home/pi/.npm/registry.npmjs.org/bunyan/.cache.json
npm verb tar unpack /home/pi/.npm/delayed-stream/1.0.0/package.tgz
npm verb tar unpacking to /home/pi/homebridge/node_modules/wemo/node_modules/request/node_modules/combined-stream/node_modules/delayed-stream
npm verb afterAdd /home/pi/.npm/lodash/2.4.2/package/package.json written
Then it hangs.
Any ideas??
pvm
Domoticz version: 4.10538
Post by pvm »
Simon_rb, it does not stay running after Restart of your machine?
simon_rb
Post by simon_rb »
Pvm, it doesn't run at all. It crashes before it runs. It finds all of my devices but then crashes. My devices show up within the insteon app on my iPhone but can't do anything with them as they do not respond...
Very puzzling.
spudgunman
Post by spudgunman »
I added a little to the wiki and cleaned up some syntax for ease of use.
simon_rb
Post by simon_rb »
I ran NPM Test and got the same error
simonrg
Post by simonrg »
simon_rb wrote:I ran NPM Test and got the same error
What happens if you run npm test in the Hombridge directory?
I don't think homebridge provides a test package - see npm help:
pi@raspberrypi ~ $ npm help test
NAME
       npm-test - Test a package
SYNOPSIS
           npm test [-- <args>]
           npm tst [-- <args>]
DESCRIPTION
       This runs a package's "test" script, if one was provided.
       To run tests as a condition of installation, set the npat config to true.
So running in homebridge directory should give:
pi@raspberrypi ~/homebridge $ npm test
> [email protected] test /home/pi/homebridge
> echo "Error: no test specified"
simon_rb
Post by simon_rb »
NAME
SYNOPSIS
           npm tst [-- <args>]
DESCRIPTION
That's correct. That's the error I got.
I don't know what to try now! Image
simon_rb
Post by simon_rb »
Maybe I need to remove npm, node from the system completely and start again.. What would be the best way of doing that? Tried sudo NPM Unintsall but that didn't work
